Old 08-10-2013, 09:56 PM   #57
KKaWing
KKaWing's Avatar
Drives: Nissan Versa
Originally Posted by sierra View Post
Drrrrr! Now I am embarrassed. Especially when geography was one of my better subjects. I'll correct that.
Well maps/locations of places is not the only aspect of geography... how humans interact with the world spatially is another. Tourism, environmental conservation, and spatial analysis are amongst some. You'll even meet geographers that don't know the atlas off by heart!
KKaWing is offline   Reply With Quote
The Following User Says Thank You to KKaWing For This Useful Post:
sierra (08-10-2013)
Old 08-10-2013, 09:56 PM   #58
B L U E S L A T E
Drives: BMW E84
Anyone in the SoCal wanna start a group buy on this?
B L U E S L A T E is offline   Reply With Quote
Old 08-11-2013, 06:17 AM   #59
FR-Sizzle
Drives: brz
Originally Posted by Admiral Ballsy View Post
If - IF - there is anything to be gained from pressurization (and I'm pretty confident in this case there isn't), it's got to be, well, pressurized. Which means no drain holes, etc.
When your driving at 60-80 mph I doubt the 3 holes would make a big difference if any. Air will be entering so fast when your driving at that speed and dont forget that air is also getting sucked into the air box, so the holes wouldnt make that big of a difference if any. They are so small that they probably wouldnt effect the performance of the part at all. If you are paranoid about the holes hurting performance it shouldnt be that hard to cover up... get some super glue and put a piece of plastic over the holes
Its like how that sierra poster thinks the Max Racing duct would effect cooling of the radiator just because it is covering the radiator a little bit when in reality when your driving around on the freeway or locally it has little to no effect.
FR-Sizzle is offline   Reply With Quote
Old 08-11-2013, 11:20 AM   #60
Admiral Ballsy
Shorter of breath
Admiral Ballsy's Avatar
Drives: a soft bargain
Well, yes, they would make all the difference in whether there was any pressurization at all.
I've spent a LOT of time testing "ram air" systems (on motorcycles, FWIW), on a dyno, in a wind tunnel. My senior design project in college dealt with it - the Kawasaki ZX-11 had just been announced, the first bike (and AFAIK the first road vehicle, period) with a true sealed and pressurized intake tract.
You don't get any benefits AT ALL unless the system is 100% sealed, and you have to be traveling over about 100MPH. Even then, the difference is quite subtle - it's less a power boost than it is a 'reshaping' of the power curve.
"Ram air" systems on cars nearly always derive whatever benefits they provide through cooler air, not pressurization - if for no other reason than street cars almost never go fast enough to gain anything.
Admiral Ballsy is offline   Reply With Quote
The Following 8 Users Say Thank You to Admiral Ballsy For This Useful Post:
Black Tire (01-15-2015), DylanJZA (05-26-2023), FRSBRZGT86FAN (04-17-2016), frsvr4 (10-19-2016), ill86 (08-11-2013), Superhatch (08-11-2013), Turdinator (08-11-2013), zooki (08-11-2013)
Old 08-11-2013, 11:47 AM   #61
zooki
Drives: waiting on a 2021...
Please don't bring any real world experience into this conversation. It tends to contradict some people's preconceived notions & expectations. Thanks.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
The Following 6 Users Say Thank You to zooki For This Useful Post:
diss7 (08-11-2013), ill86 (08-11-2013), sierra (08-11-2013), Turdinator (08-11-2013), Wayno (06-17-2015), wootwoot (08-11-2013)
Old 08-11-2013, 02:13 PM   #62
Anaxilus
Drives: They have four wheels
Wasn't going to bother asking but since you have some actual experience, might as well. I've also spent some time w/ a flow bench working on heads and intakes. The question being, do you think the the 10x increase in intake volume could hurt low end throttle response by reducing port velocity? It's also got that kink which doesn't help.
