#57 |
Drives: Raven FR-S 6M
They can't unless they can prove it caused the issue.
“The World is Flat”
[||•]=(86)=[•||] |
#58 | |
I would expect a floated valve or few LONG before a piston leaves the block if it was over revved.
| The Following User Says Thank You to wparsons For This Useful Post: | cmspooner (03-29-2014) |
#59 |
Drives: 2013 SWP Limited BRZ - Manual
Well I finally got to see the engine of the BRZ when I dropped off my summer wheels at the Subaru dealership. We're still waiting for gaskets to come in.
It turns out that a piston hit a valve and caused the piston to explode, bending the rod and messing everything else up. ![]() ![]() ![]() The metal chunks are what is left of the piston and valves. |
| The Following User Says Thank You to cmspooner For This Useful Post: | 3_NA_HAF (04-12-2014) |
#60 |
Judging by that damage that was over revved by possibly someone missing a shift..... No way that happened at idle, we're not getting the real story
The Frozen North
#61 |
You and subaru agree; but I am telling the truth. You can see from the original post that I didn't think anything major happened.
#62 |
Sorry to double post but I did give it gas when it didn't start up right away; a bad habit from driving old German cars.
#63 |
KCCO From Canada
Drives: Asphalt FRS
it looks like a massive over-rev, but giving you the benefit of the doubt, giving it a little gas when starting isn't going to cause this type of damage. i mean its definitely a bad habit but it at worst would push the engine to its rev limiter.
I have a total guess, i don't know if it's even possible, but could one of the Cam phasing Solenoids malfunctioned and kept a valve or 2 open long enough to slap the piston repeatedly during startup? |
| The Following User Says Thank You to FreshFRS For This Useful Post: | cmspooner (04-12-2014) |
#64 |
Drives: BRZ DGM Limited
so let me get this right, the engine self destructed during a jump start??? Are these engines that flimsy????
#65 | ||
I think the idea of the AVCS failing would be worth pursuing. There's not enough range of adjustment to allow a piston to hit a valve, but if something broke and it was way outside the normal range then it's entirely possible this happened at very low RPM.
#66 |
That's what I meant by missed shift, the old 1-2-1 lol. I just can't see that kind of destruction happening at idle.
The Frozen North
| The Following User Says Thank You to Dipstik-sportech For This Useful Post: | wparsons (04-13-2014) |
#67 |
Drives: '13 BRZ / '11 Outback / '06 Tundra
at least the DI seal on the pictured injector is in good shape! Ya have that going for you.
Sometimes things break, I'm not judging, could be one of many things. Glad they are fixing it for you! |
| The Following User Says Thank You to celica73 For This Useful Post: | cmspooner (04-13-2014) |
#68 |
That guy
Drives: Ultramarine mt FR-S
Ultramarine mt FR-S
P&L stage 1 turbo Prime Motoring Flex fuel Jr Tuned 506whp @17psi (e73) |
#69 |
Did you read the original post? Is this is a serious question? Obviously something mechanical broke and caused valve/piston contact, and then it's all she wrote.
| The Following User Says Thank You to xwd For This Useful Post: | cmspooner (04-13-2014) |
#70 | |
Drives: 2013 GBS BRZ Limited
You can clearly see that something hit the head what appears to be thousands of times. Lets see. Even if idle is high (1500 RPM) based on that pic you let it run "like ball bearings in a blender" for a FEW MINUTES? The only explanation is that the trouble was occurring before you shut off the car, but you didnt notice until trying to restart it. Any chance someone else dove the car before you tried to jumpstart it? Maybe that person left something on and drained the battery too. And for a piston to hit a valve, the timing chain must have come off or broken. If an engineer designed an engine that can vary the valve timing enough in software to contact a piston, then they should be fired (it's called fault tolerance) Oh and the dealer is "waiting for gaskets to come in"? Sounds like they are rebuilding it? I would demand to get a completely new long block. No way I would let them rebuild it after that. If they DID rebuild it, I would make sure to destroy it again to force them to replace it. There is no way the lower end of that engine is sound after taking a beating like that. |
| The Following 3 Users Say Thank You to stugray For This Useful Post: |
| Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package | KCMachine | Brakes, Suspension, Chassis | 111 | 10-08-2014 09:26 AM |
| Died out at light | Legacy | Issues | Warranty | Recalls / TSB | 12 | 05-29-2013 01:27 AM |
| I made a terrible mistake in buying an FR-S for my wife. | Storm_Trooper | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 01-18-2013 02:20 AM |
| TR-B1500 battery and billet battery tray install. | mines13 | DIY (Do-It-Yourself) Guides | 8 | 12-07-2012 04:59 PM |
| Starting to get worried - Engine noise | Laika | BRZ First-Gen (2012+) — General Topics | 49 | 07-02-2012 04:45 PM |
