Old 05-26-2020, 06:29 PM   #70295
humfrz
It's my understanding that an expansion tank on a hot water heater can serve one or both of these purposes. It will take up the excess water (pressure) on the hot water plumbing system as the water is heated and expands and act to relieve pressure on systems that have a backflow check valve to prevent water from backing up into the main water source.
Wiki told me that.
humfrz is offline
Old 05-26-2020, 06:35 PM   #70296
humfrz
expansion tanks are hit-or-miss around my area. .
Yes, as they are in parts of Idaho -
humfrz is offline
soundman98 (05-26-2020)
Old 05-26-2020, 06:46 PM   #70297
Tapatalk, you’re drunk
It does that all the time on notifications for some reason.
The take over is working soon the internet shall be MINE
Tcoat is offline
NoHaveMSG (05-26-2020), soundman98 (05-26-2020), Spuds (05-26-2020), Ultramaroon (05-26-2020)
Old 05-26-2020, 07:04 PM   #70298
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I got the new backup light switch today. Just to make sure, I plugged it into the car and operated the switch by hand. Yep, turns on and off fine.
So I'll probably be without backup lights for a while. That switch looks real tough to get to.
Sapphireho is offline
Old 05-26-2020, 07:13 PM   #70299
Give it Ultra he can put it to use on his ca...
Oh nevermind.
Tcoat is offline
Old 05-26-2020, 07:57 PM   #70300
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Bought rivet tool. I needed for future mods, so it’ll be interesting to see how it turns out. Need to test em out on few thing, so I won’t mess it up on actual thing I wanna do.
ichitaka05 is offline
humfrz (05-26-2020)
Old 05-26-2020, 08:14 PM   #70301
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Completely worth it. I have a pretty good sized one too.
NoHaveMSG is offline
The Following User Says Thank You to NoHaveMSG For This Useful Post:
ichitaka05 (05-26-2020)
Old 05-26-2020, 08:18 PM   #70302
Go buy a bunch of QUALITY 1/8" drill bits. I mean a bunch! If using larger it isn't so bad but still get good ones.
Practice, practice, practice.
Pop riveting is more of an art form that a mechanical action.
Tcoat is offline
ichitaka05 (05-26-2020), Ultramaroon (05-26-2020)
Old 05-26-2020, 08:23 PM   #70303
Tcoat is offline
Old 05-26-2020, 08:31 PM   #70304
humfrz
Well, those would be better to hold that new under panel on - rather that tape -
humfrz is offline
Old 05-26-2020, 08:32 PM   #70305
I love riveting metal together...
the underside of the outer wing of the airplane in my basement waiting for me to pop some domed rivets...
Dadhawk is offline
The Following 5 Users Say Thank You to Dadhawk For This Useful Post:
humfrz (05-26-2020), NoHaveMSG (05-26-2020), soundman98 (05-26-2020), Spuds (05-26-2020), Ultramaroon (05-26-2020)
Old 05-26-2020, 08:34 PM   #70306
ichitaka05
Site Moderator
ichitaka05's Avatar
I wanted bigger size too... but I have to make it rivet in a very awkward area, so didn't want it too big.
Why do I need 1/8" drill bits?
Also yeah, my plan to practice much as I can. I'm planning to make most of em in M6. It came with few rivets, so using that to get used to it.
What? Tape doesn't hold under panel enough? lol
humfrz (05-26-2020)
Old 05-26-2020, 08:35 PM   #70307
YIKES! I'd be tempted to cut the wire to that seat heater, before it burnt up your vehicle -
I've disconnected the wire harness under the seat for now. Apparently the heating elements are a known issue and as they burn out they cause grounding and some other odd effects. Going to see if that kills it, and if it does it will stay unplugged. I never use it anyway.
Dadhawk is offline
humfrz (05-26-2020)
Old 05-26-2020, 08:37 PM   #70308
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I’m not trying to compensate or anything but ....
The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post:
bcj (05-27-2020), soundman98 (05-26-2020), Tcoat (05-26-2020), Ultramaroon (05-26-2020)
