10-02-2014, 01:47 PM | #57 | |
10-02-2014, 01:49 PM | #58 |
Professional Smartass
Drives: White Out FRS
Car goes on dyno without tune. No weird dip.
Car goes on dyno with tune. Weird dip. People go insane defending Vish. Op doesn't log dyno runs so we can't see what happened. Vish blames dyno. (it worked fine on the stock tune???) This is no witch hunt, there is just some missing information. People get so butthurt. |
The Following 2 Users Say Thank You to post_break For This Useful Post: | calmtigers (10-03-2014), gonzo (10-03-2014) |
10-02-2014, 01:49 PM | #59 |
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
My vote is on traction control as well. Pedal dance when you dyno people!
- AdrianG |
10-02-2014, 01:51 PM | #60 | |
Drives: '13 Raven FR-S, MT
.ck Last edited by ck-GT86; 10-02-2014 at 02:04 PM. Reason: Corrected whp |
10-02-2014, 01:56 PM | #61 |
Drives: 2013 FRS
Just test on a Dynojet and you will likely be right around there. The Maha dyno reads obnoxiously low for some reason. It doesn't necessarily mean that your car is down on power.
The Following 5 Users Say Thank You to Shiv@Openflash For This Useful Post: | ck-GT86 (10-02-2014), DAEMANO (10-02-2014), mkivsoopra (10-02-2014), NorCal_Guy (10-02-2014), stonenewt (10-02-2014) |
10-02-2014, 01:57 PM | #63 |
Drives: BMW 120d
For dynos find one that gives consistent figures, eg. same car 1 month apart gives more-or-less identical graphs, and do all power runs at the same place. That way it's all relative to the same set of systematic errors.
10-02-2014, 02:05 PM | #64 | ||
Corrected, sorry! Quote:
And you're basically saying, go FI.... .ck |
10-02-2014, 02:13 PM | #65 | |
Time Traveller
I'm going to remind you of your own words here because they don't describe the attitude in the above reply. If you have "no intention of degrading their reputation". Then why would you post your conclusion as fact in your original post? Additionally, why would you end your original post with a call to Shiv to resolve the problem if you weren't placing blame at his feet? Lastly, can you describe in your own words and experience why you personally believe that your Maha dyno session revealed something that all the time Shiv's R&D on his and other dynos has not? here's your original text The specialist said he encountered this also on another car that was also running a Vishnu tune. Took about a whole day with the help of an outside party to adjust that dip. It's evident this is a tune issue, the huge dip doesn't exist on the stock tune. In fact, the stock tune shows a progressive line when compared to mine. Whats Next: I hope that @Shiv@Openflash finds a fix for these two issues: no power in the 1500rpm range and MASSIVE dip at 4700rpms. I dont know what dyno you guys are using -- I'm no professional, but I think a day on the MaHa would really help out. Over and out.. .ck The above goes well beyond "simply wanting to share my (your) experience". |
10-02-2014, 02:13 PM | #66 |
10-02-2014, 02:24 PM | #67 | |
My gosh, sorry if my words came off wrong -- didn't know the butt-police were out in full body armor. Let me go back and correct that for you so you can pleasantly go about your day, jesus. Take a look at all other dyno sheets you've seen. Most start at the 2000rpm range or higher, the MaHa starts around 1500. Other sessions may run for up to 15 seconds, the MaHa ran for longer than 30 seconds. What these factors play in real world situations, I don't know. If you can explain it to me, please do. If YOU can tell me what's wrong with my car, then do. I've said in my posts that I'm more than happy to delete this thread once Shiv and I can figure out what's going on. I'm more than compliant to do what needs to be done. Rather than read through the entire discussion, you nit-pick on whatever gets you off. You remind me of people I don't like. .ck |
The Following User Says Thank You to ck-GT86 For This Useful Post: | themajesticone (10-02-2014) |
10-02-2014, 02:26 PM | #68 | |
Drives: '13 UM86
JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport |
The Following User Says Thank You to themajesticone For This Useful Post: | DC2R (10-02-2014) |
10-02-2014, 02:27 PM | #69 |
Drives: 2013 FRS
It's all good guys. OP and I will be meeting up to check out his car. It's a happy ending for all
10-02-2014, 02:50 PM | #70 | |
Tags |
bromance, dip, dipsmorethanchipsandsalsa, dipsmorethangrandpaballs, dyno, ecutekbutthurt, maha, openflash, vishnu, yetanothersmearattempt |
Similar Threads | ||||
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 | FRSTEVE | Software Tuning | 105 | 08-04-2017 04:48 AM |
1st Dyno Tested/Tuned 6AT - OpenFlash Tablet | Anorexic 86 | Software Tuning | 13 | 07-25-2014 03:09 PM |
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) | Rombinhood@OpenFlash | Software Tuning | 237 | 02-10-2014 03:35 PM |
***VISHNU OpenFlash Tablet IN STOCK*** | Garrett@Openflash | Engine, Exhaust, Bolt-Ons | 15 | 12-17-2013 01:30 PM |
Interesting Findings about BRZ Audio Output | Chad_W | Electronics | Audio | NAV | Infotainment | 14 | 05-03-2013 08:28 PM |
