Old 08-01-2014, 10:30 AM   #701
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
I just installed my power blocks last night. Here is a picture of them installed with the Cusco Strut Brace. Also for anyone interested the GrimmSpeed Pulley Cover fits as well although it's physically touching the intake tube so I think I'm going to put someone between them so it doesn't wear over time.
So how long did it take you?
Jmonty is offline   Reply With Quote
Old 08-01-2014, 10:33 AM   #702
Luis_GT
I mounted my Fiebruz Intake spacers in about an hour by myself.
Old 08-01-2014, 10:56 AM   #703
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
I wasn't timing, but it probably took me about 3 hours. It would have been less if I hadn't dropped a couple of bolts and had to pull the under panel.
I see your posts a lot about the Fiebruz spacers, but no one seems to be able to find/buy them other then a link on their Facebook page. It doesn't seem they are for sale to the general public yet.
As for installing them in an hour, it may be possible, but for anyone trying this for the first time I wouldn't plan on it. It's it's a tricky install, take your time.
Old 08-01-2014, 12:36 PM   #704
Jmonty
that is the plan taking my time and getting it right, did you reset the battery after installing?
Old 08-01-2014, 03:12 PM   #705
neutron256
neutron256's Avatar
Yep first thing I did when I started working was disconnect the battery. Really a good idea when doing any work in the engine bay.
Old 08-01-2014, 09:56 PM   #706
Jmonty
I had a hard time lifting everything... from driver side what a PITA, we had to disconnect a few more wire to be able to fit it. passenger side was a piece of cake but, I didn't seem to need the new tube or even the zip-tie? everything was nice and tight.
I disconnected the negative battery not sure the ECU reset? I loved the way it drove on the side streets, then a 60 mile trip back to my house mostly freeway. Driving up my hill check engine & traction control light pop on
Old 08-01-2014, 10:26 PM   #707
neutron256
neutron256's Avatar
Yeah I had the same problem with the drivers side.
Are you running any kind of a tune? I haven't had any problems but I'm running OFT Stage 1 tune. They don't have an off the shelf tune for powerblocks on an automatic.
Old 08-01-2014, 10:42 PM   #708
Jmonty
yes I'm running a custom tune on BRZedit
plan is to get a retune after I intall the Raceseng S2 pully kit when it arrives
Old 08-01-2014, 11:11 PM   #709
Luis_GT
You have to call them, in fact I was there today and they had 2 in stock... As for installing them in an hour... if you have basic mehcanical knowledge its possible... I had never done such a mod before. I just followed the crawford BPB install someone did on youtube.
There's a guy in australia that has them already
Old 08-02-2014, 07:16 AM   #710
Hawk77FT
Drives: GTS 86
Did you guys used the gasket between the intake manifold and the intake blocks?
Hawk77FT is offline   Reply With Quote
Old 08-02-2014, 07:20 AM   #711
Hawk77FT
Drives: GTS 86
I did install them in about an hour. I can do it now in about 25 .
Did you leave the gasket between intake manifold and the blocks?
Old 08-02-2014, 12:14 PM   #712
Luis_GT
Yes, you have to, otherwhise it'll have an air leak.
Old 08-03-2014, 08:04 PM   #713
Jmonty
Update install I let one of the gaskets pop out on the Power block and didn't notice until I got home and let the motor cool, of course it is on the drivers side.
well it took just over 2 hours for the first install let's hope I can get it down to about an hour for the reinstall
Old 08-04-2014, 12:57 PM   #714
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Hello everyone. I have a Greddy intake, which has a hard plastic intake tube. How bad is the intake going to fit with the increase height of the intake tube?
Thanks in advance!
OFT Remote, OFH, Motiv OP & FP, Perrin 3' CB & 3' IT, Setrab/MoCal cooler, STI motor mounts, Wilwood 6/4 plot F&R 12.8 kits, Brake ducts, complete Whiteline catalog, complete bushing replacement, OSGiken clutch & Diff, 4.556 FD, Stance W/Spec valving 8/9 Swift.
TouchMyHonda is offline   Reply With Quote
billet, crawford, magic blocks
Crawford Performance Turbo BRZ! Balance Meets Power - Ignition Episode 71 ZetaVI BRZ Photos, Videos, Wallpapers, Gallery Forum 22 04-01-2014 05:19 PM
short blocks? 350matt Engine, Exhaust, Transmission 4 11-04-2013 08:37 PM
Billet Oil Catch Can #BC-175 by Billet Custom Tim_Asphalt_FRS Engine, Exhaust, Transmission 48 10-27-2013 02:29 PM
***Blitz Advance Power Air Cleaner and SUS Power Core Intakes*** FT-86 SpeedFactory Engine, Exhaust, Transmission 1 10-07-2013 09:40 PM
