Old 05-15-2016, 02:13 PM   #7183
brianhj
Drives: 2017 Camaro 1SS
What should the elbow bolts be torqued to?
brianhj is offline   Reply With Quote
Old 05-15-2016, 08:17 PM   #7184
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
I'm not sure of the exact number. When I removed mine one of them broke on me. Just snug them up and it should be good.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 05-15-2016, 09:48 PM   #7185
brianhj
Which belt for pulley that comes with intercooler kit? I have three belts here, 1 stock and 2 Gates... Can't remember which is which
Sent from my LG-D851 using Tapatalk
Old 05-15-2016, 09:51 PM   #7186
brianhj
Nevermind I think it's the K061015
Old 05-16-2016, 07:40 AM   #7187
Dream20b
Y u do dis?
yep
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 05-17-2016, 12:53 AM   #7188
chargedup
Drives: SC BRZ
[ame="https://www.youtube.com/watch?v=hyvKroIYKg4"]Invidia n1 + Sprintex Supercharger Subaru BRZ - YouTube[/ame]
digging my n1 so far.. really loud though
chargedup is offline   Reply With Quote
Old 05-17-2016, 10:54 AM   #7189
CK_Bladesmith
Drives: Raven FR-S
Sounds like the sprintex 335 to me. Sounds good.
Old 05-18-2016, 02:34 PM   #7190
8686
8686's Avatar
Drives: 86
I got check engine light and the car rogh to drive. found that I got cel p0204 on cylender 4 which say injector circuit/open
Any idea what to do?
Sent from my 86 using Tapatalk
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 05-18-2016, 03:48 PM   #7191
Kodename47
Kodename47's Avatar
Drives: UK GT86
Check the connections to the injector? Then try swapping the injector if that fails.
.: Stealth 86 :.
Kodename 47 DJ:
Old 05-19-2016, 05:21 AM   #7192
chargedup
Drives: SC BRZ
I keep getting asked how much power I'm making (probably due to my CF hood) PO said car was on the 'base sprintex tune' and now has a perrin true CAI & invidia N1 catback. The car had a nameless catback previously but I'd been driving with stock exhaust with the Sprintex kit for a while. When I threw the N1 on it felt 15-20% quicker, at least throttle response wise. How much power do you think I'm making.
tl;dr 2 lazy 4 dyno how much hp
Old 05-19-2016, 07:21 AM   #7193
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
Probably not much more than 212. It's been said before: the most power to gain exhaust wise comes from removing the cats in the header.
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 05-19-2016, 11:47 AM   #7194
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
You might have 1-5hp more because of the intake until your car ecu learns it's there. The exhaust won't give you anything since it's post cat. The sound will trick you into think it's faster. Ideally you'd get the tune updated whenever you change the intake and if you remove/change the cats or pipe diameter. You may end up running too lean or rich which would not be good especially the lean version.
stockysnail is offline   Reply With Quote
Old 05-19-2016, 10:30 PM   #7195
brianhj
Just installed dual radium catch cans with petcock drain valves. I hear a wheezing sound when i step on the gas - am I hearing air rushing through the catch can on the drivers side?
I'm not used to having one there and I couldn't figure out where this sound was coming from
Old 05-20-2016, 12:18 AM   #7196
riboyster
riboyster's Avatar
Sounds reasonable to me.
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
