#57 | |
Drives: Subaru BRZ Sport Tech Satin White
Then let me know how your BRZ handles this. The handling problems of this car in low friction situations are very well documented. The car oversteers too easily and too abruptly when grip goes down. This would also happen in the warm and dry if the car had enough power. |
#58 | |
Drives: '13 GBS Subaru BRZ
I'm in Minnesota, and was on Blizzak LM's last winter. They didn't cut it. I'm on Blizzak WS's this year and they are working great.
#59 | |
Drives: BRZ(sold), STI
This car is somewhat nose heavy and one SHOULD expect it to become harder to drive with less grip. Nothing wrong with rear axle. I've driven Miatas with Torsen all winter long, on I&S tires. This car didn't feel any different last winter. Torsen needs grip to work well, so give it grip. That is - get maximum grip in the worst possible situation==get I&S tires with good ice grip and/or put weight in the trunk. Blaming a decent car because you did a mistake of buying tires that aren't good on ice, and trying to defend your purchase by blaming the car is silly. Get the right tool for the job, then you get a right to complain. |
#60 |
Drives: Attitude
No it doesn't. Any loss of control is directly related to your steering, braking, and throttle inputs. Tires will make it more/less predictable depending on compound.
#61 |
#62 |
#63 | |
Tires should not affect chassis balance as you change grip at both ends simultaneously in the same way. You guys believe whatever you want. I know what I'm talking about. You might benefit from reading what Evo magazine found tracking their Euro spec gt86 in the wet. They found exactly the same problem and one editor declared the car undrivable. He was correct. |
#64 | ||
Drives: Attitude
You sir, are a Grade A troll, but let me attempt to educate a slight bit regardless.
#65 | |
![]() I don't find my snows *that* bad in the dry/wet, but they're definitely nothing even remotely close to my summers (dunlop ZII's).
#66 |
Wayward Member
Drives: Hot Lava 86
So, finally got a chance to test the i*Pikes last night with some pretty nasty weather conditions. I couldn't see the road the whole way home from work, whether it was a main road, interstate, or side road. She made it like a champ. There were some slippery moments, but I never lost complete control of the car or went off the road. I even managed to get into my snow covered, slanted driveway, plowing part of it with the nose of my car.
| The Following User Says Thank You to Nevermore For This Useful Post: | Evil Jesus (12-07-2013) |
#67 | |
| The Following User Says Thank You to Suberman For This Useful Post: | Nevermore (12-07-2013) |
#68 | |
You just fail to understand what I'm talking about. The BRZ suffers from severe and abrupt oversteer in conditions where it should not do so. You need to know this if you intend to drive this car at high speeds on very wet roads, snow or ice. That failure may kill you someday. |
#69 | |
Drives: Attitude
Before you respond that you know FMR dynamics, you brought up the rear weight biased Porsches (without specifying any front-engine model codes), so don't even... |
#70 | |
blowhard
Drives: frs, project forester
Clearly he operates on a level far different than everyone else. |
| The Following User Says Thank You to utekineir For This Useful Post: | neutron256 (12-07-2013) |
| Tags |
| driver defective, part four in the series, suberman the great., terrible debater |
| Cheapest possible snow tires plz | Boofneenee | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 11-25-2013 04:45 PM |
| Snow Tires | Enemies | CANADA | 289 | 11-25-2013 11:35 AM |
| snow tires | debs0712 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 10-18-2012 01:58 PM |
| How effective are snow tires? | theredtape | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 22 | 06-18-2012 08:49 PM |
| Snow tires? | smbrm | CANADA | 12 | 05-27-2012 02:20 AM |
