Old 03-31-2015, 12:09 PM   #57
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Ask someone to do it for you
This is what I usually end up doing, but doesn't always work. Pass-through OBD2 disabler would be ideal though. Trust me I usually get it done one way or another. It's just a "sometimes" thing.
raul is offline
The Following User Says Thank You to raul For This Useful Post:
CSG Mike (03-31-2015)
Old 04-03-2015, 02:45 PM   #58
Uplink
Uplink's Avatar
Drives: anything you let me
Originally Posted by Shutter View Post
forum begs for device so we dont have to dance on pedals
after 2+ years, device presented.
forum bitches it doesn't make coffee
lol...at least we're going in the right direction
You must be new to the internet.
Uplink is offline
Old 04-03-2015, 03:58 PM   #59
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
I finally got my hands on one of those "netzero" cd's and got my dialup going!
continuecrushing is offline
The Following 2 Users Say Thank You to continuecrushing For This Useful Post:
Ultramaroon (04-04-2015), Uplink (04-03-2015)
Old 10-01-2015, 11:25 AM   #60
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
I'm going to test this thing out at an AutoX event tomorrow. Will report back.
Certainly won't work for everyone or every situation but it might be useful in cases where one isn't logging and just wants to focusing on driving and doesn't want to worry about brain farting and messing up the Pedal Dance.
The only problem I have is that I have no clue whether I need to plug this thing in and then manually disable the VSC/TRAC via the console buttons or whether this thing is just plug and play. Maybe the dash lights will automatically go Amber, maybe they won't.
I basically consider this thing to be more 'fun' oriented and less 'competition' oriented.
Serious competition track stuff is a whole different ballgame. If I'm testing or competing then yeah, I need my OBDII port for logging in which case yeah, this thing becomes completely useless. Being serious also means a whole ton of things to worry about and running through the whole PITA Trackday pre-run checklist, by which time the car is always warm enough to do the pedal dance anyways:
- Start car
- Connect the OBDII dongle
- Mount & connect the Android phone and boot up the Torque app
- Check Torque OBDII connection
- Start up external GPS
- Mount iPhone 'just so'
- Boot up Harry's Lap Timer on the iPhone
- Set the track in HLT
- Check the GPS connection strength in HLT
- Mount, check and set up any GoPros as needed
- Do the pedal dance
Going a bit off topic here but if anything somebody ought to come up with a cheap and easy way of simplifying the whole data logging and pre-session setup routine. Ideally there'd be a single unit which handles car settings + OBDII data logging + accurate G forces and lap timing and which also integrates well with post run analysis software of some sort.
One of my main pet peeves with logging and competition is that beyond a certain point the whole pre-session setup process tends to detract from the actual driving - any attention given to your data logging setup while running a session is less attention given to your actual driving in the moment.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline
Old 10-01-2015, 01:49 PM   #61
stevesnj
stevesnj's Avatar
Just get an 86 Nanny, Pass thru powered ODBII, ABS disable and other goodies.
http://www.beastronix.com/
My 2016 Build thread
stevesnj is offline
The Following 5 Users Say Thank You to stevesnj For This Useful Post:
Beastronix (12-14-2015), Bramick (12-06-2015), CSG Mike (10-01-2015), GSpeed (10-05-2015), ultra (10-05-2015)
Old 10-01-2015, 08:44 PM   #62
Rickg87
Drives: 2012 Scion FRS
Unless your drifting you could save some $.
I run my FRS full race prep w/ roll cage, suspension, bushings, control arms,etc.
With no traction interference by simply disabling both tc and vac.
I race in NASA and run Hoosier R7's. No issues. The car is pushed hard.
I tried this obdII solution and feel no difference.
Rickg87 is offline
The Following User Says Thank You to Rickg87 For This Useful Post:
ultra (10-01-2015)
The "Pedal Dance" testing CSG Mike Tracking / Autocross / HPDE / Drifting 419 08-01-2023 11:46 PM
CEL P0351 Ignition Coil "A" Primary Control Circuit/Open romin Engine, Exhaust, Transmission 468 11-26-2021 05:05 PM
Where to buy "heel/toe" shaped gas pedal? dookie11 Scion FR-S / Toyota 86 GT86 General Forum 56 01-22-2019 12:24 PM
Pedal Dance Device robot Tracking / Autocross / HPDE / Drifting 3 01-10-2014 10:26 AM
Additional "pedal dance" testing. CSG Mike Tracking / Autocross / HPDE / Drifting 55 08-27-2013 04:02 AM
