Old 08-30-2016, 09:33 PM   #7491
COO86L
COO86L's Avatar
Drives: 2015 86 GTS + Mitsi Lancer GSR
Originally Posted by Docmattic View Post
Do you know if bullet or MRT can upgrade an old/installed kit to SPS specs?
Probably a questions for them.
Anyone can. The only real thing that is upgraded is the blower itself. So you'd be looking around probably 3k AUS? I believe that's what I was quoted to upgrade to the 335 SPS so price wouldn't be much different. Fitting wouldn't be to difficult either.
COO86L is offline   Reply With Quote
Old 08-30-2016, 10:12 PM   #7492
whataboutbob
AutoX-10/10ths every run
Originally Posted by nmastereal View Post
Anyone else start getting P0451 - Evaporative Emission System Pressure Sensor/Switch Range/Performance? Checked all the hoses and they are fully on. Thinking its the fitting to supercharger because it swivels real easy... Been going strong for 10k miles. Guess i will just order up the brass fittings and try that, seeing as its the last thing I can think of besides the sensor itself.
I put a check valve between the output of the evap solenoid and the input to the blower and it rarely happens now. Maybe once or twice a year.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
riboyster (08-31-2016)
Old 08-31-2016, 09:16 AM   #7493
nmastereal
Which check valve did you use? I think the size would be 3/8" or so?
Also does anyone have any oil or residue build up on and under the bypass? I have a little bit sitting ontop of the engine itself. I havnt seen any side effects but want to figure out why its happening. I see a screw hole without a screw =O. Dont know what thats about.
nmastereal is offline   Reply With Quote
Old 08-31-2016, 09:17 AM   #7494
nmastereal
Also how are people draining coolant from the intercooler system?
Old 08-31-2016, 09:53 AM   #7495
nmastereal
Also does anyone have any part numbers for replacement water pumps on the intercooler kit? Mine seems to have bad seals and leaks.
Old 08-31-2016, 10:27 AM   #7496
Kodename47
Kodename47's Avatar
Drives: UK GT86
It's a standard Bosch pump. You could try upgrading to a more efficient pump to see if it improves the efficiency of the system.
This one looks like the original pump: http://www.pedparts.co.uk/product/17...ator-waterpump
From memory, this looks like the possible improved pump:
http://www.ebay.co.uk/itm/BOSCH-12V-...-/270971252256
To drain the system, I would suggest just removing the lower IC hose.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
nmastereal (08-31-2016)
Old 08-31-2016, 04:16 PM   #7497
whataboutbob
This one:
http://www.boombaracing.com/check-valve-8-mm-5-16/
"Boomba Check Valve prevents reverse flow in vacuum and boost lines. It takes just 0.25 Psi to open check valve in forward direction. In reverse direction Check Valve can hold pressure up to 100 Psi. Check Valve has fittings designed for 8 mm (5/16") hose. Available in red and black anodized finishes."
Build thread:Here
Old 08-31-2016, 11:08 PM   #7498
nmastereal
This one:
Thanks! I assume its pointing toward the supercharger since thats the direction of vacuum?
The Following User Says Thank You to nmastereal For This Useful Post:
whataboutbob (09-01-2016)
Old 08-31-2016, 11:17 PM   #7499
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
Went up to Moto East and made the switch to Flexfuel and E85.
Although the picture below shows e57, the dyno was ran at e70.. Had a bit of 93 left!
Dyno numbers are uncorrected, air temp was around 94 degrees in the dyno room.. (Hot day here) with about 45% humidity. Moto East said to adjust roughly 10% for actual numbers, so I'm making roughly 280-290 on E70.. Puts me right around 300whp for E85.. Yay!
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
The Following 2 Users Say Thank You to Rifle For This Useful Post:
D_Thissen (09-01-2016), riboyster (09-01-2016)
Old 09-01-2016, 04:07 AM   #7500
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
That things gonna fly on a cold day
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 09-01-2016, 05:19 PM   #7501
Dipstik-sportech
Dipstik-sportech's Avatar
Still waiting for someone to max the 335 on a built engine
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
Old 09-01-2016, 10:34 PM   #7502
nmastereal
Wouldnt anyone with a built engine go full turbo then?
Old 09-02-2016, 08:59 PM   #7503
Dream20b
Y u do dis?
wait till Tuesday.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 09-02-2016, 09:49 PM   #7504
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Possibly...if I had the opportunity, I'd do a full motor build with the 335.
Same power band like I have now, just way better lol.
The Following User Says Thank You to continuecrushing For This Useful Post:
Dream20b (09-03-2016)
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
