Old 03-17-2012, 06:02 PM   #57
dsgerbc
Drives: BRZ(sold), STI
That's not the question he was asking, did he?
Your answer to his question could be misleading to a clueless person. Wider tires&rims don't give you more grip on their own. There are enough people out there that think that wider rubber = larger contact patch, no need to spread that misconception further.
Your answer needs clarification: If one wants to go through corners faster - one needs softer rubber, and then you'd want wider tires to make softer rubber last longer when cornering. And then you need wider rims to hold that wider rubber.
dsgerbc is offline   Reply With Quote
Old 03-17-2012, 06:15 PM   #58
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Very true, it was kinda misleading, sorry... but instead of going through very depth & somewhat of confusing post (for someone new into car) you could of just stated that. Was that hard?
Old 03-17-2012, 06:17 PM   #59
bestwheelbase
Drives: 1985 P-Type
Originally Posted by ahausheer View Post
Ok but still what is that box like structure between the resonator and cat? Perhaps an easy way to alter the sound similar to the mustang boss?
So it's another resonator?
Old 03-17-2012, 06:20 PM   #60
bestwheelbase
Drives: 1985 P-Type
Originally Posted by Turbowned View Post
Pointless when you can buy a more powerful AWD WRX for less money...
I see what you did there.
Old 03-17-2012, 06:24 PM   #61
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Originally Posted by Linseal View Post
I'm hoping for an aftermarket Scion logo, like the one the original concept car had above the plate!
Attachment 5567
Attachment 5568
deff no thanks
Of all the things on the FRS concept I wouldn't take the name plate
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 03-17-2012, 10:19 PM   #62
Alfie
Alfie's Avatar
Drives: Sheeveek Si
That is proof of a well designed exhaust!
The Honda S2000 has a similar design with a 4" pipe branching off in the same area.
I believe it affects frequencies and helps thwart rasp at higher rpm.
____"In essence they're identical, and identically excellent." Ollie Marriage TOP GEAR____
Alfie is offline   Reply With Quote
Old 03-17-2012, 11:11 PM   #63
JDMike
Drives: P11
Originally Posted by FRSDREAMER View Post
Sorry Man, but that is not happening.
if anything maybe i can swap the brz in there.
JDMike is offline   Reply With Quote
Old 03-17-2012, 11:15 PM   #64
Snoopyalien24
Mr. Sarcasm
Snoopyalien24's Avatar
Lol what about the turn signal blinkers? Their location is different on both cars.
Snoopyalien24 is offline   Reply With Quote
Old 03-17-2012, 11:24 PM   #65
serialk11r
Drives: '06 AM V8V Coupe
Does anyone know what that black steel (?) cover on the bottom of the car is? It's got the slits presumably for transmission cooling, and it covers only one side of the car, not the other...
Old 03-17-2012, 11:30 PM   #66
Snoopyalien24
Mr. Sarcasm
Maybe for those pesky speed bumps? Idk im totally guessing
Old 03-17-2012, 11:34 PM   #67
FRSDREAMER
FRSDREAMER's Avatar
Drives: 2013 FRS (hopefully)
Do you guys think a 26" mountain bike will fit in the back trunk of the FRS with the back seats down?
And I'm glad that changing the time on the car clock should be fairly easy hence the "M" and "H" buttons.
FRSDREAMER is offline   Reply With Quote
Old 03-17-2012, 11:36 PM   #68
serialk11r
If it were speed bumps then logically you'd want it to cover both sides right?
I'm baffled
Old 03-17-2012, 11:42 PM   #69
Zaben
Drives: Old Accord
That black piece and the mostly flat pieces in front of it are parts of the undertray, or at least a partial undertray. It's for aero. The otherside is already at approximately the same level and relative flat.
Zaben is offline   Reply With Quote
Old 03-17-2012, 11:46 PM   #70
Snoopyalien24
Mr. Sarcasm
I'm baffled
Idk, maybe they're sacrificing coverager over material use? Or, aero?
ahhh
2013 Scion Fr-S on the March Issue of MotorTrend KevinDuMa Scion FR-S / Toyota 86 GT86 General Forum 45 03-12-2012 06:25 AM
2013 Subaru BRZ and 2013 Scion FR-S: A Study in Comparison and Contrast Zgrinch Scion FR-S / Toyota 86 GT86 General Forum 124 02-21-2012 02:43 AM
2013 SCION FR-S Safety Audi Scion FR-S / Toyota 86 GT86 General Forum 14 01-17-2012 08:29 PM
2013 Scion FR-S: 10 Things You Don't Know (Maybe) - Insideline rmagic Scion FR-S / Toyota 86 GT86 General Forum 56 12-15-2011 05:36 PM
