Old 06-16-2013, 08:55 PM   #57
Cyau
Cyau's Avatar
Drives: UltraMarine FRS MT
this is not a RX 8
Cyau is offline   Reply With Quote
Old 06-17-2013, 03:54 PM   #58
slowbrz
Drives: '13 black BRZ MT
Originally Posted by BlueDubbinTDI View Post
Holy balls you bought the car to drive it just go drive the thing! If something goes horribly wrong my guess is that you still have a shitload of warranty left. your day hasn't truly started until you add a tire squeal to it
Hah, Ive actually broke the tires loose quite a lot
slowbrz is offline   Reply With Quote
Old 06-17-2013, 03:54 PM   #59
slowbrz
Originally Posted by kajun View Post
Really depends; what were the outside temps? That'll help your engine start warmer. In the ten minutes you drove, did the car get to full operating temp? When your cousin started it, what was the temp gauge pointing to?
It's not great treatment for the car, but it wouldn't have wrecked your engine just from that. Don't do it regularly and you'll be fine.
It was about 70F. Not sure if it was fully warmed up.
Old 06-18-2013, 03:13 AM   #60
kajun
Drives: Toyota 86 GTS
Well, 70F start is better than a 40F start obviously; chances are it wasn't fully warm, as it usually takes about 10 minutes of driving before it starts to get to normal temps, but like I said above, once or twice is not going to kill your engine.
A little more wear and tear than you'd otherwise expect, but over 100,000 miles you'd hardly notice if it was just a couple of times.
kajun is offline   Reply With Quote
Old 06-18-2013, 07:44 AM   #61
Clembo
'Senior' Junior Member
Clembo's Avatar
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
Since the OP is from California, perhaps he should be aware that it is illegal to idle a car for more than a specific (very short) amount of time there. More and more cities and states are doing or at least considering this. I have friends who have actually been cited and paid fines.
As far as the danger of driving short distances, I start a car and drive after just a few seconds of warm-up (typically when it comes off high idle). Some drives are short, others longer. I've been doing this for some 50+ years and millions of miles and have never had a problem. These are cars, not some fragile works of art that will disintegrate if exposed to the atmosphere. Give the engineers and manufacturers a little credit for designing and building something robust enough to be driven in a wide variety of circumstances, short drives included.
Despite all the so-called outside analysis and hypothetical rhetoric, if you just follow the owner's manual, you'll be fine.
"You'll never know if you don't try" - Shinroko Momose
Clembo is offline   Reply With Quote
Old 06-18-2013, 08:48 AM   #62
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
I bike to work, then race after work, triathalon ftmfw!
LeeMaster is offline   Reply With Quote
Old 06-18-2013, 09:22 AM   #63
FirestormFRS
Dear OP,
Yes it's bad to only drive short distances. No it won't destroy your car. As posted before moisture and fuel will not get evaporated out of the oil and condensation will stay in the exhaust causing it to rust faster.
Your car will last longer than the amount of time it will take those two factors to have an ill effect.
FirestormFRS is offline   Reply With Quote
flux capicator overload, joetheegyptian's new un
>>>Rev Works - Clutches - Drive Shafts - Short Shifters -All Your Drivetrain Needs<<< Rev Works Transmission and Driveline 210 09-12-2014 04:45 PM
Short ram Intake/CAI ? QC-FRS Engine, Exhaust, Transmission 12 02-01-2014 09:02 PM
BPS Short Shifter Alabang 86 Transmission and Driveline 8 09-02-2013 01:58 AM
FS: NRG short hub for frs Pekingduck Interior Parts (Incl. Lighting) 0 01-26-2013 05:55 PM
TGIF[R-S]: Can You Drive a Rear-Wheel Drive Sports Car All Year Long? No5ki Scion FR-S / Toyota 86 GT86 General Forum 27 01-06-2013 09:30 PM
