| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
#729 |
Putting vacuum into the pan's drain will only pull air through the PCV system and definitely NOT the pickup.
If the pump is a blockage, like some of us think it might be, then neither will do anything. The only way the vacuum could be an advantage is if you removed the pan and put it into the pickup to get to the screen. This is not something that could be done with simple shop-vac attachments though. |
#730 | |
Drives: 2022 BRZ sport-tech
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 |
#731 |
Drives: Crapcan
If it is like the FA20, it is on the passenger side of the block towards the bell housing. It is a bit hidden by the intake manifold.
#732 | |
#733 |
The hose that goes to the top of the intake...
This shows with our AOS installed, but pinching that hose, or pulling and capping would do it. BUT... if the oil pump IS a blockage, putting vacuum on the drain will still do nothing. Even with the PCV closed off. |
#734 |
If you pull vacuum on the crankcase, the PCV valve on the block will close. It's the other one that needs to be plugged or pinched closed.
#735 | |
#736 |
Drives: 2022 GR86
wait are we seriously talking about using a shop vac on the drain hole to suck out possible excess sealant on a brand new engine that has warranty when the OEM hasn't made an official statement yet?
or are you joking about that... |
#737 |
OH he is serious. I am more just curious if anything comes out!
#738 | |
Having said that, I don't see an issue with doing this as i can't see why it will jeopardized the warranty. If it wasn't for keeping my warranty intact, i would have dropped my pan already.
#739 | |
Ideally one would vacuum out the drain hole while there was still some oil in it. Give the liquid a chance to pull any solids out with it. As Petah said the whole thing is more of a thought exercise or experiment more than a practical way to pull sealant out. Makes no difference to me since I have no stake in it anyway!
#740 | |
Drives: 2018 Subaru BRZ
Had to delete, because it came to me that there is risk on it, as I said, variables. Isn't there a sort of pump that circulates oil, I think its used on automatic transmissions? Might be completely wrong because Im only a 5x100 dirty 1st gen.
#741 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
If you blow or suck it out of the strainer into the pan, there's only a slightly smaller chance that it will get stuck in the pan drain hole.
Design an build a swarm of nano bots to scale the pickup tube (possibly a nano pyramid) and mine the silicon in the screen. Then belay it back down the tube and out the drain without damaging the supporting structure. Possibly hydraulic spiders. They've already got those. Simples.
"I gotta rock." -- Charley Brown |
#742 |
not playing cards
Just run the engine backward
| Tags |
| oh no not again |
| New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! | steel86gt | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 14 | 03-09-2022 01:15 AM |
| Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 06:09 PM |
| Is my engine blown? | dallenj | Engine, Exhaust, Transmission | 39 | 01-30-2017 04:18 PM |
| Blown engine due to 0W-20? | Benschneider06 | Engine, Exhaust, Transmission | 45 | 07-23-2015 02:33 AM |
| Subaru BRZ complete engine gasket & seal kit 2.0L | JPxM0Dz | Engine, Exhaust, Transmission | 0 | 12-18-2012 11:11 AM |
