Old 08-09-2014, 05:29 AM   #743
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by Poodles View Post
Catch cans are part of the PCV system. Positive Crankcase Ventilation cannot occur with a vented system as it relies on the vacuum supplied by the engine.
Keep in mind this actually helps your rings seal, and also reduces pumping losses.
He knows. Trust me we've already beaten this well into the grave.
Old 08-09-2014, 09:48 PM   #744
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
You keep telling yourself that and that it isn't for emissions reasons.
This. Like I told him, it is his decision to make whether he wants to run a vented or a non a non vented/check valve to keep from pressurizing the crankcase when in boost.
Old 08-11-2014, 02:30 PM   #745
kurbkilla
kurbkilla's Avatar
Drives: Scion FRS (Asphalt)
Sorry if this was talked about but I didn't see it in the search. How bad is the whine on this supercharger and is there a way to reduce or eliminate the noise?
kurbkilla is offline   Reply With Quote
Old 08-11-2014, 03:30 PM   #746
sklimo
It's not loud at all. Sounds perfect IMO
Old 08-11-2014, 05:22 PM   #747
I recommend you hear it in person. You will barely hear it at idle (if you know what to look for), and slightly when you're cruising, if you have a stock exhaust, windows up, radio off.
If you're sitting at high RPM, but part throttle, waiting to start a pull, you'll definitely hear it (sounds like a turbo spooling without the dump tube)
Old 08-11-2014, 05:24 PM   #748
Xerious
Speed Chaser Thrill Seekr
Xerious's Avatar
Drives: 2014 Asphalt Monogram FR-S 6MT
It's a beautiful sound though... lol
Performance: Jackson Racing SC & Oil Cooler, 18x9.5 Gram Lights 57Xtreme Wheels, 255/35 Yokohoma Tires, Rays Volk Racing Black 17hex 12x1.25 lugs, KW V3 C/O, Stance Control Arms
Exterior: LED DRL MOD Kit, Tom's Tail-lights, 5%/40% tint
My Build
Xerious is offline   Reply With Quote
Old 08-11-2014, 06:15 PM   #749
kurbkilla
kurbkilla's Avatar
I recommend you hear it in person......
So.....is there anyone in ventura county with the supercharger that will let me do a ride along? If not anyone going to Chuckwalla Nov 22?
Old 08-11-2014, 07:56 PM   #750
gbrz
Wanted to say thanks to Oscar Jr and Sr for helping me fix my oil cooler hose problem. The problem was due to my install error, nothing wrong with the kit. I took some time off to go visit their office, spoke to both Jr and Sr for about an hour (great guys) and they replaced my hose for free! Excellent service and great attitudes. Thanks guys.
gbrz is offline   Reply With Quote
Old 08-11-2014, 09:06 PM   #751
The CSG BRZ passes by there somewhat regularly on its way to the track for testing...
Old 08-11-2014, 10:46 PM   #752
kurbkilla
kurbkilla's Avatar
passes through ventura county? I would think that would be out of the way for most racetracks. Or are you referring to chuckwalla?
Old 08-12-2014, 12:27 AM   #753
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
We have finally gotten around to posting some results on the Jackson Racing Supercharger Kit Tune we did versus the CARB tune provided by Jackson Racing, versus stock.
The Jackson Racing tune surprisingly is a good tune right out of the bag, though our customer did mention it had a very light hesitation under partial throttle, light load in the low to mid power band, 3000-4000 RPM. As mentioned by our customer we took it for a quick spin to replicate the issue and did notice it a bit, not a lot, but it was noticeable, so that was something we made sure to focus on.
So after the tune there really was not much room for improvement in power, but we did manage to get a few more horsepower on top and torque in the mid range on 91 octane. But I will say on 7 PSI there is only so much you can do to make power and wish there was more boost to make more power.
In any case we did manage to remove the hesitation issue the customer was speaking about by switching to a pure speed density tune and that allowed us to add FlexFuel into the tune very easily by using the MAF sensor voltage input. This keep installation of the FlexFuel kit easy (basically all you need to do is pop your hood and install) and that allows all your readiness monitors to complete properly for smog.
Cheers,
William Knose
Old 08-12-2014, 12:37 AM   #754
I've had this question come up a lot of times, regarding the PCV system, and catch cans.
***The Jackson Racing Supercharger system includes a one-way metal check valve for the rear/passenger PCV. The kit is *complete* and no additions are needed.
For track applications with stickier tires, we recommend putting a catch can in-line with the hosing that connects the crank case to the intake piping.
Old 08-12-2014, 03:55 PM   #755
Frogamazog
Drives: Soon to be a BRZ
Hey guys I'm definitely interested in the JR SC, but have been looking everywhere for header compatibility. I will be doing a full exhaust mod and really like the JDL EL header but have seen a couple posts warning that it may not fit with Rotrex SCs like JR or KW. Anyone have or know someone who has a JDL or other EL headers that pipe up by the pulley system?
Frogamazog is offline   Reply With Quote
Old 08-12-2014, 04:09 PM   #756
Only one way to find out... but unless the header goes REALLY high, it should fit. We're talking stock airbox level high.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
