Old 01-26-2021, 11:06 PM   #687
Atmo
Drives: TBA
My main home defense weapon is a short barreled shotgun, and the first round is bird shot. If that doesn't get their attention, the next 7 rounds are buckshot.
You have to shoot. If you don't know how to use your weapon without thinking about it, you won't know how when the shit hits the fan and you are scared and your blood turns to pure adrenaline.
For homeless bums, I would get a bat and a big can of pepper spray to keep near the door.
Same here but my short barrel option Remington 870 pump first round is 00 buckshot alternated with slugs with muzzle energy equivalent to a loaded 18-wheeler.
If that doesn't slow the zombies down, it should allow enough time to get to the HK 45 ACP Compact (my legal carry weapon because the holster clears the seat belt latch) in the front of the house or my favorite Browning High Power 9 in the back.
I don't have a baseball bat but have several tennis racquets except those don't count.
Atmo is offline   Reply With Quote
Old 01-27-2021, 12:23 AM   #688
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by NWFRS View Post
Spencer model of 1882.
One of the first successful pump-shotguns. Sadly, I picked this one up with a shattered wrist. I pieced it back together as best I could, with wood glue, walnut sanding dust, and dye, and filled a void in the toe. It’s only a cosmetic fix, but I’m honestly not interested in shooting it anyway. I think it would require finding reloadable brass of the correct dimension and then hand-loading them with black powder. I’ve had it apart, and it’s very interesting mechanically, with a heavy pivoting breech block powered by a forged leaf spring that throws empties straight out the top.
https://en.m.wikipedia.org/wiki/Chri...Post-Civil_War
https://www.historicalfirearms.info/...slide-or/embed
What part is the shattered wrist?
NWFRS (01-27-2021)
Old 01-27-2021, 12:58 AM   #689
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
The wrist of the stock, where it connects to the tang of the receiver. A lot of old shotguns tended to have that exaggerated “head-up” shooting position, and the wrists were often thin. If the wood was highly figured through the wrist or if the grain was running the wrong way they could break. Mine had shattered a long time ago, and a pre-war style repair was done using a few brass nails, a wire wrap, and water-shrunk leather. It looked like the gun had remained in use after the repair, but by the time I ran across it, it had begun to fall apart and the action was so gummed-up it would barely cycle. I decided to take it all to bits and clean it. The wrist of the stock was in about five pieces. I managed a passable cosmetic repair but it will never be strong enough to shoot. It really just needs a new stock. I have a blank that I may attempt to make a new stock from someday, if I get really motivated.
NWFRS is offline   Reply With Quote
The Following User Says Thank You to NWFRS For This Useful Post:
soundman98 (01-27-2021)
Old 01-27-2021, 09:40 AM   #690
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Lol. I turned my 870 into home defense after I got my super black eagle. Best duck gun ever.
NWFRS (01-27-2021)
Old 02-02-2021, 04:00 PM   #691
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
1905 S.M.L.E.
Short Magazine Lee Enfield, made at Enfield, England, in 1905. I think this example is known as a No.1 Mk.1, with additional updates performed, I think, in 1914. It’s marked I***. I believe some of the updates had to do with new ammunition types that had recently become available. I’ve never shot it and I’m not 100% positive if I can safely run modern ammunition through it despite the updates. I owned it about ten years before making the decision to take it to bits and clean it. It’s possible that it hadn’t been taken completely apart since it’s last round of updates. There was quite a lot of caked dirt and cosmoline under the stocks, together with some superficial surface rust. I really wish I knew more about these rifles and where this one might have seen service. The floating charger guide is one of the strangest features of this generation.
The Following 3 Users Say Thank You to NWFRS For This Useful Post:
humfrz (02-03-2021), NoHaveMSG (02-03-2021), soundman98 (02-02-2021)
Old 02-03-2021, 01:16 AM   #692
humfrz
1905 S.M.L.E.
Is that a bayonet or a sword? -
NWFRS (02-03-2021), Spuds (02-03-2021)
Old 02-03-2021, 01:25 AM   #693
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
Right?!
