Old 06-03-2016, 07:57 PM   #57
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Video from the Lincoln ProYolo is up.
[ame]http://www.youtube.com/watch?v=QxVNO-N1Kcw[/ame]
justinco is offline   Reply With Quote
The Following 2 Users Say Thank You to justinco For This Useful Post:
DocWalt (06-05-2016), Racecomp Engineering (06-04-2016)
Old 06-13-2016, 10:52 PM   #58
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Ooops, I forgot to post up the results from the Springs Nats Champ Tour! Car was working better for that event after making some suspension changes after the ProSolo on the Lincoln test course. Mostly happy with how the car is working out there, now I just need more seat time to become more consistent and get to that next level that the really fast guys are on.
[ame]http://www.youtube.com/watch?v=0n2Hfnx4W28[/ame]
DocWalt (06-14-2016), Silverspeed (06-14-2016)
Old 06-29-2016, 12:00 AM   #59
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Been lazy with updates on local events. We had our series event #3 a weekend or so ago, ended up 2nd place to Mr. Santel as he edged me by 2 tenths on our best runs. He did put down a crazy time on his last run out (we got 5), but unfortunately grabbed a cone. That would have been .6 seconds quicker than my best coned run (cones that could have easily been avoided for both of us).
I'm getting more comfortable with the car and it is working well, minus a little corner exit push if I don't setup the entry correctly (fixable). I am working on getting the rear to rotate quicker when I shift weight to the front (either by brake or lift). Right now the rear sticks pretty well and it is hard to slide it when I want, I had the same "issue" with my e36 STX car. Hard part is getting it to do that and also be stable/grippy in high speed transitions and slaloms.
Working on the video this week, in the meantime, some cool photos
The Following User Says Thank You to justinco For This Useful Post:
Pat (06-29-2016)
Old 06-29-2016, 12:35 PM   #60
strat61caster
strat61caster's Avatar
@justinco Are you doing the EBD disable?
ineedyourdiddly
Old 06-29-2016, 01:27 PM   #61
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Yes, I have been. Actually, in the last event (these photos above) I tried with just the buttons (5+ second hold) to test.
My friend Brian (Briankbot on here) and I got into another discussion that weekend on which is the best approach. He heard, or read somewhere, that the pedal dance limits ABS to "1-way" versus "4-way" when you just use the buttons. The thought was 4-way ABS would help brake the car quicker and in a more controlled manner.
We have no scientific evidence that supports either way, however I just tried with the buttons to see if I could feel a difference in the driving behavior. It did seem like the car stopped easier, but that could just be my imagination or from the suspension changes I made at Spring Nats. Who knows...I might try to test the differences again when we have a Test & Tune coming up.
strat61caster (06-29-2016)
Old 07-14-2016, 06:04 PM   #62
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
So I had the car into 3R auto for a new setup and corner balance to try and fix a couple minor issues (mostly corner exit understeer and inability to trail brake slide the rear end on entry). Chris Mayfield did some magic and the car feels a good bit better and noticeably more balanced. I was finally able to slide the rear on demand when needed while still being mostly stable. Need a bit more seat time in it for experience and learning to drive it better. I've feel like I have yet to put in a solid run end to end, so definitely room for improvement.
Last weekends event ended up 7th in PAX out of 157 and 2nd in STX again behind Mr. Santel by a few tenths. Video up for enjoyment!
[ame]http://www.youtube.com/watch?v=-9ZSQtAQLz8[/ame]
DocWalt (07-14-2016)
Old 07-15-2016, 10:41 AM   #63
e1_griego
e1_griego's Avatar
Drives: Many
What are you running for an alignment? (if you're willing to share).
e1_griego is offline   Reply With Quote
Old 07-15-2016, 11:11 AM   #64
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
DocWalt (07-15-2016), Shark_Bait88 (09-30-2016)
Old 07-15-2016, 11:12 AM   #65
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
I'll snap a photo of the setup sheet when I get home It's around -3.1f/-2.8r for camber, toe is mostly neutral.
e1_griego (07-15-2016)
Old 07-16-2016, 02:01 PM   #66
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Setup sheet.
Silverspeed (07-18-2016), strat61caster (07-18-2016)
Old 07-16-2016, 02:10 PM   #67
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Rest of it:
Old 07-18-2016, 12:47 AM   #68
Silverspeed
Drives: 2014 FR-S
Justin, you better ask Chris if having 31 psi in the RR and the other 3 tires flat would throw off the alignment...
Thanks for sharing.
Silverspeed is offline   Reply With Quote
The Following User Says Thank You to Silverspeed For This Useful Post:
justinco (08-11-2016)
Old 08-11-2016, 10:33 PM   #69
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Little slow on the videos lately, too busy with work and things. Latest recap of the Colorado National Tour where I took 2nd place is up!
[ame]http://www.youtube.com/watch?v=na6l7XAEWjk[/ame]
The Following 3 Users Say Thank You to justinco For This Useful Post:
Blue Gt (08-12-2016), DocWalt (08-12-2016), Silverspeed (08-12-2016)
Old 09-25-2016, 11:05 PM   #70
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Oh, how could I forget to post the 2016 National Championship video?! Oh yea, cause it was not good at all haha!
[ame]http://www.youtube.com/watch?v=cDfHRfRgZI4[/ame]
DocWalt (09-26-2016)
Autocross Videos - Tips and Discussion DaDr00 Tracking / Autocross / HPDE / Drifting 413 10-06-2025 01:52 PM
My BRZ ST* Autocross build Scooby South Tracking / Autocross / HPDE / Drifting 848 08-14-2018 11:20 AM
Project FRS - Autocross build (CS/STX), and results justinco Member's Car Journals 0 10-08-2015 04:28 PM
Tires for summer/autocross/track (videos only) dp1 Tracking / Autocross / HPDE / Drifting 2 03-15-2015 08:31 PM
Feldys Autocross videos feldy Tracking / Autocross / HPDE / Drifting 25 06-13-2013 02:58 PM
