#729 |
Drives: 2013 Ultramarine FR-S
Installed the 2017 cluster last night. Spent way too long in a 30F car to figure out where the security programming was, but I think it was worth it in the end. Just need to order the buttons and be good to go.
The Following 6 Users Say Thank You to DustinS For This Useful Post: | eastendraceshop (01-30-2019), Kiibiiin (01-30-2019), MCTeeJ (01-30-2019), Sportsguy83 (01-30-2019), Teseo (01-30-2019), Zer0 (01-30-2019) |
#731 |
Drives: 2013 frs red
Thank you for letting me live vicariously through your obsession lol
The Following User Says Thank You to Lantanafrs2 For This Useful Post: | DustinS (01-30-2019) |
#732 |
Drives: 2015 Scion FR-S
#733 |
Not too difficult. Hardest part was getting security programmed. Something the dealer can do very quick and easy. I just wanted to see if it was possible for people that have Techstream to do it themselves.
Unless you are changing LEDs in the cluster, than that is the most difficult part.
The Following User Says Thank You to DustinS For This Useful Post: | Zer0 (01-31-2019) |
#734 |
Video of how to program the cluster.
#735 |
Picked this up from the junkyard over the weekend. Not sure if I will use it, but can't beat junkyard prices for a 2J.
#736 |
New Radiator Came in:
The Following User Says Thank You to DustinS For This Useful Post: | Zer0 (02-20-2019) |
#737 |
Drives: 2015 frs
That radiator looks good. What are the dimensions? Looking into doing a V mount once I get the crossmember project done.
#738 |
~ 27" x 13.25" x 3"
#739 |
Those fans look super beefy
![]() Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post: | DustinS (02-26-2019) |
#740 |
![]() Oil Pump came in yesterday. Will get better pictures later. Should help with the oil pressure issues. As soon as the weather quits giving us one 60 degree day and then a week of 20 degree days, I will start tearing the car apart to get everything buttoned up.
#741 |
Engine is ready to come out. Ran out of time last night.
![]() I don't think my current catch can is enough. Going to try and figure out another solution before the engine goes back in (which I hope to be next week) ![]() This shows more build up and the flakes of nylon or whatever is woven around the trickflow hose. Super cheap and has actually worn off. Will be replacing with vibrant hose. The fibers are just from taking the intake off, they weren't actually being sucked into the intake while running. ![]() Trans leak is still as bad as before. Plan is to try and remove just the tail housing and reseal, worst case I send it to someone to have diagnosed. ![]() Wasn't going to do a whole lot while engine was out, but things keep popping into my head. Improved Racing Crank Scraper/Windage tray, as well as Energy Suspension full bushing kit, and Whiteline offset front control arm bushing have been added. Hopefully get everything in before next weekend. ![]() ![]() ![]()
The Following User Says Thank You to DustinS For This Useful Post: | Zer0 (04-04-2019) |
#742 |
Drives: 2015 frs
You can't go wrong with oil system upgrades.
The Following User Says Thank You to Zer0 For This Useful Post: | DustinS (04-04-2019) |
The reason I'm always broke - Dustin's Supercharged 86 | Dustin | Member's Car Journals | 211 | 11-08-2015 10:57 AM |
Help! New Car Engine Blew Up. What are my rights? | Obsidiank | Scion FR-S / Toyota 86 GT86 General Forum | 53 | 12-11-2014 11:43 AM |
Midwest Modified - Auto Photography by Dustin Faulkner (aka Fancy) | Kuzuri | Great Lakes | 20 | 02-16-2014 05:23 PM |
Engine Warm-up Time | Chad86 | Scion FR-S / Toyota 86 GT86 General Forum | 44 | 01-10-2014 12:03 AM |
So my engine blew up.... | alliedcam1 | Engine, Exhaust, Transmission | 57 | 12-28-2013 02:50 PM |
