Old 03-04-2014, 09:52 AM   #57
PoorMansRacing
Anorexic
PoorMansRacing's Avatar
Drives: 2003 Honda S2000 Suzuka Blue
Here's a good ole trick I've used in the past - get a hammer and screwdriver. Hammer the screwdriver through the side of the oil filter and then rotate it, acting as if the screwdriver is a lever.
PoorMansRacing is offline   Reply With Quote
Old 03-04-2014, 11:48 AM   #58
dpesce
Young Blood
dpesce's Avatar
Drives: 2013 Red BRZ 2.0 Premium
Originally Posted by edsbreezy View Post
Those are the ones I used to use in the shop. $4 or something from Harbor Freight. Works like a champ on these filters. Fit in better than the band/strap ones IMHO.
I tend to believe that Filters get over-tightened in the shop for a few basic reasons:
1) most oil change personnel are between the ages of 16-20, I was. Kids this old have probably not learned what a PITA over-tightening can be when your cramped under your car with no lift.
2) An overtightened filter is much better than a leaky one and a customer comeback -- could equal lost job. Now I know a properly tightened filter will not leak but I would presume fear of leaking is a reason enough.
3) THIS IS AN AWFUL ONE but a friend at Jiffy Lube said those fools used to tighten filters with wrenches/straps etc because their hands would get tired. No way to gauge tightness, possibility of ruining seal, filter housing etc... bad idea!
dpesce is offline   Reply With Quote
Old 03-04-2014, 08:31 PM   #59
cycleboy
Drives: 2013 Scion FR-S - Argento
Originally Posted by supramkivtt2jz View Post
just a guess, but im assuming you didnt punch a hole in it and let it drain first.
in these cars, i doubt itll be messy at all.
No, I did punch it through and drain it, but the filter was sitting above other parts, hence messiness!
cycleboy is offline   Reply With Quote
Old 03-05-2014, 11:38 AM   #60
racecat
racecat's Avatar
Drives: Hot Lava FR-S MT
I drained the oil pan first and didn't have any mess at all.
racecat is offline   Reply With Quote
Old 03-09-2014, 11:00 AM   #61
cycleboy
Yes, that's my normal process, drain the pan first.
But on my 2002 (and a lot of other cars I've dealt with) the filter was at an angle such that not all of the oil will ever drain out of it - unlike the 86 where it conveniently is in the perfect spot and oriented so it drains.
Old 03-09-2014, 11:38 AM   #62
racecat
racecat's Avatar
Oh yes, that makes sense. Still unfortunate!
Old 03-09-2014, 04:53 PM   #63
tzhu07
Originally Posted by retoocs View Post
I learned by lesson with my Legacy GT, let the dealer do the first oil change. The oil filter and the drain plugs were probably installed by gorillas.
I used one of these now to get filters loose.
I ended up buying this tool. Haven't actually tried it yet though.
tzhu07 is offline   Reply With Quote
Old 03-11-2014, 01:33 AM   #64
PMok
Codename: Stitch
PMok's Avatar
I had to do this for my first at-home oil change - but I let the power tools do the work for me. Pulled out the cordless drill, drilled a hole into side of the filter, and inserted screwdriver. Easy.
Old 03-11-2014, 09:10 AM   #65
troek
troek's Avatar
Drives: 2012 Toyota 86
all the "hand exercises" ive been doing since my teenage years are paying off as mine came right off with my hands.
Old 03-11-2014, 11:38 AM   #66
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
I use one of these:
https://www.channellock.com/209-Oil-...PVC-Plier.aspx
I think I bought it at the Home Depot for less. I grab the filter from the top because I use a FilterMag that restricts access.
OEM Subaru engine air filter + cabin air filter autobrz Mechanical Maintenance and Tools 6 03-09-2014 09:28 PM
Does anybody know exactly what filter the injen Sri uses? I want to get a new filter Frsexxxy Engine, Exhaust, Transmission 13 02-19-2013 10:04 AM
PLS REMOVE Nezz Australia Classifieds 0 01-31-2013 05:59 AM
will polishing your car to remove swirls remove opti-coat? bacon_cheese_beer Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 10-25-2012 10:41 PM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
