08-19-2016, 10:06 AM | #7449 |
Drives: GT 86
08-19-2016, 08:27 PM | #7450 |
Y u do dis?
244/214 on 93, heartbreaker dyno. This with the 80mm pulley 9:1 compression, minimal timing advance. didn't get the e85 tune in yet.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now. |
The Following User Says Thank You to Dream20b For This Useful Post: | riboyster (08-20-2016) |
08-19-2016, 09:48 PM | #7451 |
Hurry up and put the screws to that 335 kit I wanna see what it will top out at.
The Following User Says Thank You to Dipstik-sportech For This Useful Post: | Dream20b (08-20-2016) |
08-20-2016, 01:26 AM | #7452 |
Drives: Subaru
Anyone know if the CARB EO would work for 2015-2016 ? D-719 explicitly lists 2013-2014 as being exempt. AFAIK, there weren't any significant changes between 2013-2014 and 2015+ and so I'm curious to know if owners with 2015+ models would fail inspection w/ this kit installed.
08-20-2016, 01:46 AM | #7453 | |
Drives: 2013 Scion FRS
Keep in mind that this is barring any change to the system aside from the SS210 twin screw. I was wrong, but it is available through Innovative: https://www.delicioustuning.com/node/151
ScreamingElectron - SnakeShit |
08-20-2016, 01:59 AM | #7454 |
Just the tip
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Are the numbers low because of the low compression? Moto-East were getting 300hp 260tq on the 85mm with a stock engine with the 335.
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes |
08-20-2016, 06:45 AM | #7455 |
Y u do dis?
Likely.
Dat Hot Lava Doe
08-20-2016, 09:58 AM | #7456 |
Drives: SC BRZ
Installing a boost gauge today, can I tap in to the bypass line? It seems like the easiest to work with. Otherwise which line should I tap? Meh, guess i'm tapping the MAP
08-20-2016, 12:07 PM | #7458 |
Drives: SC BRZ
08-20-2016, 06:14 PM | #7459 |
Just the tip
Small silver one in the middle higher than the rest. Be careful and don't strip the head. I stripped mine. It's super easy to strip the allen head, thus making me not install a boost gauge. ;(
The Following User Says Thank You to stockysnail For This Useful Post: | chargedup (08-25-2016) |
08-20-2016, 07:48 PM | #7460 | ||
Drives: Subaru
08-20-2016, 10:44 PM | #7461 | |
08-21-2016, 12:32 AM | #7462 |
Drives: pinto power
anyone get to 240/250hp on a 210 unit without e85? for some reason 335i drivers want to be fucbois around me lately and i know at 200 ive still got nothing for them..
Similar Threads | ||||
Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
