#57 | |
Drives: AE86
ALL NonStopTuning pulleys are anodized. And yes, you should definitely pick up some NST alternator and water pump pulleys Best of luck with all your projects! |
#58 | |
Drives: Subaru BRZ Limited
Will you plan to make the rest of the idle pulley (total 3) and the Auto-Tensioner Pulley in order to make the full set pulley for FRS/BRZ? I did see the similar product from Japan as below. Thanks. |
#59 |
Drives: AE86
Yes, we've had the idler/tensioner pulleys in the works for a while.
Thanks! |
#60 |
#61 |
Drives: AE86
#62 |
#63 | |
Drives: AE86
![]() The Blue Gates Belt does not actually stay blue for very long. This is partially due to the fact that the FA20 uses multiple smooth tensioner/idler pulleys that wear at the color. The purpose of the Blue Gates Belt is to have a belt that is apx 300% stronger than the OEM belt, and as much as 400% times stronger than most other belt manufacturers on the market. The Blue Gates Belt eventually turns black and looks like other belts. Either way, it is an awesome options if you are looking for the best belt your money can buy. NST Pulley Kit... http://www.nonstoptuning.rpmware.com...i-1894976.aspx Blue Gates Belt... http://www.nonstoptuning.rpmware.com...i-2018070.aspx
#64 |
Drives: Firestorm 86
#65 |
Drives: AE86
#66 |
Drives: AE86
![]() Those of you who have picked up kits and installed them recently, PLEASE share your reviews, photos, and videos with us in this thread. Much appreciated! |
#67 |
Drives: 2014 BRZ Limited SWP
First pic was finished Second was finished but never got a pic of it completed Third is mine but I have a perrin lwcp instead Everything else is NST. My only suggestion is to make sure you have the proper pulley removal tool for an Auto. MT is easy as we leave it in 6th gear. #houston86club #techday Sent from my iPhone using Tapatalk
#TrackDayBro
#68 |
Drives: AE86
Awesome pics! Thanks for posting!!
#69 |
Drives: AE86
Who else has installed an NST Pulley recently?
Post some and tell us about your impressions! |
#70 |
Drives: AE86
This thread needs more!
| AST 5200 Dampers Updated 25th Feb DYNO CHARTS ADDED | Captain Snooze | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 77 | 12-17-2015 05:06 AM |
| NonStopTuning FRS BRZ Pulley Kit Group Buy | NonStopTuning | Groupbuys | 8 | 05-23-2015 02:27 PM |
| NonStopTuning 3 piece Pulley Kit - RED | harkbrz | Canada Classifieds | 4 | 11-01-2014 12:12 PM |
| NonStopTuning Short Shifter, Info, Ideas, Feedback thread | NonStopTuning | Engine, Exhaust, Transmission | 5 | 10-23-2014 10:38 PM |
| Run in method Dyno charts | Surok | AUSTRALIA | 0 | 10-07-2012 11:29 PM |
