#57 |
Drives: WRBrz
Bah!
Sent from my Nexus 7 using Tapatalk
EBSC - dt.FF - MXP CompRS
#58 |
Drives: 2013 FR-S MT Firestorm recd 5/31/12
It did stop the squeak, but they replaced throw out bearing and clutch.
Firestorm Red MT FR-S received 5/31/12 at 11 AM Novato Ca. Novato Scion, so long 1993 Lexus SC300 MT, you served me well for 18 years ![]() |
#59 |
Drives: Asphalt grey, manual Fr-S
So i have the squeaking noise almost when the clutch is all the way to the ground. I am FI im guessing its probably better to just upgrade the clutch at this point?
#60 |
Drives: Whiteout FR-S
I have the exact same noise coming from my clutch pedal recently. Not sure what I can do at this point as I'm already out of the warranty. 42500
2013 Ford Focus St
2013 Scion FR-S 2007 Honda Civic Si 2003 Acura RSX Type-S 1998 Ford Escort ZX2 |
#61 |
Waited 5 years for this
Drives: '18 MX-5 Club
#62 | |
Will probably keep an eye on it for now since I have 20k left on that warranty.
2013 Ford Focus St
#63 |
Throwing this out there, has anyone removed the clutch spring? I will need to put this back on before bringing it to the dealer. Also wondering if anyone is past 40k with this noise, and or has decided to not fix it and is living with the noise.
2013 Ford Focus St
#64 |
Drives: Argento FR-S
Dropped the transmission, lubed the shift fork where it pushes on the throw out bearing, replaced the throwout bearing since it also looked/felt worn, and lubed the pivot point where the slave touches the fork.
No more noise.
#65 |
Drives: 2013 FR-S 6spd Whiteout
I am having the same sound that was posted in the video. Dropped mine off for service today and mentioned the problem. I will update with what happens...
#66 |
Drives: '94 Ford Aspire
Got exact same problem with mine. 35.5K miles - #9xx ever produced, bone stock, DD, never launched/abused. Will be dropping the car at the dealer on Wednseday and keep you updated.
#67 |
Just picked up my car and they said they could not replicate the issue. I took one of the techs for a test drive to try to replicate the problem... and it didn't happen. He greased up the spring and cable but im believing that it is in fact the throw out bearing like others have reported. When I got home the squeak came back, but alot quieter.
Going to live with it until my warranty is about to expire.
#68 |
Yea last week my dealership did a courtesy warrenty on my throw out bearing. The tech said it was pretty bad.. Clutch sounds and feels great now. Now i just need to figure out whats up with my ac at start up
#69 |
How many miles did you have? There really should be a TSB for this.
2013 Ford Focus St
#70 |
Drives: 2013 Subaru BRZ Lightning Red
I just wanted to also add my personal experience here to confirm what seems to be a common issue with the manual transmissions.
I just picked up my car yesterday afternoon from a local Subaru dealership for the same issue, including clutch squeaking, stiff clutch, and weird catch points. It started initially as just the squeaking clutch, but the clutch action started to get stiffer, and the catch point started to shift on me. The tech initially said he couldn't repro the issue, so I called BS and told them exactly what they had to do in order to repro the problem. After inspection, it was found that the throwout bearing was seizing, which had caused damage to the clutch disk, clutch housing, flywheel, and clutch fork and springs. A full clutch kit was ordered and all of the previously-mentioned items were replaced under warranty. After the repair, the car is driving BUTTERY smooth, with no noise either. Seriously, the car didn't even feel this good from the factory. I'm thinking there is something wrong with the spec for these items coming from the factory, because the car feels fantastic now and the noise is gone! Last edited by stratodyne; 07-17-2014 at 09:10 PM. |
| Loud 'Squeak' Noise From Clutch? | Brndn704 | Issues | Warranty | Recalls / TSB | 23 | 07-20-2020 08:58 AM |
| Upgraded Clutch Squeak | Rybot | Issues | Warranty | Recalls / TSB | 116 | 10-09-2019 02:10 PM |
| Clutch pedal adjustment gone wrong? Clutch issues. | PulpBrah | Engine, Exhaust, Transmission | 12 | 03-06-2017 04:08 PM |
| Clutch Squeak | CatDaddysBBQ | Issues | Warranty | Recalls / TSB | 4 | 07-14-2015 06:44 AM |
| Clutch pedal squeak. | merino_frs | Engine, Exhaust, Transmission | 1 | 08-25-2014 01:00 AM |
