#57 |
Drives: Whiteout FR-S
I'm hoping to get the money together soon to start building mine and figuring out mounting location. I also need to get an obd2 splitter so i can hopefully keep the use of my p3 gauge
#58 |
There are now 2 carseats!
Drives: 2013 DGM BRZ
I think I figured out the oil temp thing.
I think I send it "07E02101" and get back a 29 byte answer and use the 29th byte (aka "AC" (which, as an aside was something I was being dense about until last night. The numbering system for returns is documented as A=1, B=2,...,AA=27, AB=28, AC=29) and subtract 40 to get oil temp in C. I'll try it later tonight. (If this works then I can also probably get that fuel tank level thing working as well.) |
#59 |
Drives: Toyota GT86
Hi robot,
it should be the last byte in the message, see my code: http://mbed.org/users/chrta/code/Obd...emperature.cpp Since i do the CAN message decoding on my own, my packet data length may differ from yours. BTW: I will use this display http://www.adafruit.com/products/1431 (1,5" OLED) |
#61 | |
It turns out the PID is actually a CAN one and I was reading it wrong because the ELM command set returns it with numbered "stanzas" and not just in one long string. |
#62 | |
Drives: 2013 GBS BRZ Limited
When I plug it into the Arduino Leonardo, I can get it to work fine for my application, but I dont have enough EEPROM for the SDCard library. So I got a Mega, and the shield doesnt "just work" like it did with the Leo & UTFT Lib. So now I want to get it to work in serial mode, but havent messed with it much. If I could get that working I would try to get the touchscreen to work for very basic gestures. |
#63 | |
https://learn.adafruit.com/1-8-tft-d...eed-spi-wiring Shows you the different pins. The rest of the tutorial is probably not helpful for your setup. "On Atmega 328/168/8 type Arduinos ('classic' type) the hardware SPI pins are 11 (MOSI), 13 (SCK) and 10 (CS). For Megas it is 51 (MOSI), 52 (SCK), and 53 (CS). The CS pin can be a different pin but if you use any other pin you must still have the hardware SPI CS pin (10 or 53) as an output!" |
#64 |
I got oil temp working. It was a pain.
Code:
Serial1.println("AT SH 7E0");
getResponse();
Serial1.println("2101");
Serial.println("brz oil temp");
//value = ( (getResponseCAN('4', 11) ) - 40) * 1.8 + 32; //29th byte - 40 (?)
getResponse();
//Serial.println(&rxData[109]);
//Serial.println((float)strtol(&rxData[109],0,16));
value = ((float)strtol(&rxData[109],0,16) - 40) * 1.8 + 32;
Serial.println(value);
//Serial1.println("AT D"); //these two lines make the next 2101 reading get cut off
//Serial1.println("AT E0");
//Serial1.flush();
delay(40);
Serial1.println("ATSP6");//doesn't work and is slow (probing for protocol takes work)
//getResponse();
#65 |
http://www.gps-laptimer-forum.de/vie...hp?f=20&t=1364
The one jpg link in the thread is a screenshot of someone with a prog querying the ecu for what pids it supports. ECT is supported. ECT is engine coolant temp. I must be doing something wrong. I bet there is still data in a buffer or something when I start reading the coolant temp and the offset messes it all up. |
#66 |
robot,
Curious - Have you looked at using a droid phone as the interface/display unit for the arduino? I see that there is a USB HOST library for Droid, but I havent dug into it much. I think that would be an excellent choice for these purposes as almost everyone has an old droid smart phone laying around. Then from the Arduino's poit of view, all IO is just through the Serial IF (no need for the UTFT lib.) |
#67 |
If anyone is interested I could use some help. I'm stuck on the timing of the OBD II UART device. I sort of, almost have readings working from all of the PIDs. They just aren't working one after the other.
#68 |
Drives: WRB BRZ
How fast is your refresh rate? I'm polling at around 30ms period for rpm without any issues.
Sent from my Nexus 4 using Tapatalk
#69 | |
Depending on how I have things set up I start of with no readings and then after looping through several pages I get readings ok. OR I get readings from everything but the water temp. I'm kind of confused at the moment and should probably do some code cleanup to help things out. I did find this...and it was extremely helpful: https://forum.sparkfun.com/viewtopic...32457&start=60 (it's the post by rocketboy...it's basically a way for you to type commands in from a serial monitor and see the responses.) http://forum.arduino.cc/index.php?topic=258730.0 is my call for help on the Arduino forums. I should have studied more CS in school. |
#70 |
Drives: WRB BRZ
Anytime I have timing issues, I usually relax all timings. For CAN, the identifier ID also relates to priority. The higher the number, the lower the priority. If you're reading all values by sending out a request for each value, I suggest increasing your loop delay.
| EGT gauge | SubBrZ | Engine, Exhaust, Transmission | 23 | 11-10-2015 09:31 PM |
| Gauge pod | ikeryder13 | Want-To-Buy Requests | 4 | 03-30-2014 01:02 PM |
| WTB DCW gauge pod | mikepaul21 | Want-To-Buy Requests | 1 | 03-26-2014 08:28 PM |
| FS DCW Gauge Pod | whitefrs | Interior Parts (Incl. Lighting) | 7 | 03-26-2014 02:39 PM |
| Temperature Gauge a dummy gauge? | bambbrose | BRZ First-Gen (2012+) — General Topics | 40 | 08-19-2012 04:29 PM |
