10-03-2016, 10:03 PM | #743 |
btr.life
Drives: 2022 GR86
So I got a 2017 BRZ, pulled the ECU info with my OFT today.
Here is what it shows. I do not seem to have a K00C BIN in my OTS v2.070 tune package. I guess they need to come out with new ones to support this model?
The Following User Says Thank You to justinco For This Useful Post: | Lonewolf (10-06-2016) |
10-04-2016, 03:05 AM | #744 |
Drives: UK GT86
Yup, will probably be a while. Someone will need to define the tables for them 1st.
.: Stealth 86 :.
10-04-2016, 03:27 AM | #745 |
yep asabove you will need to sen therom to the oft guys, they will get it defined an make up tune files
10-04-2016, 12:27 PM | #746 | |
btr.life
Drives: 2022 GR86
10-04-2016, 06:17 PM | #747 |
Huge E85 fan!
Drives: 2016 Scion FRS
What's this about OFT making you a custom tune based on logged data? I assume they charge for it. How much better is a custom tune based on logged data than the canned tunes?
10-04-2016, 10:42 PM | #748 | |
If you NA in America where the tunes were made ie similar fuels and you have stock intake and standard type el or uel header then the tune is likely going to be fine and limited benefit getting custom tune. if you have changed intake and live outside america with different fuels and have long tube headers like ace , nameless ptuning or similar then you will benifit from custom tuning and getting a tune from a tuner that has tunes developed on a dyno for those high end headers as they require different vvt cam timings than the base headers to extract the benifits. |
10-06-2016, 09:26 PM | #749 |
Drives: Moped
Perhaps shoot them an email, and see if they are working on support for the 2017's....I'm curious as well
10-07-2016, 11:59 AM | #750 |
btr.life
Drives: 2022 GR86
Yea, I did already. They don't seem to respond to them, I've sent them questions in the past with no reply. I will give them a call today or next week.
The Following User Says Thank You to justinco For This Useful Post: | Lonewolf (10-07-2016) |
10-07-2016, 08:06 PM | #751 |
Drives: United States
Just got my oft, copied my stock tune onto it and retuned the car for UEL stage 2.
My question is there was no fuel octane rating. So there was like stage 1.bin, Stage 2 el.bin, Stage 2 UEL.bin, then Stage 2 EL E85.bin, Stage 2 UEL E85.bin. I have UEL headers and full exhaust and run 93 oct. Is the Stage 2 UEL tune 93 or 91? I saw a video where someone did the brz and his said 91, 93 or E85 for all the tunes and mine didn't. I just want to make sure I'm running stage 2 UEL 93 oct. |
10-07-2016, 09:13 PM | #752 | |
You'll need to remove one of the default .bin files to upload the new map(s). Sent from my SM-G930V using Tapatalk
Invidia catless FP & Q300. Enkei TS-10s. Conti ExtremeContact Sport tires. Hawk HPS pads. Centric Rotors.
10-07-2016, 09:23 PM | #753 | |
10-07-2016, 09:26 PM | #754 | |
10-07-2016, 09:26 PM | #755 |
Drives: FRS-Raven-MT
Not really sure if I am asking this in the right thread but didn't really want to make a new one.
I've been seeming some pretty strange behavior with my ltft and stft readings on my oft. The ltft values seem be stay constant and jump around from 0, 0.78, 2.54, 3.90, and 5.56. The stft has the same kind of behavior just different slightly numbers. My afr and command afr trend pretty close together. Not really sure what to make of this. Just seems a bit odd. Older logs I have, usually these numbers are a bit more dynamic, not so static. Sometimes when I'm driving they are both pegged at the same number. Anyone have any ideas? Or is this normal? I was thinking a faulty o2 sensor but I'm still getting good afr readings seems like. |
10-07-2016, 09:35 PM | #756 |
Huge E85 fan!
What are your LTFT and STFT like at 2500 RPM and at idle? As you accelerate and at higher RPM it'll bound around, you have to get the numbers at steady throttle 2500 RPM and at idle
Similar Threads | ||||
WTB: Open Flash Tablet | TOZER | Canada Classifieds | 3 | 07-05-2015 07:13 PM |
Open Flash Header & Open Flash Tablet | Calavera | Engine, Exhaust, Bolt-Ons | 9 | 05-11-2015 08:27 PM |
FS: open flash headers / open flash tablet - SOLD | alanhung85 | Canada Classifieds | 12 | 02-10-2015 02:08 PM |
FS: Open Flash Tablet (OFT) | mex2309 | Engine, Exhaust, Bolt-Ons | 1 | 10-29-2014 02:49 PM |
Open flash tablet. | cooldandani | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 02-22-2014 07:14 PM |
