Old 10-14-2013, 08:36 PM   #715
blackstar847
X GT86 X
Drives: 2013 FRS
Originally Posted by Muskokan View Post
Holy! That's tons, sometimes I get a a 1x1 condensation spot, not enough for me to bring it in yet. But that thing looks like you could keep a fish happy.
Never had an issue with it at all then it's been raining the last few days and woke up to this. I'm yet to read this whole thread (read the first 5 and realized there's over 30 pages) but I'm hoping my dealer will fix it.
blackstar847 is offline   Reply With Quote
Old 10-14-2013, 08:41 PM   #716
Muskokan
Drives: white Sport-tech
Oh yea it was super common when they first came out, an over tightened screw I think it was. Thought they would fix is after the tsb, apparently not lol
Muskokan is offline   Reply With Quote
Old 10-15-2013, 01:31 PM   #717
wheelhaus
wheelhaus's Avatar
I finally got around to fixing mine.
Just removed the light, gently removed the gasket (as to not tear it) and poured out as much water as possible (I had about 1 1/2" deep puddle) by tilting the light toward the inboard corner, then leveling the light to pour the water out the nearest bulb hole. This was remarkably effective as it left less than 1/4" of water.
I then cut a 20oz Mt Dew bottle to fit around the larger bulb socket and fit it to a hair dryer. This would pump warm dry air through the housing and let the moist air escape through the smaller hole used earlier to pour the water out. Kept it on lowest heat and an hour later it was completely dry. Shook it around with the lens facing down to check for any remaining water droplets.
Cleaned the mating surfaces thoroughly with ISO alcohol. Reinstalled everything with a small bead of black silicone (less than 1/8") around the gasket (both sides) where it gets pinched, and around the hardware, and snugged down the bolts. Will report back after some rain/snow.
wheelhaus is offline   Reply With Quote
Old 10-16-2013, 02:42 PM   #718
Hanakuso
I noticed a small insect in one of my taillights. Not sure if they will replace it under warranty but since my FRS is a 2012 build I rather have the revised version.
Hanakuso is offline   Reply With Quote
Old 10-23-2013, 03:36 PM   #719
blackstar847
X GT86 X
Drives: 2013 FRS
I went to my dealer today and was told my VIN is newer than the current TSB for the tail light but they offered to replace it at no charge still. Should be in next week.
Old 10-25-2013, 08:18 AM   #720
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
Had mine replaced, drivers side is fogging again.
Deadspool is offline   Reply With Quote
Old 10-29-2013, 09:46 PM   #721
Garstang
Garstang's Avatar
Drives: FRS
I had mine mist up early spring. I did not do anything about at that point. I thought I would keep an eye on thru the summer. Well this fall it misted up again. So I took it in to the dealer. They Knew about the problem and did even come out and look. They just ordered up another on on warranty. So If you think the problem is gone and you don't act on it. It will bite you later. Hope you still have warranty left at that point.
Garstang is offline   Reply With Quote
Old 10-29-2013, 09:47 PM   #722
ZionsWrath
Thanks
ZionsWrath's Avatar
When was it replaced first?
Old 10-29-2013, 09:49 PM   #723
Garstang
Garstang's Avatar
Drives: FRS
Don't waste you time.
Originally Posted by RFB View Post
After you wash the car - open the trunk and see where the suds collect at the base of the trunk lift piston housing.
Spray your back window and watch the water flow
There is a natural channel for water to continually assault the gasket.
I used snowman snot ( dollar store gooey gum for post it notes on fridge )
built a dam and water channel (placement is obvious) dribble water and modify the snot so the water flows away from the top of the gasket.
Instantly removable always pliable - re-usable.
So far so good for me - waiting for more severe temp and humidity changes for the long term test - will try to post pics soon.
:happy0180:
If I was you . I would go get a new one while you have warranty. Or you won't have any money to buy snot. When you don't have warranty to fall back on . Just saying.
Old 10-29-2013, 11:15 PM   #724
RFB
RFB's Avatar
Drives: FRS
Methinx u misunderstand
Get a garden hose and spray it on the center of your rear windshield full force then watch the full force water jet coming out over your tail lights.
Then open your trunk and press on the black plastic housing of your tail lights and see the gap. Thats where the water assails the gasket and eventually penetrates the gasket EVERY time it rains or you wash the car.
Then read my original post. (Yes I have had 2 warranty replacements, both that eventually leaked, including my new crystal eyes).
Since my snowman snot fix (99 cents) , extreme rain, extreme temperature changes and an extreme garden hose test - NO MORE CONDENSATION !
just sayin -
RFB is offline   Reply With Quote
Old 10-29-2013, 11:20 PM   #725
Garstang
Garstang's Avatar
Drives: FRS
Yup
just sayin -
Okay you are right I did not follow what you were saying. Know it makes sense to me.
Old 11-01-2013, 10:32 PM   #726
Perry
Drives: 86 Raven
All the problems of our cars (chirping, condensation, rear deck clunk ) should all be recall and replace all the problems.. don't wait for your costumers stop by the dealership and complain. They know all this shit. LOL TOYOTA SUBARU DO SOMETHING!!!
Perry is offline   Reply With Quote
Old 11-02-2013, 08:42 AM   #727
RFB
RFB's Avatar
Drives: FRS
They will fix
I'm sure that the cost to the corporation of replacing all those expensive tail lights will result in a fix .
Either a complex over engineered parts and body alteration , or they will steal my idea LOL !
Old 11-02-2013, 11:03 AM   #728
kodyo
Drives: Scion FR-S
They don't always replace the tails. Sometimes they just dry it out and replace the gasket.
kodyo is offline   Reply With Quote
Red tail light photoshops OwenK FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 68 02-06-2013 03:48 PM
HKS head and tail lamps DIG1992 Cosmetic Modification (Interior/Exterior/Lighting) 5 05-19-2012 01:04 PM
Tail of the Dragon Tomcat9700 Scion FR-S / Toyota 86 GT86 General Forum 32 02-10-2012 02:30 PM
headlight condensation MRZ415 Off-Topic Lounge [WARNING: NO POLITICS] 1 01-23-2012 02:24 AM
Optional coloured tail lights? m_life Scion FR-S / Toyota 86 GT86 General Forum 9 11-30-2011 06:20 PM
