Old 12-14-2014, 05:57 PM   #57
Amaya
Amaya's Avatar
Drives: 2015 Scion FR-S 6MT
Won't lug as they are the "ideal" shift points. Did it for a couple of days and didn't see any difference in mileage but may have a higher impact with all city driving.
Feels like you are playing a really lame game of Guitar Hero (Shift Hero?) if you try to hit the indicator right on.
Shift points won't change mpg's as much as throttle position.
Amaya is offline   Reply With Quote
Old 12-15-2014, 07:23 AM   #58
brianhj
Drives: 2017 Camaro 1SS
Are you guys not going above 4k rpms or what
brianhj is offline   Reply With Quote
Old 12-15-2014, 09:24 AM   #59
Yep! On a regular basis!!!
Old 12-15-2014, 09:26 AM   #60
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
If I drive conservatively it's 3.5k and below. Anything above that and it's a noticeable decrease. The shift indicator is way too early and thinks the world is flat.
2016 Camaro SS is offline   Reply With Quote
Old 12-15-2014, 09:29 AM   #61
Amaya
Amaya's Avatar
The trick is keeping it above the torque dip. After all the low torque is indicative of inefficiency and that's like the opposite of what you want for good mpg's, right?
Old 12-15-2014, 12:09 PM   #62
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
Scenic Driver is offline   Reply With Quote
The Following 2 Users Say Thank You to Scenic Driver For This Useful Post:
2016 Camaro SS (12-15-2014), Silver Ignition (12-17-2014)
Old 12-16-2014, 04:30 PM   #63
Dake
Dake's Avatar
If you want the best mileage, you have to think like a modern AT. It upshifts as soon as it possibly can to keep the RPMs as low as possible. If you're waiting until 4k (or even 3k) RPM, that's too high.
Around town in regular traffic I regularly upshift at 2000-2200. That gives adequate acceleration and does not bog down the engine.
To equate it to MPH I go:
1st to 2nd: almost immediately (and don't even leave second for a rolling stop)
2nd to 3rd: 12-15mph
3rd to 4th: 19-20
4th to 5th:28-30
5th to 6th: 38-40
The reality is, from a dead stop I often skip-shift first to third, third to sixth; from a rolling start it's second to fourth, fourth to sixth. Again, this is on mostly level terrain, in regular traffic. On any given tank of gas I still get after it when the spirit moves me and I still do 70-75 on the highway, but the rest of the time that's how I shift and I maintain a steady 30-32 mpg.
Dake is offline   Reply With Quote
Old 12-16-2014, 04:47 PM   #64
Koa
3rd to 4th: 19-20
4th to 5th:28-30
5th to 6th: 38-40
This isn't true. RPM is not a good indicator of engine load by itself. It's a good metric to use in shifting, especially with matching the output shaft and input shaft (the main purpose of a tach). Shifting at 3k-4k rpms will, all other things considered, give you better miles per gallon than trying to lug the thing around. I'll explain why in one sentence:
Throttle position is WAY more important- if you're lugging it all the time, you're consuming extra gas.
Anyone who has owned a turbo-charged car will know exactly what this entails
Old 12-16-2014, 04:49 PM   #65
brianhj
3rd to 4th: 19-20
4th to 5th:28-30
5th to 6th: 38-40
Boooooorrrrrring
The Following User Says Thank You to brianhj For This Useful Post:
Koa (12-16-2014)
Old 12-16-2014, 04:49 PM   #66
Koa
P.S. I added 2 to 3 MPG from switching stock tune to OFT's off-the-shelf 91 octane Stage 1 tune.
So excited about that. I am seeing 30-31mpg on the car, up from 27-29mpg averages (typically was 27mpg)
Old 12-16-2014, 08:45 PM   #67
Kaotic Lazagna
Drives: GR Corolla
http://www.fuelly.com/car/scion/fr-s/2014/07Vios/287038
Slowly accelerating, camping in the slow lane (when possible). LOL. I'd rather spend/save money for parts than on gas =P
Primarily freeway driving, but I deal with Cali's Bay Area traffic daily (so I would say equivalent to 50/50 city/freeway driving).
Old 12-17-2014, 09:35 AM   #68
paulca
Drives: Toyota GT86 Coupe Red (UK)
I'd just confuse things as we have a different sized gallon! I think we both use imperial miles though (or do you guys use statute miles?)
I 'can' get 42mpg with highway cruising. I 'can' get 35mpg commuting in mixed traffic, but usually it's around 29-31mpg.
However that spread shows that it really depends on how and where you drive the car!
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
paulca is offline   Reply With Quote
Old 12-17-2014, 12:51 PM   #69
Dake
Dake's Avatar
Apparently stating twice "Level ground" ie "average conditions" wasn't enough so I'll state it a third time:
Under average conditions on level surfaces in regular traffic.
No where did I say this is what happens every time, all the time, regardless of the world around me. This is for tooling over to the grocery store for a gallon of milk. That is not how I drive on a track day or how I even drive merging onto the highway.
This method does not "lug" the engine in anyway in those general circumstances. If the conditions are not appropriate for a low RPM upshift, wait until a higher RPM. Yes, throttle position matters and that is taken into consideration.
Also, I'm glad people driving turbos have an apparently better understanding. I think the most important thing to understand is: we're not driving a turbo.
Boooooorrrrrring
This I can respect even if I don't agree. I personally enjoy the fact that I can be comfortably boring in general and have a blast on the track once a month.
That being said I chuckle when folks complain about our low 0-60 times but insist on hammering it from every stop light anyway. You bought the wrong car if you only get your kicks "a quarter mile at a time".
Old 12-17-2014, 01:57 PM   #70
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
Not sure if it's been mentioned becasue TL;DR but the MPG number on the dash computer is directly and entirely related to the throttle % and nothing else. So if your number is low, your foot is heavy. Period.
Don't believe me? Tune for E85. Computer average stays the same but real world MPG's are 5-8mpg lower.
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
