Old 09-26-2013, 12:03 AM   #57
Iddoit2er
Drives: S
Originally Posted by Silenthillnight View Post
What's the turnaround time for getting the programmed amp back? I sent mine out two weeks ago and sent them an email asking about it and haven't seen or heard anything yet
Sent from my Nexus 4 using Tapatalk 4
Yeah for real. Samesies
Iddoit2er is offline   Reply With Quote
Old 09-26-2013, 01:07 AM   #58
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
I got it back in one day o_o. I live local to them and sent it in pretty early though.
l0aded is offline   Reply With Quote
Old 09-29-2013, 06:37 PM   #59
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
I followed all of your advice, thanks for the directions.
The subwoofer doesn't work no matter what I try.
I have horrible sound if I wire it up the way yours are done with the reference wire from the former dash speakers hooked up to factory ten pin near the original amplifier.
If I hook it up as if it wasn't the reference system with the dash speaker wire disconnect and the regular 400 system 10 pin to the factory 10 pin I get decent sound in the front.
Either way the sub doesn't work.
I disconnected everything and reconnected everything with the fuses pulled, no luck.
No matter what I touch on this car, it never works right the first time.
The directions that came with it are incomplete, doesn't tell where to plug in anything. The DSP is mounted upside down so the white wire connector is on the bottom and the gray is on top, directions are the opposite .
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 09-30-2013, 08:43 AM   #60
buddy32
Drives: WRB Subaru BRZ Limited
PM me if you have questions. I received the reference package last week and installed it on Friday. Everything works on mine. You are right, the instructions aren't complete at this point. I called them to ask and make sure what I was doing was right. I'll write up a review and add to my build thread later.
buddy32 is offline   Reply With Quote
Old 09-30-2013, 01:22 PM   #61
sparks
sparks's Avatar
You can PM me questions as well. I installed my Reference system over the weekend with zero issues.
2013 BRZ Preimum #452 - Sterling Silver
sparks is offline   Reply With Quote
Old 09-30-2013, 02:11 PM   #62
tonystewart
Bad DSP/Amplifier, will need new components, then the signal will activate from the umbilical cable and the subwoofer amplifier will activate. Preliminary diagnosis from OEM Plus Audio will determine this to be a real possibility / primary problem.
It is also possible that the flash update for the dsp never really worked necessitating a new flashed dsp. The key issue is the failure of the dsp to activate when connected to the umbilical
The Following User Says Thank You to tonystewart For This Useful Post:
sparks (09-30-2013)
Old 10-03-2013, 12:37 PM   #63
Iddoit2er
Drives: S
So ummmm yeah, my updated DSP and umbilical cable came back with zero instructions...
Im sure I can figure it out...but seriously?
Old 10-03-2013, 12:47 PM   #64
sparks
sparks's Avatar
I'm sending you the instructions
Old 10-03-2013, 01:31 PM   #65
Iddoit2er
Drives: S
Email sent. Thanks.
Old 10-03-2013, 01:50 PM   #66
sparks
sparks's Avatar
Originally Posted by Iddoit2er View Post
Email sent. Thanks.
And you have the instructions
Old 10-03-2013, 02:00 PM   #67
Squishy
Drives: 2013 WRB BRZ
For those with a BRZ doing the upgrade, I was tweaking the EQ as the upgrade to the DSP still had a little too much in the mid range that brought back some fatigue to listening certain music.
I went through an old thread and amazingly the EQ setup for the stock BRZ setup back then does amazing things to the sound balance after my OEM Audio Reference upgrade.
http://www.ft86club.com/forums/showt...response+curve
I tweaked a little less punchy bass but the mid range imbalance has been smoothed out alot at high volume and low across multiple genres of music I tested from House to Disco to jazz and pop/rock.
Squishy is offline   Reply With Quote
Old 10-03-2013, 02:47 PM   #68
Iddoit2er
Drives: S
I figured it out. Thanks!
Its been such a long time, I dont really remember what it sounded like before, but it sounds pretty good.
While I opened up the door to put the new speakers in, I took out the door control assemblies and wrapped the housing in foam before putting them back in. No more rattle from the door controls! I suggest anyone who needs to take the door card off do this while youre in there. Now to fix the rattle from the TBL...
Old 10-03-2013, 03:24 PM   #69
Norkoastal
Never on Time Always Late
Norkoastal's Avatar
Drives: #silenced crickets
Can anyone confirm the model/part number of the tweeters swapped in? I'm looking to buy these to add to my custom setup.. Thx!
CO>CA Cartel
Norkoastal is offline   Reply With Quote
Old 10-03-2013, 03:31 PM   #70
Silenthillnight
Drives:
I finally got my amp back and I'm instruction-less as well. Can someone send me some instructions as well? Thanks in advance.
Silenthillnight is offline   Reply With Quote
OEM Audio Plus [Reference] 400 shiro Electronics | Audio | NAV | Infotainment 3 08-16-2013 03:18 PM
'Noobish' questions as I look to upgrade my car audio audio. DkY in Vcr Electronics | Audio | NAV | Infotainment 0 09-22-2012 09:45 PM
Wheel reference links JDLM Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 02-27-2012 03:22 AM
Toyota reference has the FR-S with a 2.5L motor Toyota fr-s Scion FR-S / Toyota 86 GT86 General Forum 3 09-24-2011 05:42 PM
Toyota Reference Site Axel Other Vehicles & General Automotive Discussions 7 03-06-2010 07:07 AM
