Old 01-25-2017, 10:59 AM   #57
chaoscentral
Drives: 2013 Scion FR-S Series 10
https://www.dropbox.com/s/2ppc5iw92r...83517.mp4?dl=0
Is what a broken rocker arm can sound like. Not my video, just posting what I found online
Current Mods: Eibach Sportlines/ Borla UEL Header/ Invidia N1 Catback/ OFT Stage 2 UEL E85 Tune/ Enkei EDR9 18x7.5
chaoscentral is offline   Reply With Quote
Old 01-25-2017, 12:22 PM   #58
dallenj
Drives: Grey FR-S
Originally Posted by chaoscentral View Post
are you able to tell if the sound is coming from the valve cover or not? only things i can thing of with that sound is either valvetrain or exhaust, and unless you ripped off half the exhaust without knowing I kind of doubt it is that. if you can't figure out where the sound is coming from try using a big screw driver as a stethescope to locate the sound. I know some of the 13s(if you have a 13 that is) have some rocker issues, but do you know when this started happening?
started happening just a few days ago. I was just driving normally and started hearing some extra mood from my passenger side.
dallenj is offline   Reply With Quote
Old 01-25-2017, 12:38 PM   #59
chaoscentral
Really hard to diagnose over the internet lol. I'm fresh out of ideas. All I can say at this point is get it on a lift or jack stands and start poking around where the noise is coming from. Check all of the exhaust in that area etc. If it is indeed coming from within the valvecover, get it looked at ASAP before you end up with a new window into the valvetrain
Old 01-27-2017, 10:50 PM   #60
dallenj
Drives: Grey FR-S
Here is an update. Pretty sure its an exhaust leak in missing 2 header bolts one on the drivers side one on the passenger side. Ill know for sure in just a little bit when I start my car and underneath it.
Unrelated but I notice an oil leak coming from what I think is my exhaust vvt housing. Shown at the end of the video.
Old 01-27-2017, 11:35 PM   #61
dallenj
Drives: Grey FR-S
Found the issue of the noise. It was an exhaust leak caused by a missing header nut. Little concerned about the oil leak I found though watch the end of the video I posted and let me know any ideas you have. I'm trying to find out where it is coming from right now.
Old 01-28-2017, 01:59 AM   #62
dallenj
Drives: Grey FR-S
i.imgur.com/7OKH8vY.jpg
NX Plate kit with a 75 shot
1320 Headers
J2 Front Pipe
Greddy Evo3 Cat Back
Old 01-28-2017, 08:28 AM   #63
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Do you wrap those headers? Extreme heat from the headers may of killed a gasket/seal, which yes it looks like an oil leak for sure.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 01-28-2017, 12:52 PM   #64
dallenj
Drives: Grey FR-S
I do not wrap my headers.
I found out a little bit ago an exhaust leak from the missing header bolt is not the source of the noise. I am ordering some header gaskets and hopefully that fixes it if not I think I have something in the valve train that broken.
1320 Headers
J2 Front Pipe
Old 01-28-2017, 01:18 PM   #65
chaoscentral
http://www.ft86club.com/forums/showthread.php?t=67454
That may be of some use to you, looks like it has happened to some other people as well. the factory sealant not holding on some cars in that same area
Old 01-30-2017, 08:15 PM   #66
dallenj
Drives: Grey FR-S
How do you post pictures on here I have tried before. They just will never upload.
1320 Headers
J2 Front Pipe
Old 01-30-2017, 10:53 PM   #67
chaoscentral
I usually just host them elsewhere like imgur then copy the url generated on that page and click the insert image button on the forums and paste in the link
Nitrous setup Subaru86 Engine, Exhaust, Transmission 6 08-03-2015 01:54 AM
Nitrous build dallenj Forced Induction 34 08-01-2015 03:27 AM
nitrous? ender2664 Forced Induction 48 06-13-2015 10:36 PM
Anyone running with Nitrous? JDMenrique Forced Induction 29 10-21-2012 10:02 PM
nitrous eindio Forced Induction 17 09-22-2012 01:09 AM
