Old 09-12-2016, 11:00 PM   #729
BRZ68
Drives: BRZ m/t
Originally Posted by Jonathanlim View Post
By how much? I was over boosting to 25psi, I'm suppose to be at 8psi. Wategate routing was incorrectly done.
On my supposed 8psi map1 by DT, im reaching above 18psi. Delicious recommends connecting port 2 of my Gspeed ebcs to the bottom port of my wastegate(same as yours)
BRZ68 is offline   Reply With Quote
Old 09-12-2016, 11:11 PM   #730
Jonathanlim
Drives: 15' Frs
JDL turbo kit owners thread
Make sure your wastegate spring is correct. Mine came with a pre-set 25psi spring. I had to install the yellow 7psi one.
The green fitting you leave alone. The blue arrow I had a fitting on there but I removed that to the red arrow. You have to remove the red arrow with a Allen wrench. Once you do, you have to block off the blue fitting that you removed. The red arrow should say air. This is how I routed my ecbs. [IMG]https://uploads.tapatalk-cdn.com/20160913/822df49ca826a8bc943128c5d006***9.jpg[/IMG]
Jonathanlim is offline   Reply With Quote
The Following User Says Thank You to Jonathanlim For This Useful Post:
BRZ68 (09-13-2016)
Old 09-14-2016, 04:44 PM   #731
BRZ68
Drives: BRZ m/t
http://uploads.im/CKJM2.jpg
Here's my Precision wastegate. I have mine routed the way Delicious recommends, just like yours. I'm still overboosting by a lot
Old 09-14-2016, 04:56 PM   #732
Amputechture
Drives: 2014 BRZ
Are you running off just wastegate pressure? If not, unhook your boost controller and try just wastegate. If you don't overboost, you know it's either a bad solenoid or something software related. If you still overboost, take apart your WG and see if the diaphragm is damaged, or if you are not using the correct spring.
Amputechture is offline   Reply With Quote
The Following User Says Thank You to Amputechture For This Useful Post:
BRZ68 (09-16-2016)
Old 09-18-2016, 09:16 PM   #733
Jonathanlim
Drives: 15' Frs
I'm having issues with fitment. My turbo to downpipe isn't fitting properly. I've used flanges and brand new v band clamps and nothing is sealing up the gap.
Old 09-19-2016, 06:19 PM   #734
Jonathanlim
Drives: 15' Frs
Old 09-19-2016, 07:52 PM   #735
drambo136
drambo136's Avatar
Drives: 2013 Hot Lava
Did you try loosening all the other bolts hand tight. ie the down pipe and turbo manifold bolts. Id even disconnect the intercooler pipe from the turbo. Then try to get the vband on then snug all the bolts
Sent from my SAMSUNG-SM-G930A using Tapatalk
drambo136 is offline   Reply With Quote
Old 09-21-2016, 01:16 AM   #736
BRZ68
Drives: BRZ m/t
I disconnected my Ebcs and im still overboosting. Im going to check the diaphragm if it's damaged or not. From what i remember, i have a total of 7.5psi springs in there. Will update here what i find out
Old 09-21-2016, 11:13 AM   #737
Jonathanlim
Drives: 15' Frs
Still leaking.
Old 09-21-2016, 11:20 AM   #738
drambo136
drambo136's Avatar
Still leaking.
Damn maybe jesse or someone over at jdl can chime in. Maybe just call them
Old 09-21-2016, 05:19 PM   #739
Lee@JDLAutoDesign
Lee@JDLAutoDesign's Avatar
Drives: Corrado
Still leaking.
What EXACTLY did you try? With the nature of these things a few degrees of rotation of the exhaust system flanges could easily close the gap that you are showing. If it were me, I would disconnect (or at least loosen) all of the exhaust connections, then start by aligning the turbo to downpipe flange. Tighten the v-band enough that the face of the flanges will stay in contact but the downpipe to turbo flange can still rotate. Then work your way downstream connecting the rest of the flanges in a similar fashion.
Lee@JDLAutoDesign is offline   Reply With Quote
Old 09-21-2016, 05:52 PM   #740
Jonathanlim
Drives: 15' Frs
I removed the whole over pipe and downpipe. I re adjusted it and I still have a leak on the turbo. The flanges are not helping at all. I went to autozone and got some gaskets but it's only a temporary fix. There's a leak still
Old 09-21-2016, 10:47 PM   #741
BRZ68
Drives: BRZ m/t
I got my overboosting issue resolved! It turned out to be the hose from the Ebcs to the wastegate melted from the header proximity. Car's running well finally. The only problem left is the reading on my Aem boost gauge seems off.
What vacuum source did you guys use? I put a vacuum manifold connected to the top vacuum source of the intake manifold next to the pcv line for my bov and boost gauge.
Old 09-22-2016, 12:13 AM   #742
JDLAutoDesign
Drives: 13 FRS
I'll give you a call tomorrow and we'll get it sorted one way or another. What's your order/invoice number for the kit so I can pull up all the info.
Thanks!
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 02:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 03:31 AM
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 08:33 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 01:58 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 07:27 PM
