Old 09-29-2015, 08:53 PM   #743
JohnnyP
Drives: 2013 Whiteout Scion Fr-S
Discussion started
JohnnyP is offline   Reply With Quote
The Following User Says Thank You to JohnnyP For This Useful Post:
CSG Mike (09-29-2015)
Old 09-29-2015, 09:05 PM   #744
sato
sato's Avatar
Drives: Dodge Patitas
Just joined...
Sent using Tapatalk
Old 09-30-2015, 10:58 AM   #745
s2d4
s2d4's Avatar
Oddly enough, I've looked into this myself (for work). Although E85 is proven to be better for certain emissions standards (mostly CO2), it is rated worse for others (NOX). Just so happens CA uses a combination of both, hence the current laws.
You are right about the NOX.
I was referring to how a lot of the GTRs in Aus run e85, starting from way back in 2006 and passing the 5 gases test on cars with 400kw at all wheels.
Unless it's been proven to not pass, and maybe so due to different requirements for cars of different era, I can only go by my own experience so far.
The Following User Says Thank You to s2d4 For This Useful Post:
BigFatFlip (09-30-2015)
Old 09-30-2015, 11:01 AM   #746
s2d4
s2d4's Avatar
Originally Posted by Irace86 View Post
Better for emissions but worse on gas mileage, right? They dont like things getting worse drastically. Just my guess. So is that a no on e85 being hooked up?
I am pretty sure those guys don't care for the drop in mileage if they are getting an extra 100kw from it. Maybe it's an American thing as mileage for Aus GTR owners don't come up in conversations at all.
CSG Mike (09-30-2015)
Old 09-30-2015, 11:37 AM   #747
Zan
Drives: 2015 WRB BRZ
From what it looks like, there will be an issue with the fitting of the supercharger and a Mishomoto PCV Catch can. Can anyone confirm this? If so, how did you work around this issue.
Zan is offline   Reply With Quote
Old 09-30-2015, 01:19 PM   #748
TRD-X
TRD-X's Avatar
Drives: Da-Big Banana
Facebook discussion group here:
https://www.facebook.com/groups/1072440386107226/
Page has been parked for a while, but with the kits shipping shortly, time to get the discussion going
The only problem with facebook is everyone starts a group.
Here's another one.
https://www.facebook.com/groups/1492786544353272/
Old 09-30-2015, 01:41 PM   #749
Slicknick951
Slicknick951's Avatar
Drives: 2014 WRB Brz
I was actually going to start asking once people got their kits installed but maybe some people here who have seen it can chime in.
What oil coolers and or air oil separators work with this kit?
Safe to assume crawfords mounting location is out of the question
Slicknick951 is offline   Reply With Quote
Old 09-30-2015, 01:59 PM   #750
TRD-X
TRD-X's Avatar
Crawford offers a universal AOS kit this is what I'll try first.
https://crawfordperformance.com/prod...kit-version-2/
Old 09-30-2015, 02:32 PM   #751
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Based on what I remember, very unlikely it will work unless its relocated else where. The SC takes up most of the space above the engine towards the bulkhead.
Hard to say which kit works without seeing it. Maybe a good discussion for the FAQ/owner's thread
http://www.ft86club.com/forums//show....php?p=2365692
Old 09-30-2015, 06:44 PM   #752
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
The Radium catch can will fit and is currently what I'm using with my Sprintex. It's all the way in the corner to the right of the master cylinder out of the way.
stockysnail is offline   Reply With Quote
The Following 3 Users Say Thank You to stockysnail For This Useful Post:
CK_Bladesmith (09-30-2015), CSG David (09-30-2015), JB86'd (10-01-2015)
Old 10-01-2015, 12:19 AM   #753
killboy
killboy's Avatar
Drives: 1FRS, 1 BRZ, 2S2000s, Evo8, Dak.R/T
We relocated the battery to the trunk (improved weight distribution) and put the Crawford AOS where the battery was with a custom bracket on my Cosworth install. Just another option to consider.
killboy is offline   Reply With Quote
The Following 2 Users Say Thank You to killboy For This Useful Post:
Brzzee (12-06-2015), Porcupint (10-01-2015)
Old 10-01-2015, 05:44 PM   #754
AppleSauce
Drives: FR-S black. Buell XB12s 25th anniv.
So why leave it carb legal if u dont live in cali or some state that does dumb emissions testing.
He who shall be last shall be sideways and smiling
AppleSauce is offline   Reply With Quote
Old 10-01-2015, 05:51 PM   #755
ravisraval
Drives: 2013 FRS
ETA for actual carb exemption? I take it current owners could still get screwed by the popo.
ravisraval is offline   Reply With Quote
Old 10-01-2015, 07:16 PM   #756
BigFatFlip
BigFatFlip's Avatar
Mostly if you don't want to bother getting a custom tune. Its like the equivalent of getting a base tune (I believe the only other option is a "tune it yourself")
Personally, I'm not too worried. Edelbrock, being based out of CA, has CARB cert on all their kits. Even with a 2013MY (which means you'll need to comply with smog by 2018/9?) you shouldn't have to worry about it, unless you give them a reason to pull you over
The Following User Says Thank You to BigFatFlip For This Useful Post:
CSG Mike (10-01-2015)
boost, byebye jackson racing, e-force, edelbrock, forced induction, supercharger
Trunk needs a bit of force to close..... Hachiroku14 Issues | Warranty | Recalls / TSB 30 06-19-2018 06:09 PM
X-Force 3" Exhaust mwjcyber Engine, Exhaust, Transmission 19 03-13-2017 02:55 PM
The force is strong with this one (2015 STi) blackhawkdown FR-S / BRZ vs.... 39 08-01-2014 01:26 AM
X force or Invidia N1 JakeG AUSTRALIA 8 01-18-2014 05:16 AM
G-force meter mikepaul21 Cosmetic Modification (Interior/Exterior/Lighting) 2 03-17-2013 02:24 PM
