#743 |
Drives: 2013 FRS
Hi guys,
AllZA1JA01G, ZA1JA00G, ZA1J900G and ZA1J700G ROMs (EU 6MT) now support adjustable launch control and flat-foot shift. So if this applies to you and you would like to test this, please email me at shiv@vishnutuning.com and I'll send you a new map folder with these functions active. Or if you would rather wait until the next public map release, that's good too. J and N series ROMs are in the process of getting these functions too. Hopefully by New Year ![]() Cheers shiv |
#744 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
Welcome back shiv. We tried to start a little war for you but got reprimanded. To keep this technical the car is running great.
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#745 | |
Drives: GT-86
#746 |
Drives: 2013 FRS
No they are quite different. Around the 0xBAD00 section. I'll email td-d and ask him to add it into the RomRoader XDLs as well. And then will release the enhanced ROMs soon after.
#747 |
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
No problem, can do.
Sent from my iPad using Tapatalk HD |
#748 |
Ordered today. Excited.
Anyone have video of the sound at 4k? I'm curious. |
#749 |
Fanboy
Drives: 2013 ultramarine frs
I've got a muffler delete and honestly I found a reduction in overall volume, and while I think I can hear the 4k noise people mention it is not dramatic at all in my car. It's nowhere near as abrupt or loud as civic type r vtec was anyway.
#750 |
#751 |
Drives: 2015 WRX
@shiv@vishnu
So I ordered new grimspeed gaskets and installed them the other day using the method of torquing the inner nuts first then the outer ones in an alternating pattern. The old gaskets didn't appear to have a huge exhaust leak but there might of been a small one. Took logs on the way home from work today and LTFT's were still all over the place, but maybe thats because its still trying to relearn from fixing the exhaust leak? http://www.datazap.me/u/malt/12-29-1...skets?1-2-9-11 So I figured I'd reflash the maps to see if I could wipe the LTFT's and start fresh. Hooked up the OFT to my computer erased the maps and redownloaded the maps from shiv's site. Uploaded the Stage 2 map to the OFT and went outside to reflash it. Got this error message: "OFT is out of sync DME write denied" What exactly does that mean and how do I fix it. EDIT: I did make a backup of my orginal rom and thought about erasing the OFT and reuploading everything again. Just went to try and do that and I get the error "Cannot erase this device". This doesn't sound good.... |
#752 | |
Drives: 2013 FRS
Simple fix: just load maps in each of the 5 map banks and you'll be good to go. |
#753 |
Drives: 2015 WRX
I did manage to get the car flashed again with your tip, thanks! I think there was roughly 2ish gallons of E85 left in the tank when I filled up which might cause a small lean condition if I understand how LTFT works correctly. I'll run this tank out and fill up with 93 and check once more in hopes that this is resolved. If not then I'll either pony up and buy your open flash header and sell this borla header because I had nothing but issues with the borla header on my STi and the flanges not being flat. I'd rather not have to do that but the thought of replacing another set of $30 gaskets for the same result doesn't sound to pleasant to me.
#754 |
Drives: 2015 WRX
http://www.datazap.me/u/malt/12-29-1...flash?1-2-9-11
This log is roughly 10-15 miles after the reflash and it already looks LOADS better to me. Obviously there needs to be some more miles put on it for some fine adjustment to the LTFT's but I don't see it jumping from 18 to -2 anymore while cruising down the road. Fingers crossed that the exhaust leak doesn't come back. |
#755 |
Drives: 2013 Raven FRS 6MT
this is probably one of the dumber questions in this thread but can I use a Mac with my oft? I am about to do the whole process but it seems like I need Windows.
Thanks.
2013 Raven 6MT FRS
Berk Dual Exit Muffler Delete Open Flash Tablet https://www.youtube.com/user/pstaff716 |
#756 | |
Drives: 2013 FRS
Shiv |
| Tags |
| cat overtemp |
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 06:35 PM |
| OpenFlash Tablet Stg 2 Tune (Dyno Progress) | Rombinhood@OpenFlash | Software Tuning | 26 | 10-24-2013 01:19 PM |
| FBM Tuning fixed my issue, FA20 and Visconti didn't work as well | whitefrs | Forced Induction | 253 | 08-19-2013 12:39 PM |
| Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 10:59 PM |
