Old 05-17-2014, 04:30 PM   #57
Slysdexia
Slysdexia's Avatar
Drives: '14 Monogram 6MT FR-S - Hot Lava
Originally Posted by Kdej1 View Post
It's perfectly reliable (when done right). It's just most people don't like to let their cars fully warm up in the morning. So depending on your internals, this could be the motors undoing..
What do you mean by 'fully warm up', exactly?
I let it run for 30 seconds to let oil get where it needs to and let the cylinder temps come up to prevent acidic condensation and subsequent wear (combustion byproducts are acidic), then drive off fairly normally. I don't put the hammer down until I'm sure oil temps are up.
Slysdexia is offline   Reply With Quote
Old 05-17-2014, 10:48 PM   #58
CruiseZen
CruiseZen's Avatar
Drives: 2014 Ultramarine 6MT FR-S Monogram
subscribed
Borla axleback exhaust * mud guards * Michelin Pilot Super Sport tires * Opti-Coat * BRZ trunk lid liner * Rexpeed Wide Mirrors (heated)
CruiseZen is offline   Reply With Quote
Old 05-18-2014, 01:34 AM   #59
Panda Mao
Panda Mao's Avatar
Drives: 2014 Scion FRS
Ive never done this on newer cars as onlyh 1-2 mins after start up I drive off but on older cars especially in colder weather I let the car idle as much as 5-10 mins until the temp gauge needle is at normal operating temps.
idk how much it affects newer cars considering they warm up faster than older cars but I assume even in very cold weather it will take a few mins to warm up but I may also let it warm up the same way as my older cars till the gauge is at normal operating temps mainly not just cuz of oil temps in normal range but usually with older motors like cast iron they are very brittle with cold and hot changes that are instant will lead to metal cranking as for aluminum the metal expands as temps rise idk how it plays into motor longevity via "full warm up" though
Panda Mao is offline   Reply With Quote
Old 05-18-2014, 06:29 AM   #60
Victor Draken
Drives: Toyota Gt86
Never waited more then the garage door to open and close before driving off.
Just drive it slowly and without revving it to much for the first few miles. That's it.
Victor Draken is offline   Reply With Quote
Old 05-18-2014, 10:11 AM   #61
Mikem53
Drives: FR-S 6MT
Originally Posted by celek View Post
After inspecting the Cylinders on the FA20 it appears that it has a nikasil plated bore on solid aluminum cylinders... No inner steel. But that is fine I have a fix for that.
Edit applied a Magnet to the cylinder and it stuck so must be steel there. very difficult to see with the naked eye on a oily block
According to this article here:
The fa20 has thin cast iron sleeves in the bore, as you suspected.
http://www.revvolution.com/blog/2014...amp-amp-4u-gse
Mikem53 is offline   Reply With Quote
Old 05-18-2014, 12:51 PM   #62
Kdej1
Colten Drew
Kdej1's Avatar
Drives: '13 Fr-s // '95 Civic // '09 Vette
It has a long term affect on the engine. I was just saying depending on what internals are used.. For example, my N/A K24 Civic had forged pistons but was still on OEM cylinder walls I would not drive the car until it was at normal running temp.
IF this car is your daily driver, or you drive this thing a lot ( 10k+ miles a year) and in stop and go, want to start the car up and drive off a few minutes later, then this is something you really should think about. Cast Hypereutectic pistons have a very very low expansion rate and thus can have a very tight piston to wall clearance, and thus very little blow by or piston rock when the engine is cold. This makes for a great every day daily driver motor.
Everyone is fast to go with shelf forged pistons because they are available and cheap. All pistons have a spec'd piston to wall clearance to have the cylinders bored to spec so that the piston has the correct skirt clearance. This is ofcourse as everyone knows, very very important. Now the part no one thinks about is at what engine temperature is this clearance? If you have your block bored at say 70deg F with a .0025" clearance, then how hot does the motor have to be to get the piston closer to .0008-.001"? on many many forged pistons this temperature is around 190-200 deg F. On most cast pistons, this temp is actually much lower around 150-160deg F. MOST cast Hypereutectic pistons also have a very tight COLD piston to wall clearance of usually less than .001". Most honda and nissan motors are around .0008" COLD and when at normal opperating temp, closer to .0006".
A cast piston will have much much less piston rock, slap, and cylinder scoring due to those effects, because of the much tighter piston to wall clearance. a Forged piston will have a lot more piston rock, slap, and so on when cold because the piston is rocking in the bore A LOT more than cast piston. This is why it is so very critical to let your engine warm up before driving or "smashing on it" most people will wait until the engine temp gauge starts rising, which is good, but you need to know how warm that is. A forged piston at 160 deg is still not "fully expanded" to its spec'd clearance as it should be. At 160-165 deg ( which many built street car setups run while cruising down the road) there is still a bit of extra piston to wall clearance which means excess piston slap and rock, which means excess piston and cylinder scoring...
For a REAL Street car I will try to choose FACTORY cast pistons anyday over a forged piston..Race car, Forged piston anyday ( unless have to use cast)
Kdej1 is offline   Reply With Quote
Old 05-18-2014, 04:20 PM   #63
ramiram1984
Drives: 2016 STi DGM
I understand you (OP) want to go into uncharted territory with the FA20 N/A.
Please keep tabs of how much $ and time you spent.
Subd
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Old 05-24-2014, 12:57 AM   #64
celek
Resident Gear Head
celek's Avatar
Custom set of pulleys cam in today
celek is offline   Reply With Quote
Old 05-24-2014, 01:07 AM   #65
celek
Resident Gear Head
celek's Avatar
Originally Posted by Herndon View Post
Why the need for a new crank?
Could not machine it the way I wanted to.
Old 06-02-2014, 03:49 PM   #66
celek
Resident Gear Head
celek's Avatar
Spot the differences?
Old 06-02-2014, 04:06 PM   #67
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
I think I'm stupid lol
lbroskee is offline   Reply With Quote
Old 06-02-2014, 04:41 PM   #68
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Did you guys remove that much material?
industrial is offline   Reply With Quote
Old 06-02-2014, 05:47 PM   #69
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
Looks like the oil feed holes have bigger reliefs(if that's what you call them) cut, as well the crank throws looke like they have a larger radii between the connecting rod bearing and the side of the support? It maybe my eyes are decieving me.
Gords_zenith is offline   Reply With Quote
Old 06-02-2014, 08:15 PM   #70
Slysdexia
Slysdexia's Avatar
Much smaller rod journals. What displacement are you looking at with that?
Sent from my hand computer using radiation.
2.3ltr, all motor, helpful, hks, hks stroker, informative, na brz
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! THMotorsports.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-11-2013 05:25 PM
The *ULTIMATE* Exhaust Thread by ECS Motorsports! | Over 2 Dozen Options! + FREE S&H! AJ@ECSMotorsports Engine, Exhaust, Bolt-Ons 27 09-05-2013 09:14 AM
*--->>ULTIMATE COILOVER THREAD<<---* The Best Deals + Free Shipping FT-86 SpeedFactory Brakes, Suspension, Chassis 95 01-30-2013 07:48 PM
Who's in for the long haul? Laika BRZ First-Gen (2012+) — General Topics 47 07-09-2012 09:48 AM
