Old 12-31-2018, 04:44 PM   #715
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
Originally Posted by Kiske View Post
So no revisions to the snout then, requiring the small amount of DIY grinding to clear the 2018's alternator plugs. :/
No grinding required. I have a kit on a 2018 TS already.
The Racers Line is offline   Reply With Quote
Old 12-31-2018, 06:12 PM   #716
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Any CARB goals for New Years Resolutions? @HarropOz @The Racers Line
Old 12-31-2018, 08:41 PM   #717
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
I had it and the Cosworth kit mixed up, sorry.
Old 01-14-2019, 12:25 AM   #718
Irace86.2.0
Apparently this won't be the year that I must smog my car. Now that the law has been changed from 6 years to 8 years, 2013 vehicles will need to smog their vehicles in 2021, except when transferring ownership and maybe other situations, I believe. This is good news, but I really hope they get a CARB tune for this car.
Old 02-10-2019, 09:26 PM   #719
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Are their no built harrop cars that aren't running the hks stroker kit? Low compression builds?
Old 02-10-2019, 09:39 PM   #720
ohmai18
ohmai18's Avatar
Drives: Subaru BRZ
Still no updates on CARB...sigh.
Sent from my Pixel 3 using Tapatalk
ohmai18 is offline   Reply With Quote
Old 02-22-2019, 01:45 AM   #721
Pizazu
Pizazu's Avatar
Drives: FRS Release Series 1.0
Late to post but thank you to Neal at @The Racers Line.
https://imgur.com/mlYVJ7U
Pizazu is offline   Reply With Quote
Old 03-31-2019, 08:07 PM   #722
ArCha
Drives: 2013 Subaru BRZ SWP
I recently did a couple pulls and I was a bit disappointed by the numbers, 259WHP and 207WTQ. 85mm pulley and ace 350 header only, everything else is stock. Tuned over the air by Zach at delicious. I will say this though the gains from stock 95mm pulley to 85mm pulley and header feel like you added the supercharger to stock again.
ArCha is offline   Reply With Quote
Old 04-02-2019, 03:13 PM   #723
Kodename47
Kodename47's Avatar
Drives: UK GT86
Those are good numbers if the rest of the exhaust system is stock IMO.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-03-2019, 08:24 AM   #724
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
on 91?
Old 04-03-2019, 07:06 PM   #725
ArCha
I was hoping for another 20
on 91?
Canadian 94 with up to 15% ethanol. Winter gas.
Old 04-03-2019, 07:15 PM   #726
Irace86.2.0
Those are normal numbers. The stock pulley is large. The 85mm is even larger than the Edelbrock kit’s stock pulley. 95mm to 85mm will have good gains but not as significant as the gains going from 95mm with E85 to 85mm with E85. Too bad Canadians don’t have access to E85.
Old 04-11-2019, 11:53 AM   #727
Irace86.2.0
I guess, maybe,
On another note, has anyone with a built motor pushed this kit with a higher boost pulley to say 20psi? If so then how did you handle first gear power or even second gear? I feel like sensitivity or modulation would be difficult with just the throttle, and of course there would be more power than what could be put to the ground. I know we have discussed using a boost controller to do boost by gear, but couldn't this be done easier via tuning. Someone could have different maps with a more aggressive map, but wouldn't it be easier to modulate the throttle via drive by wire. Couldn't someone program 1st gear to have say 50% throttle output for whatever is imputed, and 2nd could have 75% throttle output, and 3rd-6th could have 100%. Just something I was thinking about if I ever went with a built motor with a smaller pulley because 1st gear is already sensitive with an 85mm pulley.
Old 04-12-2019, 02:50 PM   #728
Kodename47
Kodename47's Avatar
Drives: UK GT86
.....but couldn't this be done easier via tuning. Someone could have different maps with a more aggressive map, but wouldn't it be easier to modulate the throttle via drive by wire. Couldn't someone program 1st gear to have say 50% throttle output for whatever is imputed, and 2nd could have 75% throttle output, and 3rd-6th could have 100%.
Yes you could do that.
.: Stealth 86 :.
Kodename 47 DJ:
JDL turbo kit owners thread yomny Forced Induction 1352 01-08-2025 04:20 AM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
Harrop car lip kit? djdnz Cosmetic Modification (Interior/Exterior/Lighting) 15 12-15-2015 02:50 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