Anaxilus is offline   Reply With Quote
Old 08-11-2013, 03:22 PM   #63
Admiral Ballsy
Shorter of breath
I'm not sure exactly what you're asking - by 'intake', do you mean the air tube? In my lexicon (yes, I'm old), 'intake' means 'intake manifold'.
The only thing in front of the throttle body that would affect velocity would be the relative air pressure. Volume isn't changing; the combination of TB flow characteristics and pressure are going to determine velocity, all else equal.
Old 08-11-2013, 03:22 PM   #64
zooki
I think you port velocity will be affected more by the plenum size of the actual intake manifold, and the shape & length of the runners, not the air filter assembly. Unless you change the actual intake manifold I can't see it making much of a difference. IMHO, 5 HP @ 7000 rpm isn't going to be noticeable in a 2800 lb. car. But that's just my opinion.
Old 08-11-2013, 03:33 PM   #65
Admiral Ballsy
Shorter of breath
I agree 100%.
Old 08-11-2013, 03:52 PM   #66
Anaxilus
No, not the manifold, obviously the intake 'duct' in question here. Everything in the chain affects the system. The reason I ask is because you can increase volume and cause reduced velocity which leads to loss of low-end responsiveness for high-end gain. Not dissimilar to dropping an oversized carb on a big block. You get big numbers but terrible throttle. It's not just a matter of volume being pressurized, this why venturis are employed, to increase speed. If you mean you don't think it will matter much because the butterfly and everything after it is the same, then I get your meaning.
_____
Response isn't measured by horsepower in the upper range. Are you saying all variations of air filter box design apart from OE are snake oil? The media is not the only restriction in the chain.
Anyway, I guess I'd like to see the flowbench numbers on this product, if there are any.
Old 08-11-2013, 03:59 PM   #67
Admiral Ballsy
Shorter of breath
Not in both directions. Sure, you can restrict flow upstream of the TB, but you can't increase it beyond the native characteristics of the TB itself. You're not going to get any more air into the system that you'll get with nothing in front of TB at all.
Venturies affect speed, but not flow. It's like electricity - you can increase voltage, you can increase current, but you can't do both at the same time; power out can't exceed power in.
Old 08-11-2013, 04:44 PM   #68
Anaxilus
Right, which is why I was wondering if this duct could potentially reduce speed by increasing volume. As you put it, it's like Ohms law, so you are playing a zero sum game in your analogy.
Old 08-11-2013, 05:03 PM   #69
zooki
Come on, you know we go by how "cool" parts look and "butt dynos" on this forum. We have no room for empirical data....
I do know that years ago I measured just how much "ram air" effect a scoop placed directly in the front of a car(under the leading edge of the front bumper). It came to 4 inches/water at 100 MPH. Which is about 1/7th of a pound, give or take.
Old 08-11-2013, 09:30 PM   #70
sierra
Drives: Skoda Yeti DSG diesel 4x4
So the ram effect is negligible. What is important is cool, stable air without restriction to the throttle body requirements. This intake looks able to deliver that[for its part] whereas an intake placed directly into the incoming air is in danger of an erratic supply from turbulence, unless it's placed in clear air as in F1 cars.
sierra is offline   Reply With Quote
PERRIN Silicone Intake Duct Review JoeBoxer Engine, Exhaust, Transmission 287 01-24-2018 11:01 PM
FRS bumper duct VENOM~ Cosmetic Modification (Interior/Exterior/Lighting) 36 12-12-2015 01:15 PM
TF Brake Duct Cooling Kit Touge Factory Tracking / Autocross / HPDE / Drifting 77 06-11-2015 08:01 AM
Maxracing dynamic intake duct Mars2 Engine, Exhaust, Transmission 123 09-23-2014 09:39 PM
WTB: Stock Intake Air Duct FR-S Matt Want-To-Buy Requests 4 08-12-2013 07:30 AM
