#57 |
Drives: '13 Toyota GT86 , VW Chico "1.4"
#58 | |
For our Aussie friends: http://www.oilcheck.com.au/technical...gine-oils.html -Dennis |
#59 |
Drives: Subaru BRZ Sport Tech Satin White
Impossible. Never happens.
I suppose we could disagree about what "darkens" means. All engine oil changes colour shortly after it goes into service. This is not relevant to oil change intervals. Heat cycling will darken engine oil. In turbo engines this is very noticeable. |
#60 |
Drives: Skoda Yeti DSG diesel 4x4
#61 | |
It's not nonsense at all. The colour of my oil changes within a few hundred miles after an oil change. If I changed it when the oil turned black, I would be doing 500-1,000 mile intervals!
And in case you missed it: Quote:
-Dennis |
#62 | |
That is simply nonsense because most of my engines have had clear oil for several thousand km's after each oil change. Last edited by sierra; 12-10-2013 at 07:00 PM. |
#63 | |
But we seem to be going in circles so I don't know what the point is. -Dennis |
#64 |
This thread is stupid... look if they guy wants to change his oil every time it's not amber and thinks he can do better than the engineers at Subaru/Toyota (you know, the people who MADE the engine) in deciding when it's time to change the oil, then let him. It's his money and car, not yours.
| The Following 2 Users Say Thank You to TheLaughingMan For This Useful Post: | eSOLOR (12-15-2013), ndsleep612 (12-18-2013) |
#65 |
Drives: Yes
^As he said, you can change your oil whenever you want, but you will be wasting some perfectly good oil... just please take it to get recycled
#66 | |
Depends to some degree on the oil and additives. In general, all engine oil darkens with heat cycling. By how much depends on what's in the oil. The point is colour change or absence thereof is not relevant to deciding when to change it. You can't tell by looking at the oil whether it is any good or not. In fact, the true maximum service life of fully synthetic oil is not known. Oil change intervals are set by the manufacturer based on filter holding capacities and the probability of water contamination. The oil itself remains serviceable for very high mileages. |
#67 | |
Drives: 2014 Subaru BRZ Ltd M/T WRB
I read an article (Car & Driver, maybe?) in which the author said he does an initial one always at 20 miles then again at 500 miles. That seemed awfully conservative to me, but he seemed to have vast amounts of car knowledge that I do not. |
#68 | |
Used oil analyses posted here have shown that there really isn't much difference in how quickly break-in wear metals (measured in parts per million) reduce if you do several oil changes in the first few thousand miles or do only one. People need to stop thinking that the engine manufacturing process is the same that it was 25 years ago. If Subaru and Idemitsu Lubricants thought that the factory oil (which is a more robust formula than the dealer Idemitsu oil) should be changed at any time prior to 3,750 miles, they would put it in the manual. There are many cars going 5-7,500 miles on factory fill and there is nothing wrong with that. -Dennis |
#69 | |
![]() ![]() ![]() Sorry just need to highlight those FACTS for everyone else to read. |
#70 |
Drives: Ultramarine Scion FR-S
I have to do mine at 5000 Miles for the warranty at my dealership or they can use it as an excuse if anything happens.
| Tags |
| some idiots post here, stock oil is synthetic |
| Almost at 1000 miles. Oil change when? | TheGuyWithTheFireStorm | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 13 | 08-08-2013 01:31 PM |
| oil change at 1000 miles! thoughts? | ric342 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 23 | 05-23-2013 11:37 AM |
| Oil change at 1000 miles. | Dorb | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 22 | 03-08-2013 05:18 PM |
| Check Engine light after: Major service (Fuel pump, ECM, and 7500 miles oil change) | R2RO | Issues | Warranty | Recalls / TSB | 3 | 02-04-2013 11:06 PM |
| When to change the oil | Capstan | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 10-11-2012 03:41 PM |
