#743 | |
Drives: FR-S Whiteout
http://datazap.me/u/solidone/plm85g-...2213&mark=2098 Now, it doesnt seem to be causing any knock and another thing is that, beside while taking these logs, under no other circumstance would I go WOT at any time at such a low RPM. Then maybe it's not such a big deal, I'm thinking. Also, what's the daft drop in the stock timing and afr target you speak of? Perhaps I need to address it on those OL fueling and ignitin advance table as well?
Intent > Content
cowardice is the mother of cruelty. |
#744 | ||
Drives: UK GT86
Tip in Load Limits MAF Scale OL Fuel Table It is worth considering that if there is a large amount of overlap then there is the potential that the AFR at the sensor is leaner than the actual cylinder AFR. Quote:
When I reference the large drop in timing and AFRs on the stock tables, just compare the tables to the load limits and you'll see that there's a large region in the top right of both timing and the OL Fuel tables that is never looked up. If you set those cells to the value that the load limits stop at then you could raise the load limits completely and then set them to correct any fueling error. I knocked together a spreadsheet to work that out: Load Limit Value Calculator
.: Stealth 86 :.
#745 | |
I'd also like to note that the max loads seen with the 91 octane seems to be a bit lower than with E85. Not sure if ignition advance as something to say about the lower loads or if it's just the higher octane of the E85 compared to the petrol. Probably a bit of both. I set up the load limits according to the log and it looks quite different than what I set for the E85 rom.
Intent > Content
#746 |
Drives: 2013 BRZ Limited GB 6MT
Hi again,
After resetting the ECU, I was able to log 3 files today with the parameter as suggested. Thank you! ![]() Drive 1 http://datazap.me/u/username404/1029-drive-1 Drive 2 http://datazap.me/u/username404/1029-drive-2 Drive 3 http://datazap.me/u/username404/1029-drive-3 Last edited by username404; 10-29-2015 at 11:33 PM. |
#747 |
^ that's a lot of fuel trim.
Intent > Content
#748 |
Yep that's what I was told. Not sure if the leak is at the manifold where BPB are installed or Headers or Headers & OP.
I got new gaskets from GrimmSpeed for both end of the OFH. Not sure how to reseal the BPB or just remove them. All suggestions are appreciated. Thanks! |
#749 | |
Intent > Content
#750 | |
Hi again, After resetting the ECU, I was able to log 3 files today with the parameter as suggested. Thank you! Drive 1 http://datazap.me/u/username404/1029-drive-1 Drive 2 http://datazap.me/u/username404/1029-drive-2 Drive 3 http://datazap.me/u/username404/1029-drive-3 |
#751 |
^ Is the tune you are using intended for your setup? For use with the BPB? While the fuel trims do till look a bit high, under load it's not horrible maybe +3~8%, but once your idling it will shoot up to +12%. Seems to indicate some sort of leak, but it could possibly be a really poorly matched MAF scale to your setup. I remember seeing a log with a perrin intake using perrin's supplied MAF scale that looks even worse than yours.
If you dont know how to find a leaks in your intake or exhaust, Id suggest you take it to a mechanic that does to make sure there aren't any leaks. For intake vacuum leaks you can shoot some carb or brake cleaner around intake connections that are suspect while idling. If the rpm go up, then you have found a intake leak. For exhaust leaks you can fill a squirt bottle with soapy water, and with the help of another person shoot the exhaust connections with the water as they lightly press on the throttle and bring up the engine revs. If you see the water you shoot on the connections bubbling, then you have found an exhaust leak. There are many other, perhaps better ways, to find leaks in the intake and exhaust. those are the first methods I use since I will have carb and brake cleaner laying around anyway. If there are no leaks found, then its probably safe to say that the maf scale is off by a good margin. Hope this helps.
Intent > Content
#752 | |
What should I do as next step? Just the gaskets anyway? Or Contact Open flash? Thanks! |
#753 | |
It not unusual for even stock cars to have 8% or so trims even on petrol If its like 15% then that generally indicates a bigger problem. |
#754 |
Found the issue. Cracked at OP and FP. Just replaced with Nameless catless resonated downpipe. Hopfully new logs should show better results. |
#755 |
^ ewww... Not so sure changing that out will make much a difference to fuel trims though, since it's a bit downstream form the O2 sensor. But who knows? I've seen weirder shit before.
Intent > Content
#756 | |
Stock OP+FP replaced with Nameless Catless Resonated DP and New Log after the reset. http://datazap.me/u/username404/nov-...log=0&data=1-9 Better? |
| RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 01:15 AM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 12:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 09:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 04:57 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 09:27 AM |
