Old 02-01-2014, 02:01 PM   #701
TRD_07
TRD_07's Avatar
Drives: Firestorm 6MT
Originally Posted by FullBlown View Post
Hi Mike, Ryan and I spoke on the phone and both agree that replacing the upper brackets is best way to free up some room.
We are going to machine new brackets and overnight them to you.
We will also be supplying these brackets with every kit from now on.
Anyone who has our kit that wants the these brackets, please contact us and we will send them out free of charge.
What about for those of us who don't have fbm turbo kit but purchased the radiator? Will the brakets be available for purchase and/or can they be provided? Thanks and great thinking in doing these for the extra space!
TRD_07 is offline   Reply With Quote
Old 02-01-2014, 02:11 PM   #702
shiro
shiro's Avatar
Drives: 2013 Scion FR-S, 2014 Lexus IS350
You only now noticed. It has been over 2 months now. I might get back into a new one if they make any big changes.
Honestly, you did a good move until Toyota and Subaru decide to make some changes and updates/upgrades. It get's pretty costly when having to put in aftermarket parts to keep the car from failing haha. But hands down, the car is fun and looks pretty nice.
But I'm sure you'll jump on one of the newer ones when they work all the bugs out.
shiro is offline   Reply With Quote
Old 02-01-2014, 02:23 PM   #703
FullBlown
FullBlown's Avatar
Drives: Scion FRS
They will be available for purchase
FullBlown is offline   Reply With Quote
Old 02-01-2014, 04:54 PM   #704
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
Originally Posted by mike the snake View Post
I've read, and found a link somewhere, where someone installed those clamps without removing the manifold by removing the AC compressor.
Seems to me it would be a lot easier to undo the AC compressor than to remove the entire manifold.
I've asked my shop/tuner many, many times to install these clamps on the vacum lines. Not sure yet if they've done it yet though.
I didnt remove anything to put silicone on the nipple end. I have thick fingers and found it easy once I positioned myself on the passenger side headlight area.
you could use a stronger adhesive, but for most people, a little dabble of silicone will easily hold the pressure.
Deadspool is offline   Reply With Quote
Old 02-01-2014, 06:32 PM   #705
mike the snake
Were you able to do this without removing anything?
I'd be willing to try that if it meant not having to remove (or pay to remove) anything.
Old 02-01-2014, 06:41 PM   #706
Dipstik-sportech
Dipstik-sportech's Avatar
I blew that hose off and as soon as I crossed back into canadia the pcv hose popped off as well.
The Frozen North
Old 02-01-2014, 07:15 PM   #707
Deadspool
Much title. Wow.
Deadspool's Avatar
The Frozen North
No luck at all mate.
Old 02-01-2014, 07:26 PM   #708
Dipstik-sportech
Damn Canadia luck lol. Clamped it and it's gtg
The Frozen North
Old 02-01-2014, 07:42 PM   #709
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
I think you need to get back into one. You're on here more than most
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 02-02-2014, 03:20 PM   #710
Deadspool
Much title. Wow.
Deadspool's Avatar
I'm having difficulty activating the auto-blip. I know the map is correct.
It's not make or break, would sure like to see its function in person though.
Old 02-02-2014, 04:31 PM   #711
toekneehair
toekneehair's Avatar
Drives: 2013 Subaru BRZ/FBM turbo flexfuel
when I was on the dyno we popped off the same tubing under the manifold. It took us a few minutes to figure out where the leak was. It is definitely a pain that is for sure. We got a zip tie around it after getting it back on and we were able to pull the zip tie tight from the small hole that is on the side where the inlet tubes V off before attaching to the block.
toekneehair is offline   Reply With Quote
Old 02-02-2014, 05:14 PM   #712
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
Hey all, installed my stage 2 FB kit last weekend. I'm in hot Florida though and I'm having major cooling issues.
It seems like the non-brand slimline fans included with the premium install kit are a bit weak for 100+ degree temps. For what it's worth.
I will have an update for my build thread soon with details and thoughts on the kit, overall very impressed with the quality and customer service, LJ's been great.
Ironsquid is offline   Reply With Quote
Old 02-02-2014, 09:30 PM   #713
pmccut
Drives: Blue Subarus
Not surprising. Mine over-heated at stop lights with stock radiator in 80F last summer. Their radiator makes a big difference but isn't a cure-all either. If you haven't already you should read http://www.ft86club.com/forums/showthread.php?t=53580
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
Old 02-02-2014, 09:42 PM   #714
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Going to go with their Radiator and Shroud kit and SPAL fans, then remove the mishimoto oil cooler and opt for the FB one.
This should relocate the hot air from the oil cooler to the side fender area instead of flowing onto the IC and Rad.
My downpipe is heat coated AND wrapped, and the turbo is blanketed.
With the new rad and shroud I think that might do it, if not I might try a new racing thermostat.
If that doesn't work, I might try to engineer some air excavation for the bay, I already have a vented hood.
Thanks for the link though
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
