Old 05-26-2020, 11:34 PM   #70323
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
1/8 inch and whatnot.
Saw 13" riveter and going "Whaa .."
So, rocket bunny then ...
bcj is offline
The Following 2 Users Say Thank You to bcj For This Useful Post:
NoHaveMSG (05-26-2020), Ultramaroon (05-26-2020)
Old 05-26-2020, 11:42 PM   #70324
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Airplane kit actually so really plane parts. The Outer wings are the parts you see. The inner wing runs under the fuselage and is what the outer wings connect to.
In the view below the inner and outer wing join where the extra ribs (6-V1-2) are on the mid-left. The extra ribs make up the wing walk. The part that appears flat is the inner wing, the angled up portion is the outer wing.
Are you going to bolt one of those to your car like I did?
NoHaveMSG is offline
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
Dadhawk (05-27-2020), humfrz (05-27-2020), Tcoat (05-27-2020)
Old 05-26-2020, 11:46 PM   #70325
Ultramaroon
not playing cards
Ultramaroon's Avatar
Don't say "bolt on" with that drawing! Ho will lose his shit.
Ultramaroon is offline
NoHaveMSG (05-26-2020), Spuds (05-27-2020), Tcoat (05-27-2020)
Old 05-26-2020, 11:47 PM   #70326
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Whoops. Too late.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
bcj (05-26-2020), Ultramaroon (05-26-2020)
Old 05-27-2020, 12:04 AM   #70327
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Sapphireho is offline
NoHaveMSG (05-27-2020), Ultramaroon (05-27-2020)
Old 05-27-2020, 12:17 AM   #70328
p1l0t
p1l0t's Avatar
really?
Kenan is the best.
p1l0t is offline
humfrz (05-27-2020)
Old 05-27-2020, 07:30 AM   #70329
..might be a redneck.
"Is or is not, there is no might.", Yoder...
I Is.
Dadhawk is offline
Sapphireho (05-27-2020), soundman98 (05-27-2020)
Old 05-27-2020, 07:34 AM   #70330
How big is this wing?
The outer wings are @10ft long and 18" thick, it will easily fit out a normal door. All the subassemblies except the fuselage could be finished in the basement and moved. The fuselage would have to be built in my hanger.
Technically, I could get the fuselage out as well, but it would require removing a double window and a wall that is framed for a french door but is closed with sheetrock.
Dadhawk is offline
humfrz (05-27-2020), soundman98 (05-27-2020)
Old 05-27-2020, 07:36 AM   #70331
No it's too wide for the street. I'd recommend the elevator, vertical rudder is optional.
Dadhawk is offline
NoHaveMSG (05-27-2020), p1l0t (05-27-2020), soundman98 (05-27-2020)
Old 05-27-2020, 01:29 PM   #70332
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Work thought it was a good idea to update the system middle of the week... so I can't work til it finishes. Got time to waste, so looking at wire connectors.
Any good wire connector that can be plug in and out. Using it for front bumper, so if/when I take it off the front bumper, I can dislocated it without an issue. Was looking into these style, but was feel not clean.
It's only 2 pin, so was looking into these style as well... but concern of weather/water
ichitaka05 is offline
Old 05-27-2020, 01:46 PM   #70333
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I prefer the spade connectors, then a dab of dialectic grease to help them out. Adhesive lined heat shrink to keep water out of the backside of the connector.
ichitaka05 (05-27-2020), soundman98 (05-27-2020)
Old 05-27-2020, 01:50 PM   #70334
Can't beat these. I use them in my boat.
https://store.valueaccessories.net/2...ectorPlug.aspx
Tcoat is offline
Opie (05-27-2020), soundman98 (05-27-2020)
Old 05-27-2020, 01:54 PM   #70335
ichitaka05
Site Moderator
ichitaka05's Avatar
Thanks!
In the boat? Then def itll be waterproof rough for my car!
Tcoat (05-27-2020)
Old 05-27-2020, 02:06 PM   #70336
I used these when I upgraded the headlights on my Suburban. Worked very well.
Dadhawk is offline
Tcoat (05-27-2020)
