#687 |
Hot Dog
Drives: quicker than arghx7
I might as well add this from my short time with the BRZ earlier this week. The O2 sensors are 4-wire heated narrow-band. Are there any other GDI cars that use narrow-band? Perhaps I'm too used to GDI + turbo having WBO2 these days. It's not the end of the world, I'm just a bit disappointed....it definitely shows the low-cost nature of the car.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products. |
#688 |
Drives: '06 AM V8V Coupe
^ darn, that sucks
From what I've read, wideband and narrowband operate quite differently, so is it difficult to switch in a wideband and have the ECU cooperate?
#689 |
Hot Dog
No dice. Narrowband are 0-1V signals that oscillate around 0.5V, and wideband O2 sensors produce a 0-5V linear-relationship signal. Not compatible whatsoever.
![]() ![]() What this means is the car will run open-loop at WOT, which isn't a bad thing [cars have been doing it forever], but not super-precise like closed-loop WBO2 100% of the time.
#690 |
Okay this is kinda random and stupid but I went on Wolfram Alpha and found that somewhere between a rod:stroke ratio of \sqrt{14.3}/2 and \sqrt{14.4}/2 (this is about 1.89ish) the acceleration at BDC does not have that little "lump" (acceleration has only 1 local min/max around there). If I had Mathematica still installed I could've had it solve in general form but oh well. Fun fact!
#691 | |
Drives: Attitude
#692 |
Drives: SSM LT MT BRZ
There is lots of good content out there regarding the rod stroke ratio. I find serialk11ler's response to clearly define what I know about Rod:stroke, longer rods allow for slower acceleration away from TDC at the beginning of the intake stroke, reducing load on Small end of rod, and allowing more time for peak pressure to build as the piston starts to travel down the bore on the power stroke, there is a slight increase of maximum piston velocity (increasing friction) at mid stroke, but it is momentary and only requires consideration if you are already pushing the 5000 in/min speed that is usually referenced as the max desirable.
#693 | |
The Mechanic
Drives: Civic Turbo,FR-S
#694 |
Not really, they're very different. Honda has both a system that will vary the cam timing, and 2 lift profiles to improve volumetric efficiency across a large range of rpm, which this lacks. The "VTEC kicked in yo" is not because of a cam advance, but because the engine switches to a long duration cam lobe that is meant for maximum power. The low duration cam lobe could make more power if they wanted it to, but they kept it mild to presumably reduce emissions and fuel consumption.
#695 | ||
Drives: 4 Wheels Auto
If you said your observation or measurement of such the piston motion over time is quasi-sine wave, I have no problem with it. A mistake is a mistake.
#696 |
Whatever, I said quasi- simple harmonic. Sure, sinusoidal is the wrong term. You get the point. It's obvious that the piston is limited to travel in 1 direction, and normal people associate "sinusoidal" with "simple harmonic". Fancy terms? Not really... jesus.
#697 | ||
Oh Boy, Why do I have to do this again....
#698 |
There's nothing wrong with what I wrote, the vertical distance between the circles is going to be the distance that the piston moves since you're just translating the circle up by that amount. Anyways, it seems like you get what's going on, so what's the problem? Why do you keep trying to point out things that I did "wrong" that are either just nitpicking at word choice or not wrong at all? Longer rod with the same stroke gives lower peak acceleration...this is pretty obvious.
And I already said many times, sinusoidal means simple harmonic, I don't know why you keep trying to argue that I'm oh so wrong because the piston is clearly limited in travel by the bore. I know that, and so should everyone else, it's OBVIOUS. The reason why I brought in the tangent circle drawing was it's an easy way to visualize the differences. A lower rod length reduces the speed of the piston around the bottom of the stroke, and increases it around the top. That's just the easiest way to understand the difference for me, so I shared it. By the way, "circle" , "radius", "perpendicular", "tangent" etc. are not fancy words. They are basic geometry terms. Last edited by serialk11r; 03-09-2012 at 02:42 AM. |
#699 |
Anyways back to your original question, what are the benefits. Newton's 3rd law says there's a reaction force to whatever force is going through the rod, and the rod ends are free bearings so there is no torque along the rod, thus the sideloading force is determined by the rod angle and the piston's net force (it's the tangent of the angle times the net piston force). Since the tangent is increasing along the relevant interval, the sideloading force at any crank position besides 0 and 180 is greater because the rod angle is greater.
The other thing would be that since the piston is travelling slower at TDC, the pressure increase wrt crank angle is greater, and you have a higher peak cylinder pressure. As the engine speed increases, the charge has less and less time to burn. I suspect this is the main reason for going with a longer rod, as a minor change in rod ratio doesn't actually change peak forces that much. Anyways, lower friction is good, higher peak pressure is good. |
#700 |
Kuruma Otaku
Factory cars are coming with widebands these days?
Because titanium. |
| Joke Thread | VenomRush | Off-Topic Lounge [WARNING: NO POLITICS] | 27 | 07-09-2011 01:44 AM |
| The Music Thread | aliphian | Off-Topic Lounge [WARNING: NO POLITICS] | 13 | 03-28-2011 12:35 PM |
| engine swap thread | aspera | Engine Swaps | 231 | 03-15-2011 06:10 PM |
| FT-86 to debut new GPS-track day technology for use on track and GT5! | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 01-30-2010 12:30 PM |
| Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 11:59 PM |
