Old 01-14-2016, 10:30 AM   #57
CWright1386
CWright1386's Avatar
Originally Posted by Summerwolf View Post
It is an 8.75 wide wheel. 245 is going to look "correct" while a 225 will look "stretched"
If you're just going for looks the look is subjective. 245 will also offer a larger contact patch if performance is your goal.
Makes sense. Thanks!
Sent from my XT1585 using Tapatalk
CWright1386 is offline   Reply With Quote
Old 01-24-2016, 12:07 AM   #58
lukey86
Built Not Bought
lukey86's Avatar
Drives: 2012 Toyota 86 ZN6
So there's a nutsert in the strut tower that I didn't think would rub. I was wrong.
The hole wasn't really fixable so now I have to buy a replacement strut (if they even sell them!) So for now I've had to cut a standard spring and re-install it. Looks like crap as I'll need camber bolts to tck the wheels. Funny thing is though, I've only put one of the oem coils back on but the ride quality has improved out of sight! That was unexpected..
lukey86 is offline   Reply With Quote
Old 02-09-2016, 11:48 PM   #59
lukey86
Built Not Bought
lukey86's Avatar
She's come such a long way 😍😍
Old 03-05-2016, 06:35 PM   #60
lukey86
Built Not Bought
lukey86's Avatar
Slam and chill @ the Illusiv Oz car park meet
Old 04-03-2016, 06:25 PM   #61
ChanceK
ChanceK's Avatar
Drives: 2016 FRS
Hey man, I really like your car. I just ordered my Airlift kit and I was wanting to run 18x9.5 with a +20 offset. I know you have 18x9.75 +20, but how much are your fenders rolled and pulled?
ChanceK is offline   Reply With Quote
Old 04-03-2016, 08:15 PM   #62
lukey86
Built Not Bought
lukey86's Avatar
Thanks man! There's a few things you'll have to do to tuck and get a decent ride without rubbing/scrubbing.
The front fitment isn't too bad, it pokes a little but with max camber it's ok. You will have to do something about the inside of the strut tower though, the bag rubs on it with max camber. I ripped a hole in one of mine from rubbing so I removed all the clips, nuts etc. and used a hammer to knock a little crater for the bag to sit in (not really noticeable from the engine bay side unless your building a show car) it doesn't rub at all now at driving height. It does rub a little when fully aired up but it doesn't hurt as long as it doesn't rub on anything sharp.
The rears I rolled and pulled a little but for a decent ride you need LCA's. Natural camber isn't quite enough and in order to stop the wheels from scrubbing the fenders on every bump you need to run high psi which makes the ride really harsh lol. LCA's will give you a little more camber and allow you to run lower psi for a nice smooth ride with no scrub. A new set of sway bars are highly recommended too
Old 05-01-2016, 11:06 AM   #63
lukey86
Built Not Bought
lukey86's Avatar
This is why I'm broke cdrazic93 Off-Topic Lounge [WARNING: NO POLITICS] 14 07-26-2014 03:15 PM
I think I broke the tie rod....... jshum Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 06-04-2014 12:41 AM
My ECUTEK usb key broke.. JerryMichaels7 Software Tuning 6 02-07-2014 12:53 PM
Broke down and did the interior. jybrd Cosmetic Modification (Interior/Exterior/Lighting) 20 07-15-2013 08:49 PM
Oh-Oh's, I Think I Broke It! track_warrior Issues | Warranty | Recalls / TSB 232 06-12-2013 10:58 PM
