#57 | |
Drives: 2013 SWP BRZ Ltd. / E60 M5
![]() Thanks for the info!
2013 BRZ Limited | SWP | Verus Ventus 1 and High-Efficiency Rear Wing | Invidia N1 Ti | JR Oil Cooler | RCE T2 | RaceSeng Cas/Cam | SPL LCA & TA | Wilwood/RR Racing Stage II/Sport Performance | XP10 | Apex ARC-8 | Toyo R888R | 245/40-17 | Sparco Ergo II/Evo II | AIM MXP | SmartyCam GP HD 2.2
#58 |
driving smoother faster
Drives: Sold
What I learned this HPDE season:
- I like driving on slicks and probably won't use tires above UTQG 100 on a dry track again - I like Toyo Proxes RR...a lot...they give audible warning before they let go and it looks like they will take on many heat cycles |
#59 |
Drives: 2015 Scion FRS - Raven
#60 |
Drives: 2015 BRZ
Between the spring perch and the sidewall. No issues without camber bolts, or with Tarmac II coilovers.
#61 | |
#62 |
Drives: 2014 BRZ SCCA STU endurance car
Both guys who run a serious summer setup here love the R888's. They wear surprisingly well for street use too.
#63 |
R888's are known to fall off fast, and heat cycle out long before the tread is gone. They're also not competitive against current R compound treaded tires (Hankook TD, etc), or even against the hottest street tires anymore.
#64 | |
CASC-OR T.A. Director
Drives: '13 Prius, '22 BRZ
I think I'm going to order their street compound (Carbotech 1521) and swap pads between track and off track. Pain in the ass but it makes the car a true weekend warrior as opposed to just a track warrior.
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK |
#65 | |
#66 | |
It was interesting to note that the RE71-R was stickier to touch and picked up more dirt. Nevertheless the R888 was faster. Of course, the R888 is still significantly slower than a racing slick (see my previous post). Over here the R888 is meanwhile being replaced by the R888-R (but I have no experience with the R888-R nor do I know anyone who has.) |
#67 |
Drives: 2013 FRS / 2013 427 Vert
These are my R7's after 32 heat cycles over 8 days this the summer.
Sebring 5 Days Roebling 1 Day NOLA 2 Days They still look great but the compound has hardened substancially, still managed laps at NOLA in the 2:02's. Most track days I rotate front to back at mid day then opposite corners at the end of day 1.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
#68 |
I just bought a second set of track wheels from a forum member today. These are RPF1's in 17x8. I plan to run a 225 tire on these wheels and compare back to back against the 17x9 Titans which will be reshod with a slightly used set of 245 A7's I have in the garage. Many have suggested that less section width and less sticky compound may actually be faster on horsepower biased tracks like Sebring, RA and VIR where I plan to run in the coming months.
I would like to hear suggestions for a tire to represent the skinny on lighter wheels side of the equation. Very interested in these, total weight would be 34 pounds. http://www.tirerack.com/tires/tires....P0TR&tab=Specs
[SIGPIC][/SIGPIC]
#69 |
Drives: Sold
Any more comments on Maxxis Victra RC-1? Or new experiences with Maxxis VR-1?
#70 |
Drives: 2013 BRZ Limited M/T
He just ran this first set http://www.ft86club.com/forums/showthread.php?t=13157
| NT-01 or R888 ?? Summer Track Tire | Deep Six | Tracking / Autocross / HPDE / Drifting | 22 | 03-04-2015 02:35 AM |
| Autocross to Track Day Transition "Dive bombing a tire wall" | Rickapl | Tracking / Autocross / HPDE / Drifting | 13 | 07-27-2014 10:40 PM |
| Autocross to Track Day Transition "Dive bombing a tire wall" | Rickapl | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 07-15-2014 10:05 PM |
| New Tire Choices | Lunatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 06-30-2014 03:31 PM |
| Best $100 Summer Tire in 225/45/17 | Black Tire | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 03-07-2013 06:22 PM |
