Old 08-29-2020, 02:05 AM   #72269
MICHAEL450f
Drives: 2018 BRZ
I actually prefer the 350. They are pretty solid. KTM really turned a corner and is a premier manufacturer.
Love to hear that!
MICHAEL450f is offline
Old 08-29-2020, 02:18 AM   #72270
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by MICHAEL450f View Post
Love to hear that!
I remember when the 350SXF came out. A lot of people mistook it for a big 250, when really it felt more like a light 450. It punches well above it's weight. The older LC4 based engines where kind of lackluster and old school with a lot of KTM quirks. After they came out with the SXF line of bikes with the new dual overhead cam design, which is still pretty trick by today standards, they improved a lot. Even the more modern version of the original LC4, like what is in my 690, is light years above their early designs.
NoHaveMSG is offline
The Following User Says Thank You to NoHaveMSG For This Useful Post:
MICHAEL450f (08-29-2020)
Old 08-29-2020, 11:10 PM   #72271
Special_K
Bannéd
Special_K's Avatar
Drives: 2013 DGM BRZ
If you haven't gone through the work to adjust your clutch height, you're a crazy person.
Also, turns out I've been a crazy person for years, and it took having to replace my clutch to finally bother.
Sent from my SM-N960U using Tapatalk
Special_K is offline
The Following User Says Thank You to Special_K For This Useful Post:
Spuds (08-29-2020)
Old 08-30-2020, 12:20 AM   #72272
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I have the most pathetic tomato patch this year. When we moved in, the garden area was neglected for several years, and overgrown with weeds and highly invasive sumac. It took us months of work, and gallons of heavy brush killer to clear it. When it came time to plant, I was suffering from health problems, so basically I did no garden prep, and we just stuck them in the ground. I think the soil needs a lot of work for next year. Plus I need to trim the nearby trees for more light.
@humfrz, what do you suggest for the soil?
On the other hand, my son loves carving pumpkins at Halloween, so we planted 6 plants against the back fence. We already have pumpkins taller than my knees. I count about 30 pumpkins. I have a feeling we will be giving a lot away to the neighbor kids.
Sapphireho is offline
The Following 4 Users Say Thank You to Sapphireho For This Useful Post:
humfrz (08-30-2020), Kiske (08-30-2020), soundman98 (08-30-2020), Spuds (08-30-2020)
Old 08-30-2020, 11:13 AM   #72273
ls1ac
ls1ac's Avatar
Putting peat moss is one of the best soil rejuvenators. Get a couple of bails and a tiller. Turn it into the ground about 3 to 4 inches. Not sure of your soil PH, have it tested and you can correct it for your garden.
Looks like you are in an arid area, so you could look at a product like "soil moist". It is a polymer that holds moisture and releases it slowly. Turn it into the ground in the area of your plantings.
Depending on what brush killer you used there may be some residual left. It could take a few years to totally clear. This could stunt growth.
ls1ac is offline
The Following 2 Users Say Thank You to ls1ac For This Useful Post:
Sapphireho (08-30-2020), soundman98 (08-30-2020)
Old 08-30-2020, 11:33 AM   #72274
JD001
JD001's Avatar
Drives: Subaru BRZ
You need to have a word with your neighbours as they're throwing old worn out shoes into your fabulous home veg garden.
JD001 is offline
Old 08-30-2020, 11:47 AM   #72275
Sapphireho
Famous Potatoes
Sapphireho's Avatar
That happens to be one of my favorite slippers. Ok, the "fur" on the inside is about gone, but still comphy.
The Following 3 Users Say Thank You to Sapphireho For This Useful Post:
humfrz (08-30-2020), JD001 (08-30-2020), soundman98 (08-30-2020)
Old 08-30-2020, 07:17 PM   #72276
humfrz
Before I start, what brush killer did you use?
humfrz is offline
Old 08-30-2020, 08:51 PM   #72277
Sapphireho
Famous Potatoes
Sapphireho's Avatar
humfrz (08-30-2020)
Old 08-30-2020, 10:23 PM   #72278
humfrz
OK, that's a good one.
You won't have a residual effect for following crops.
"Triclopyr breaks down in soil with a half-life of between 30 and 90 days. Triclopyr degrades rapidly in water. It remains active in decaying vegetation for about 3 months.[4]"
That stuff beats the hell out of the stuff I have sprayed to get rid of woody type weeds. You guessed it, it was 2,4,5-T (AKA, Agent Orange). Yep, sprayed a ton of it ..... and there ain't nutten wrong wif me -
humfrz is offline
Sapphireho (08-31-2020)
Old 08-30-2020, 10:25 PM   #72279
humfrz
OK, THAT explains the picture of your feet -
humfrz is offline
Old 08-31-2020, 05:20 AM   #72280
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
"Founded in Orange County, California, in 2008, Otto Aviation is an offshoot of Bill Otto’s Otto Laboratories. The aviation company claims that the plane can fly between 18 to 25 miles on a gallon of fuel compared to two to three miles in a similarly sized jet.
Owners of the Celera 500L will be able to fly the rear-engined plane for an operating cost of $328 per hour. This number is around six times lower than similar-sized aircraft. The Celera 500L also has a very generous 4,500 nautical mile range and can cruise at more than 460 miles per hour."
Meet The Celera
Captain Snooze is offline
The Following 6 Users Say Thank You to Captain Snooze For This Useful Post:
Dadhawk (08-31-2020), MICHAEL450f (09-04-2020), p1l0t (08-31-2020), soundman98 (08-31-2020), Spuds (08-31-2020), Ultramaroon (09-02-2020)
Old 08-31-2020, 06:08 AM   #72281
JD001
JD001's Avatar
Drives: Subaru BRZ
That's nice to hear, I can see that you like taking care of your "favourite slippers". BTW, just ordered a new pair as I have worn through my current slippers, WFH, I haven't worn "proper" work shoes in months...
BTW, you should tie little "tell tails" to the wire frames supporting your tomatoe plants, don't want anyone poking their eye out when picking the ripened fruit..
JD001 is offline
The Following 2 Users Say Thank You to JD001 For This Useful Post:
humfrz (08-31-2020), Sapphireho (08-31-2020)
Old 08-31-2020, 11:31 AM   #72282
humfrz
That's assuming there is any ripened fruit to pick -
humfrz is offline
JD001 (08-31-2020), soundman98 (08-31-2020)
