Old 02-07-2014, 01:14 PM   #57
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Originally Posted by jonathan9573 View Post
Did you order the whole kit or just the front lip?
Sent from my iPhone using Tapatalk 2
trd front lip, trd side skirts, sti style rear spat. i dont really like the trd rear valance. skirts and rear are scheduled for tuesday delivery
Old 02-07-2014, 02:36 PM   #58
FRSHunter
Drives: Asphalt FRS
Are those two screws supposed to dig into the bumper? If I do get this maybe ill put something over it.
FRSHunter is offline   Reply With Quote
Old 02-07-2014, 03:09 PM   #59
jonathan9573
jonathan9573's Avatar
Drives: 2013 Asphalt Scion FR-S
They are rivets and they are mounted far enough in they they should t touch the bumper. I have not test fitted it yet but spitfire481 has and might be able to get a pic of where they actually rest when it's mounted to the car.
jonathan9573 is offline   Reply With Quote
Old 02-07-2014, 11:41 PM   #60
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
Holy crap! It fits so well for a replica!
Joe-G is offline   Reply With Quote
Old 02-08-2014, 12:27 AM   #61
m.box.design
m.box.design's Avatar
Drives: 2013 Whiteout FRS
@Chen
Old 02-08-2014, 01:06 AM   #62
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
If you were to chop off the upper portion, would it still flow with the bumper's "mouth"?
Old 02-08-2014, 01:16 AM   #63
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
that is my plan too....I've seem picture that had the license plate frame removed, but it just don't look right without it. might be a better look if cuts the lip as you mentioned on the pic.
Old 02-12-2014, 12:10 PM   #64
jonathan9573
So has anyone seen or has considered painting the entire front clip body color instead of spraying in the flat black areas?
Old 02-12-2014, 11:13 PM   #65
spitfire481
Drives: 2JZ FRS
The section you guys are looking to cut are hollow. when you cut that you will have a decent gap between the lip and bumper
Old 02-13-2014, 03:48 PM   #66
Midarete
Midarete's Avatar
Drives: Whiteout FRS
Would love to see some pictures with the TRD sideskirts as well :P
Midarete is offline   Reply With Quote
Old 02-13-2014, 04:25 PM   #67
spitfire481
Drives: 2JZ FRS
Ill probably go into the shop over the weekend and spray the color matched parts. Ill do the satin black next week sometime. I have some damaged Apr brake cooling ducts ill be painting satin black as well once I'm finished repairing them
Old 02-14-2014, 07:43 PM   #68
jonathan9573
Could you snap a few pics before you spray the satin black? You have the same color as I do and would love to see it.
Old 02-14-2014, 09:36 PM   #69
aSaki
I have that same lip, I have to grind down the corners a little bit where the fog light bezel is or else it doesn't really fit flush when you actually have fog lights so keep that in mind if you are ever going to install fog lights in the future. When you have everything painted and mounted already it'll be a lot harder to work on afterwards.
aSaki is offline   Reply With Quote
Old 02-14-2014, 11:53 PM   #70
spitfire481
Drives: 2JZ FRS
I will be taping off the satin sections before spraying the body color. Then coming back in a few days and spraying the satin black. That way rock chips in the satin black will always show black, not body color
Bayson R lip kit review Cjymiller Cosmetic Modification (Interior/Exterior/Lighting) 59 07-06-2017 01:23 PM
Weather strip/Rubber seal for bodykits FRSHunter Cosmetic Modification (Interior/Exterior/Lighting) 4 03-08-2016 04:34 AM
Weatherstrips for bodykits FRSHunter Exterior Parts (Aero, Lighting, Etc.) 1 12-14-2013 09:15 PM
Who has Bayson R Lip kit? Cjymiller Northern California 21 09-29-2013 09:52 AM
Bodykits....Bodykits....Bodykits.... FT-86GOD AUSTRALIA 78 08-08-2012 09:44 AM
