#57 | |
Site Moderator
Drives: ichi 86 Project
![]() My guess is they're using cheap NA Impreza parts. That car is pretty much a guinea pig, so gotta replace the parts when it breaks... and STI parts aren't really cheap (even though they make it themselves). When they actually have final production chassis test driving the Nur THEN we can prob do some math and so forth on bolt patterns & other fun stuff |
#58 |
Drives: 08 sti
Yes, Subaru should just move to all 5x114, it would lean out their manufacturing process to only have to make one bolt pattern....
Anyways, the 5x100 suby bearings suck. It is the reason that only the 2004 STi was 5x100, of the US models. On my WRX I put on STi Brembo take offs, biggest mistake EVAR, I only kept them on for a month or so. The main reason being was pad knock back, there are threads on NASIOC about the topic. It is very very scary to experience and have no idea what is going on other than my brake pedal just hit the floor and im not stopping. It should be noted that knock back typically shows up while driving spiritedly on the track and in the canyons. It would be my guess that if the FT86 is released with no brembos it will be 5x100, if brembos are an option or come standard on a higher performance model then the car might be 5x114. Thinking about it, the mule being 5x100 make sense since its missing brembos. While yes the concept that has been showcased did have 4 pot brakes, the 06-07 WRX came with the FHI 4/2 pot brakes from the GC/GM generation STi and it never had a problem with knock back. I have herd that some other BBKs have the knock back issue on the 5x100 too. |
#59 | |
Site Moderator
#60 | |
Drives: 08 sti
For the Impreza at least till model year 2007, I dont know about the new ones but I have a feeling nothing has changed 5x100 + side push caliper(as seen on mule)= ok 5x100 + FHI 4 pots(similar size to the concepts) = ok 5x100 + STi brembo = No good 5x114 + any brake = ok |
#61 | |
Site Moderator
As for the pad knock back stuff, just wondering did you just replace the calipers and not other parts (like brake boost, lines & etc)? |
#62 | ||
Drives: 08 sti
When driving in a straight line it felt fine and stopped really good, in fact the pedal with the brembos was firmer than the FHI 4/2. After some cornering thats when it would show up and then the pedal would just hit the floor and i would have to triple pump the brakes to get the pads back to rotor and build pressure back up, and after that if you continued in a straight line the brakes were fine. For the knockback, I had SS lines at the time already, I bleed and rebleed the brakes properly even had it machine bleed, when that didn't work I rebuilt the caliper with all new seals, when that didnt work i went back to the stock FHI 4/2 and that solved the problem. Knock back was one of the main reasons that the STi went to 5x114 in 05, and got differently designed bearings. Quote:
#63 |
Drives: MR2
Yikes is right lol. I know some people swap out bigger brakes from larger cars of the same brand. That way everything bolts up and works correctly, but without the cost of a big brake kit. I know there were some toyota examples, but I'm too tired to think clearly.
#64 |
hashiryu
Drives: Mk4 Supra
Lots of examples. Toyotas, Nissans and Hondas back in the day were practically like lego toys.
#65 | |
Drives: RX8 S1
Another article regarding the mule.
apparently it is RWD only acording to this.. interesting though as this is the 1st article i have read in who knows how long that doesnt mention dates (apart from the schedule being due later this year) Quote:
#66 |
Drives: 2001 Legacy GT
I'm surprised no one has mentioned this but it now seems very likely given other photos.
I am almost 100% certain the headlights on that mule are Supra headlights. Wasn't there talk of there being a test mule disguised as a supra? Ben |
#67 |
RaggedEdge Autosports
Drives: 97 APU Supra
No they are not supra head lights, if they are then it looks like they baked them and pulled them apart to put in some amber and change the projector main light to what ki da looks like a halo projector light, which is possible but I doubt it plus they would have covered up 50% of the head light with body panels
Red JZA80 APU Supra 800whp
White 07 Turbo Si 411whp *RIP* ![]() |
#68 |
Drives: MR2
You can tell they're WRX headlights. No big surprise there...
#69 |
yea I guess my eyes were deceiving me.
I think I was viewing something else that I thought was the actual outline of the light that did not resemble the wrx.Carry on... Ben |
| Subaru's FT86 debut in 2013? | Dark | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 07-30-2010 02:46 PM |
| new Kia coupe | Ground N Pound | Other Vehicles & General Automotive Discussions | 22 | 12-29-2009 03:04 PM |
| edmonds.com take on subaru's version | MtnDrvr86 | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 11-19-2009 05:28 PM |
