Old 06-20-2020, 03:35 PM   #71065
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Oh that would be very problematic for me.
You say that like there is a discrepancy in the counts
NoHaveMSG is online now
Old 06-20-2020, 03:53 PM   #71066
humfrz
Originally Posted by EAGLE5 View Post
Ginger was hotter. Significantly so.
humfrz is offline
Old 06-20-2020, 03:53 PM   #71067
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
yyyyyyeeeeaaahhhhhh, NO!
IceFyre13th is offline
Old 06-20-2020, 11:44 PM   #71068
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I guess the island had a gal for all tastes, even humfrz'.
Sapphireho is offline
Old 06-21-2020, 12:08 AM   #71069
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Not sure how, but I’m going to call this assembly error by me. Kicked out both rocker arms on the intake side of number two cylinder. Explains the oil pressure drop too from the lifters popping out of the oil galley.
Old 06-21-2020, 01:16 AM   #71070
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Finished up grinding the knife. Now just need to finish few small things THEN I can do heat temper & treat. After that, just glue em together & DONE! But that won’t be for another few wks.
ichitaka05 is offline
Old 06-21-2020, 01:18 AM   #71071
humfrz
Well, excuse the hell out of me for being attracted to the more mature women with more class -
humfrz is offline
Old 06-21-2020, 01:57 AM   #71072
humfrz
Well, don't feel bad, sometimes assembly shit happens.
I recall the first large engine I overhauled at age 14. Our oldest Oliver tractor was burning a lot of oil and had lost power. My grandfather said it needed new rings and a valve job. I asked him if I could do that and he said OK.
Now, keep in mind I didn't have a manual nor a shop manual. So, I tore into that puppy, being careful to place the pieces I took off in order along the shelves in the barn.
Welp, I got it apart, took the head into the machine shop/parts dealer in town to have the valves ground. I purchased a gasket set and a set of rings and rod bearings. When I was trying to put the pistons back in with the new rings my father showed me a trick, using a cut open tin can and a large hose clamp. That's after he scolded me for "spending too much of his money on that old tractor".
OK, so far so good, so I thought. Oh yes, my grandfather did insist that he torque the head bolts down. When I asked him how tight they should be, he replied, "head bolt tight, using a 1/2" drive socket and a medium sized breaker bar".
I buttoned that puppy up and dumped some oil in it. Ready to fire it up. However, that puppy wouldn't crank - literally wouldn't crank (it was a crank start tractor). I thought that I wasn't strong enough so I asked my grandfather to try. He pushed down on the crank and told me that the engine was froze up.
He then asked me if I had shimmed the rod bearings. He could tell from the look on my face that I didn't know what he was talking about. So he explained to me about the purpose of those skinny little washers between the rod caps and the rods.
So, since it was time for a trip to town, we stopped in at the machine shop/ parts supply store and he had the parts man show me how to use that plastic string and gauge to properly shim and space the new rod bearings.
So, after doing that, that puppy fired right up an ran good for several years. That was our go-to tractor when anything got stuck in muddy fields (check out those wheels).
THE END
humfrz is offline
Old 06-21-2020, 02:11 AM   #71073
MICHAEL450f
Drives: 2018 BRZ
[QUOTE=NoHaveMSG;3342778]Not sure how, but I’m going to call this assembly error by me. Kicked out both rocker arms on the intake side of number two cylinder. Explains the oil pressure drop too from the lifters popping out of the oil galley.
The first time I rebuilt a 2 stroke dirtbike I forgot a tiny woodruff key and the thing was trying to run backwards. It happens. I now build turbine engines but with all the regulations they make it almost impossible to mess that up and we still get a lot of test rejects.
MICHAEL450f is offline
Old 06-21-2020, 06:50 PM   #71074
soundman98
ProCrastinationConsultant
soundman98's Avatar
if it makes you feel any better, this weekend the rich deuchebro on the local lake sunk somewhere between half-a-million to 1 million dollars worth of vehicles.
his $250k-300k boat started sinking, so he drove his brand new jeep wrangler 4-door(seeing claims it was hellcat swapped), and a brand new ford raptor into the water to try to tow it out. everything sank.
his daddy will have new one's ordered up by monday afternoon...
https://www.reddit.com/r/IdiotsInCar...ng_to_get_his/
soundman98 is offline
Old 06-21-2020, 07:32 PM   #71075
Gotta love he at least 30 year old boat and motor valued at about $2000 that is trying to help and still afloat
Tcoat is offline
Old 06-21-2020, 07:39 PM   #71076
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I got an info-card for Father's Day from my youngest. Good to know.
Old 06-22-2020, 11:15 AM   #71077
p1l0t
p1l0t's Avatar
Ouch. Hopefully this isn't your daily.
p1l0t is offline
Old 06-22-2020, 11:27 AM   #71078
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Kinda. I split my time in thirds between the car, the SUV, and the motorcycle.