British military doctrine over the years was so strange. I couldn’t say what was going through their heads at any given time. They took interesting lessons away from each conflict. I think this is a 1907 pattern bayonet. It came with my rifle, but I have no way of knowing how long they’ve been together.
https://en.m.wikipedia.org/wiki/Pattern_1907_bayonet
humfrz (02-03-2021)
Old 02-03-2021, 01:44 AM   #694
humfrz
Right?!
With that stuck on the end of the rifle, in trench warfare, I could see where the added "reach" would have an advantage -
PS - I just read your attachment after I posted - . Interesting.
NWFRS (02-03-2021)
Old 02-03-2021, 02:06 AM   #695
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
That makes sense. I bet you’re right.
I’ve never really done any research on them. Maybe it was designed to compensate for that controversial 25” barrel length. I’m pretty sure I would have been shot by my own side for being a coward and refusing to go “over the top”. I can’t even imagine.....
humfrz (02-03-2021)
Old 02-03-2021, 03:09 AM   #696
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
best time i ever had at the range was watching a big burly tough guy that's never shot before walk up to the line with his brand new 45, lines up down range, fires, and screams as the gun jumps out of his hands.
My father-in-law used to be in the army, part of a security detail. He is retired now but still enters into some shooting competitions. I have no idea what the type of competition is called but there are structures and targets. One moves from one station to another and there is (I think) a combination of accuracy and time taken involved.
He turns up with some shitty decrepit pistol that might have cost a few hundred dollars that he has fixed up and he will whip all these clowns who turn up with their flash "I've got all the gear".
The Following 3 Users Say Thank You to Captain Snooze For This Useful Post:
NoHaveMSG (02-03-2021), NWFRS (02-03-2021), soundman98 (02-04-2021)
Old 02-03-2021, 09:21 AM   #697
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
I am legitimately blown away by what some people can do with open sights. Rifles and pistols both.
Old 02-03-2021, 09:33 AM   #698
My Father was a good shot, had been shooting since he was big enough to carry a gun.
He used to go to Turkey Shoots and would always use the house gun, which was typically the cheapest, most broken shotgun available in the county.
He won about 70% of the time he shot.
humfrz (02-03-2021), soundman98 (02-04-2021)
Old 02-03-2021, 10:50 AM   #699
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Ian from the Forgotten Weapons YouTube channel does that. He will show up with either an oddball, or a historic firearm and use it. A few of the video openings will show a group of people around his gun case wondering WTF he brought. There is video of him using a chauchat lmg during a match that is pretty amusing because of how comically clumsy it is.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
NWFRS (02-03-2021)
Old 02-03-2021, 11:42 AM   #700
Sapphireho
Famous Potatoes
Sapphireho's Avatar
My oldest son was a high level Army sniper, two tours. He can kill you from a mile away. He came home in one piece, so I guess he won.
The Following 5 Users Say Thank You to Sapphireho For This Useful Post:
Dadhawk (02-03-2021), humfrz (02-03-2021), NWFRS (02-03-2021), soundman98 (02-04-2021), Stephen W. (02-03-2021)
No Politics or Religion discussions please Hachiroku Off-Topic Lounge [WARNING: NO POLITICS] 1 01-07-2021 12:50 PM
Product Showcase - Auto Finesse Tripple - All In One DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 11-16-2012 04:28 PM
Product Showcase: Menzerna Fast Gloss 400 DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 11-16-2012 09:14 AM
FR-S vs. 370z, end all be all of discussions OldSkoolToys FR-S / BRZ vs.... 1491 09-25-2012 06:58 PM
Are politics off limits? Longhorn248 Site Announcements / Questions / Issues 35 05-16-2012 10:24 PM
