#7449 | |||
Drives: Passat
Sometimes I overreact to being called names like moron, negative nancy and jerk. I'm working on that. Quote:
These Denso ECUs are too slow to transition from CL to OL, especially when boost kicks in quickly. I could be wrong but I was under the impression that the CL target AFR could not be changed. If possible, this is a great solution. I really like the idea of running CL all the time and simply changing the target AFR to suit conditions. I believe that Porsche does it this way. Anyway, I imagine that several of the resident tuners have this well figured out by now. Quote:
Fan the flames? Who, me? ![]() Peace. |
#7450 |
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
There's a host of tables available to control this transition, and yes, you can alter closed loop AFR.
#7451 | |
Drives: Scion FR-S A/T, Whiteout
CL Delay Engine Speed B Counter Threshold These two tables are what I could find in terms of the actual delay counters. It's my understanding that if you zero these out, the ECU then simply checks your current open loop fuel map cell against Minimum Active Primary Open Loop Enrichment to figure out whether to transition to open loop or not. I'm basing this off of mad_sb's post here: http://www.ft86club.com/forums/showthread.php?t=30418 His tables are different as he's using BRZEdit in that post though, so maybe we can't actually do this unless all of those same tables are defined in RomRaider and I'm just not seeing them. On the subject of full-time closed loop though: What's to keep you from setting that minimum enrichment value to lower than the lowest value on your fuel map? That alone should prevent the transition to open loop completely, because that check is the last step in the process. If you were to then modify CL Fueling Target Compensation A/B (Load) to mirror your open loop fueling, you should be left with a system that stays in closed loop and targets the right AFR all the time. Is there anything particularly unsafe about trying this? Or any gotchas in terms of fueling limits in closed loop defined elsewhere? (This is just me thinking aloud basically, so please correct me if I'm wrong in any of my assumptions here.) Related question: Why aren't there corresponding tables for BRZEdit's Closed Loop AFR A/B in RomRaider? Last edited by PantsDants; 09-14-2014 at 05:47 AM. |
#7452 |
Wideband bro.
As for the map not showing, just not in your def yet. Td-d is the best man for that.
#7453 | |
These are the CL delay tables that are available: CL to OL Transition with Delay (Accelerator) CL to OL Transition with Delay Throttle Hysteresis CL to OL Transition with Delay (Base Pulse Width) CL to OL Transition with Delay BPW Hysteresis CL Delay Minimum (ECT) CL Delay Maximum Engine Speed (Neutral) CL Delay Engine Speed B Counter Threshold CL Delay Maximum (Throttle) (Low Atm. Pressure) CL Delay Maximum (Throttle) (High Atm. Pressure) CL Delay Throttle A Counter Threshold CL Delay Maximum Engine Speed (Per Gear) |
| The Following User Says Thank You to Td-d For This Useful Post: | PantsDants (09-14-2014) |
#7454 | |
As for the CL-to-OL transition maps, I was talking specifically about the counter threshold tables. I wasn't sure if all of the thresholds from the link I posted were defined in some fashion in my rom (A01D) or not. |
#7455 | |
On the counters, there is actually a third counter CL_to_OL_Delay_ which is an overriding counter. I don't think I've defined for the roms, but easy enough to add. |
#7456 |
Drives: S2000
What is the turbo housing that's used? Does it have any info on the nameplate? If not, any guesses as to it's size?
I'm trying to make a setup for my S2000, but none of the electric motors can get even close to the RPM requirements of a properly sized turbo. Makes me wonder how this issue is resolved. |
#7457 | |
Drives: DGM BRZ 6MT
If you don't get any answers here, you might get better luck in the opensource thread: http://www.ft86club.com/forums/showthread.php?t=41148 Sent from my iPhone using Tapatalk
| The Following User Says Thank You to TM For This Useful Post: | DAEMANO (09-15-2014) |
#7458 | |
Time Traveller
#7459 | |
Drives: SWP BRZ
Rob isn't just using of the shelf parts, he's machining compressors etc. |
#7460 | |
Drives: 93'Camry, 82'Corolla, 76' Celica
Thats the bit of magic behind what it took to make this system, and why it would be so hard to reproduce independantly. You need to source, extremely custom made motors, to spin as fast as possible and not blow-up. You need a custom made compressor housing, and a custom made air impeller, that is properly matched to the custom made motor. Then you need to have the electronics "Know" to design a custom made, very high powered controller for this DC brushless motor. You need to have the knowlege of electrical engineering, mechanical engineering, fluid dynamics, and be willing to get a little dirty trying out countless variations of this thing to make it all work. You would have to design and spec out all of these things to companies willing to make them for you. It would also help if you had a lot of machining tools available to do things that nobody else would fool around with.That's what's so awsome about Rob's TQ250, right now! If there are any minor hicupps to work out yet, most of them are in making it dummy proof to install. The fact is, mines been running flawlessly for 9 months now, and thats a major triump of engineering! How many competitors have show-up so far? This stuff is hard to do well, and Rob's work is truly pioneering.
#7461 |
Drives: 2015 Limited series all white brz
hey sorry guys im a bit of a novice, when it says WOT, i understand it means wide open throttle, or "pushing it to the limit" i guess i could say right?
but how is it activated then? ive read via a switch but the videos ive seen never shows anything, unless each videos just recorded with a switch already activated? :P and also this rob guy must be pouring out these models, i msged him a few days ago and no reply at all, must be quite busy at the moment ! |
#7462 |
Drives: 2011 Outlander XLS, 2013 FR-S Blue
It's a small mechanical switch that bolts below the accelerator pedal. It clicks on when the pedal is 95% to the floor.
Sounds silly but it's dead simple to install, or adjust, and it works on any car. |
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 05:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 07:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 08:07 AM |
