Old 08-25-2016, 09:32 PM   #7477
PitViper
PitViper's Avatar
Drives: 2013 Scion FRS Limited Edition
Originally Posted by ajcarson11 View Post
Thanks! I'll see if i can get ahold of a 75mm...
I have a 75mm that im not using.
Sent from my LG-D950 using Tapatalk
PitViper is offline   Reply With Quote
Old 08-25-2016, 09:57 PM   #7478
nmastereal
Anyone else start getting P0451 - Evaporative Emission System Pressure Sensor/Switch Range/Performance? Checked all the hoses and they are fully on. Thinking its the fitting to supercharger because it swivels real easy... Been going strong for 10k miles. Guess i will just order up the brass fittings and try that, seeing as its the last thing I can think of besides the sensor itself.
nmastereal is offline   Reply With Quote
Old 08-25-2016, 10:46 PM   #7479
GT86NZID
GT86NZID's Avatar
Drives: GT86 '14, F10 '15 & AMG GTS '16
Recently ordered and installed Sprintex SPS stage 2 intercooled kit into my '14 GT86. Which turns out to be NZ's first unit as it is a revised version of stage 1 and introduced in 2016.
Was making 250whp and 285nm on base tune and got it custom tuned and gained to 277whp (326hp crank) and 317nm.
And god she whines loud.
Video of flyby car at full throttle
[ame="https://www.youtube.com/watch?v=tqJlrM1ayJs"]Sprintex SPS supercharged GT86 (Loud Whine) - YouTube[/ame]
GT86NZID is offline   Reply With Quote
Old 08-26-2016, 02:28 AM   #7480
riboyster
riboyster's Avatar
Check evap solenoid?
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 08-26-2016, 08:33 AM   #7481
nmastereal
Dont have the right tools to test the solenoid itself =/
Old 08-26-2016, 12:12 PM   #7482
brianhj
Drives: 2017 Camaro 1SS
If the fitting swivels it most likely is leaking. I had that problem (air leaks, not the code) and put yellow Teflon tape (thicker than white) on the brass fittings and tightened them more than before. No more leaks after that.
brianhj is offline   Reply With Quote
Old 08-26-2016, 01:40 PM   #7483
COO86L
COO86L's Avatar
Drives: 2015 86 GTS + Mitsi Lancer GSR
SPS brothers!!! The SPS system goes above and beyond what I and Delicious Tuning expected. I was the first Toyota 86 in Aus to have one
I've actually sold it and moved on to a Borg Warner EFR turbo so for now it's no whine life for me :'(
COO86L is offline   Reply With Quote
Old 08-26-2016, 06:59 PM   #7484
Dream20b
Y u do dis?
Originally Posted by yip View Post
Just picked up a 335 kit and about to order dw700 injectors, dw300c pump and a flex fuel kit per Moto-Mike's recommendation.
Going with this kit seemed like a no brainer after driving a JRSC C30 & C38 setup.
Fuggin excited!
Booooom, that's what i'm talkin about, yeah, do look into a built motor for sanity.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 08-26-2016, 08:34 PM   #7485
gouldfish
Let me know if that does it for you. I've been struggling with this CEL code for awhile now. My car is currently in the shop and they are having trouble diagnosing the leak. They found a leak, but apparently Sprintex says it's a "known leak" with the supercharger and is nothing out of the ordinary. I am thinking about having the brass fittings put on anyways just to make sure.
gouldfish is offline   Reply With Quote
Old 08-26-2016, 10:21 PM   #7486
nmastereal
Did they test the evap solenoid itself? I am going to do as BrianHJ said and just replace the fitting (hopefully this weekend)
Old 08-28-2016, 07:27 PM   #7487
riboyster
riboyster's Avatar
Found this. Maybe it'll provide some insight? Apparently it is only used as diagnostics, and can be disabled without too much worry (although if it were me, I'd try to solve the problem, just like you, and keep it activated).
Definitely something to do with the evap solenoid and it's fuel line.
Double check your purge line. Make sure it isn't clogged/restricted.
http://www.engine-codes.com/p0451.html#ixzz2xpJ6ZYo8
Old 08-29-2016, 07:40 AM   #7488
Docmattic
Drives: GT 86
Do you know if bullet or MRT can upgrade an old/installed kit to SPS specs?
Probably a questions for them.
Docmattic is offline   Reply With Quote
Old 08-29-2016, 07:42 AM   #7489
Docmattic
Drives: GT 86
Love the exhaust sound! What is your setup?
Old 08-29-2016, 04:49 PM   #7490
gouldfish
Yeah I have seen that site as well, there is a definitely a problem with the car though. It does not drive well and has a rough idle and will just stall out in idle as well. Currently we're replacing the plastic fittings with brass ones but I believe the real issue lies in a leak we found here:
Right where that red circle is, I found this from an earlier post, but never saw any resolution to the leak here. We spray there and get rpm fluctuations. Has anyone else dealt with this leak before. Sprintex has told us this is a "known leak" and is normal. I have my doubts on that....
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
