Old 02-04-2014, 04:15 PM   #729
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
Were just having them hold the package at the distro so we can pick it up.
You saw the returned IC end tank piping right?
Ironsquid is offline   Reply With Quote
Old 02-04-2014, 04:25 PM   #730
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Yes, looks like they dropped it off a building.
FullBlown is offline   Reply With Quote
Old 02-04-2014, 08:17 PM   #731
mike the snake
OK, I'm breathing a little easier now. It's been well over 2 months without my car, on what was supposed to be an "under 2 weeks" job.
The new revised downpipe is installed, as are the radiator, spal fans, and shroud.
The new parts still didn't offer enough clearance, so the radiator was moved forward, which finally offered adequate clearance.
Here's some pics showing the extra clearance (with double wrapped DP) and one of the front bumper mod I did. I still have to paint the wire flat black, but that, with the new crash bar will allow MUCH more air into the front.
Old 02-04-2014, 09:07 PM   #732
ZionsWrath
Thanks
ZionsWrath's Avatar
I used to work at FedEx. No comment.
Old 02-05-2014, 05:11 AM   #733
crook
crook's Avatar
Drives: storm black GT
I can't go back through all these pages but on the last couple I see a few of you have had the problem of popping a hose off under the intake manifold?
I have noticed mine was off the other day and managed to put it back on using long nose pliers but havnt got around to putting some clamps on.
How have you guys done it? And has any1 taken any pics of the hose etc as I am out of town and I have to try explain to my dyno tuner which hose needs to be clamped and what's it entail (removing the ac compressor or intake manifold etc) thanks guys
crook is offline   Reply With Quote
Old 02-05-2014, 05:35 AM   #734
Dipstik-sportech
Dipstik-sportech's Avatar
I think there's only one hose that's under there, it connects to the purge solenoid. I took my intake off to get at mine but it was hot so I didn't want to touch the ac compressor.
The Frozen North
Old 02-05-2014, 05:50 AM   #735
mike the snake
Man! Taking the intake off seems like a TOTAL pain, I'd do just about anything to avoid that.
Old 02-05-2014, 05:52 AM   #736
Dipstik-sportech
It's actually very easy. U don't have to take it right off, I just took the 6 bolts off and lifted it up enough to get at the hose
The Frozen North
Old 02-05-2014, 10:16 AM   #737
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I removed my intake manifold to make sure I got clamps on all the hoses and to clean up the coolant routing to the turbo by eliminating the throttle body cooling hoses. There is a picture floating around somewhere in some thread of the bottom of the intake manifold showing what needs to be clamped.
I didn't find it to be a pain. I removed it and reinstalled it in a couple hours after work one night. It goes a lot quicker once you have installed the injectors so you know how to disconnect the fuel lines. I left the injectors and fuel rails installed when I pulled the manifold.
Old 02-05-2014, 10:20 AM   #738
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
no pain at all... it was a 3 hr job for me as it was my first time.
Old 02-06-2014, 07:45 PM   #739
mike the snake
Crash bar arrived!
This, along with the holes I cut in the bumper will allow a LOT more air into the front.
If anything, it'll get air over the AC evaporator so my AC will work better, because the intercooler pretty much blocks off the entire grill area completely.
Old 02-06-2014, 08:29 PM   #740
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
YES!
I want to see how one of those looks with the FMIC in place and grill/mustache removed.
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
Deadspool is offline   Reply With Quote
Old 02-06-2014, 09:24 PM   #741
Dipstik-sportech
Samzies!!!! There's two 10mm bolts on the plate that u mount the bar too that have to be removed.
The Frozen North
Old 02-08-2014, 09:39 PM   #742
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Here's my FBM Stage 2 writeup with FBM Radiator+shroud+SPAL fans installation
http://www.ft86club.com/forums/showthread.php?t=57792
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
