Old 03-25-2014, 02:43 PM   #743
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
Everyone who is even thinking about ever autocrossing is STX should send a message through the system here: http://crbscca.com/
Subject line should read:#12449 Oil Cooler Allowance Proposal
Then in your own words short and sweet or not so long and drawn out let the SEB know that you support this proposal for all Street Touring classes.
2superblus is offline   Reply With Quote
Old 03-26-2014, 11:46 PM   #744
EN2_Squirrel
EN2_Squirrel's Avatar
As i recently discovered toe arms are illegal. Thanks @blkwrxwag from what i understood, it was how it connected to the car at the innermost part not being a bushing. If it is only the connection like the megan racing version; would the whiteline be legal(appears to be bushing)? Thanks in advance
EN2_Squirrel is offline   Reply With Quote
Old 03-27-2014, 10:06 AM   #745
SubiePig
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
Originally Posted by EN2_Squirrel View Post
As i recently discovered toe arms are illegal. from what i understood, it was how it connected to the car at the innermost part not being a bushing. If it is only the connection like the megan racing version; would the whiteline be legal(appears to be bushing)? Thanks in advance
"on double/unequal arm suspensions only the upper arms or lower arms may be modified or replaced but not both. Non-integral longitudinal arms that primarily control fore/aft wheel movement, (trailing arms, links of a multilink suspension) maynot be replaced, changed, or modified."
http://scca.cdn.racersites.com/prod/...nd%20links.pdf
Page 81-87 are your friend.
Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication
STX Build thread 14th/67 SCCA Nationals (2014)
SubiePig is offline   Reply With Quote
The Following 2 Users Say Thank You to SubiePig For This Useful Post:
PoorMansRacing (03-27-2014), Scooby South (03-27-2014)
Old 03-27-2014, 08:26 PM   #746
EN2_Squirrel
I read very carefully and found no allowance for toe adjusters. "Non-integral longitudinal arms that primarily control fore/aft wheel movement" does not include toe arms. But thank you for giving me the idea.
Old 03-28-2014, 02:22 PM   #747
mrazny
Drives: BMW 135i, soon to BRZ
It's also within a camber allowance. Gotta prove Camber change IMO, and would be how I'd rule if on a Protest Committee.
mrazny is offline   Reply With Quote
The Following User Says Thank You to mrazny For This Useful Post:
EN2_Squirrel (03-28-2014)
Old 03-28-2014, 02:50 PM   #748
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
http://scca.cdn.racersites.com/prod/...april-solo.pdf
Member Advisories
Street Touring
#13236 Toe Link Clarification
There is no allowance in Street Touring for aftermarket toe links. In regards to aftermarket control arms, you can replace
your upper or lower arm. However the mounting points must be in precisely the stock locations, excluding the sway bar
endlink mount, and excluding incidental chan
The Following 3 Users Say Thank You to 2superblus For This Useful Post:
EN2_Squirrel (03-28-2014), PoorMansRacing (03-31-2014), Scooby South (04-06-2014)
Old 03-31-2014, 10:01 AM   #749
SubiePig
I really don't think you actually read was I was saying. I was quoting the fact that they are NOT allowed. I don't understand why this is still a discussion.
Old 03-31-2014, 03:18 PM   #750
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
I did understand but since it was just in the Fastrack I figured I would show it in black and white the ruled opinion.
Old 04-12-2014, 09:11 PM   #751
Itsjusdame
Itsjusdame's Avatar
Drives: Asphalt
I bring my tires to the events to change , and since I haven't found a jack low enough that can reach the front jacking point and portable enough to bring to events.... I have been using the pinch weld behind the front tire (I know the risks , shame on me , I'm trying to do better ) to lift both front and back tire a the same time to change wheels. After doing some reading I might be better of going for dead center to lift both . How do you guys do it??
Itsjusdame is offline   Reply With Quote
Old 04-12-2014, 09:22 PM   #752
xwd
I and most other people lift from the side.
Buy a jack pad like this:
http://protechproducts.com/index.php...ory&path=35_37
Or buy a hockey puck and cut a slit in it to fit the pinch weld. Then you can lift the car anywhere on the side and not worry about it.
I've been using one of the Protech ones on a few different cars for 8+ years now and it's as good as new.
The Following User Says Thank You to xwd For This Useful Post:
Itsjusdame (04-12-2014)
Old 04-12-2014, 10:21 PM   #753
Itsjusdame
Itsjusdame's Avatar
Drives: Asphalt
Thanks , I got a puck I'll be using at my next event
Old 04-16-2014, 06:51 PM   #754
Turbo Den
Drives: FRS, IS300, 911sc
with the new 2014 R.S.
http://ca.autoblog.com/2014/04/16/20...new-york-2014/
since it comes with TRD lowering springs... does it mean, if my non-R.S. model uses the same set of springs, i will still stay in stock class? or into STX?
Turbo Den is offline   Reply With Quote
Old 04-16-2014, 06:53 PM   #755
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
While I can't guarantee anything, I'd say the odds of this staying in CS are slim to none. I know my vote won't allow it to stay.
TomR
ABQautoxer is offline   Reply With Quote
The Following User Says Thank You to ABQautoxer For This Useful Post:
Kido1986 (04-17-2014)
Old 04-17-2014, 10:03 AM   #756
piknockout
Drives: 2014 BRZ
Too many "standard" twins out there that you would make immediately outclassed. I'm sure it will follow the CR logic and move to BS. But will still be allowed in STX.
piknockout is offline   Reply With Quote
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 07:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 02:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 12:02 PM
