Old 05-17-2014, 10:22 PM   #57
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
After much deliberation and reading, I decided to just do this mod. And I'm not going back. I pride myself on being a smooth driver, and I didn't even need to adjust. My up shifts and downshifts just feel right after this mod. Timing feels so natural now. Reading through this thread addressed all my concerns.
I think the problem with the helper spring is that it makes the pedal return just a bit slower, so that grey area between clutch disengagement and engagement takes that much longer. That results in the rough takeoffs and jerky shifts.
I ended up taking the c-clip off by using two flatheads. One as a lever to hold it in place, and the other to push the opposite end out. Crude, but it worked.
As someone else mentioned, I did this, pedal height adjustment (1-2 mm above brake), Pentosin MTF2, and MTEC springs. "Car should have been like this from the factory"
unsurety is offline   Reply With Quote
Old 05-17-2014, 10:27 PM   #58
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
As far as stiffness, I'd say it's about 15-20% stiffer now. But most importantly, the pedal action feels linear, and you can feel the clutch engage near the top. I don't even have to think about shifts or stare at the tach from a standstill anymore.
If you cant bear the stiffness, adjust your seating position and don't skip leg day.
Old 05-17-2014, 11:32 PM   #59
blue cat
blue cat's Avatar
Drives: Toyota 86 GTS
Had a look under the there today with the intent of removing the spring, does anyone have a metal bracket on either side of their clutch mechanism? i can see the helper spring up the back and have almost no access to it? RHD car if that makes a difference
blue cat is offline   Reply With Quote
Old 05-18-2014, 12:54 AM   #60
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
I gotta say, I was a bit sceptical about doing this, but after removing it today, I'm a believer! Improvement in feedback is great. It doesn't take long to get used to the slack in the first 1/2" of travel, either.
'13 Argento FR-S
SportInjected is offline   Reply With Quote
Old 05-18-2014, 05:04 AM   #61
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
Just had to chime in once more... after just one night of this mod, you couldn't make me go back to stock. I would sooner sell my car than undo the pedal height adjustment, helper spring delete, put back the stock shifter springs and OEM MTF and drive like that.
In fact, I loved the Pentosin fluid and MTEC springs so much that I grinned like an idiot while testing them out. But you couldn't make me decide between keeping those two or the lowered pedal height and helper spring delete.
It's that good. Upshifts and downshifts feel involuntary and so smooth. I only stalled 3-4 times in 1,600 miles (I remember each instance ) but now I think it would be impossible to do so.
Still not convinced? I'd rather drop a bowling ball on my junk than revert to stock. DO IT... or at least try someone's car who has it done.
Old 05-18-2014, 03:01 PM   #62
elbles
Drives: 2013 Subaru BRZ
In my car, I noticed that when the clutch was fully depressed (and the return spring thus fully extended), there was a metal bracket obscuring access to the top pin (to push it out). I had maybe a inch or so of clearance between the passenger side of the pin, and the bracket.
I did the same thing myself, but it was the easiest way to get it out that I could think of. Worked perfectly (and quickly).
Many thanks to MikeyBRZ for the original post, and all others who commented... this improved the car so, so much.
elbles is offline   Reply With Quote
Old 05-20-2014, 11:30 PM   #63
Slysdexia
Slysdexia's Avatar
Drives: '14 Monogram 6MT FR-S - Hot Lava
I removed the clip and pin with the clutch pedal up, spring compressed.
I tried it this way, and couldn't get my giant hands in there at the same time. I ended up wedging a big flathead under the clip and prying to bend it out of the way.
Sent from my PO-T4T0 with Eyes.
Slysdexia is offline   Reply With Quote
Old 05-21-2014, 06:23 AM   #64
patz0r
Drives: GTS86
Anyone have an update to this?
The clutch would be so much better without the spring!
It looks like a clutch prison there in my GTS86
patz0r is offline   Reply With Quote
Old 05-21-2014, 04:00 PM   #65
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
If you guys could take pictures, and/or get a diagram e-mailed from your local Toyota dealer maybe we could see what's going on.
This is what the bracket looks like on a LHD:
It's in the way, but it just makes it trickier. If the bracket is no different, then I think it's just more difficult because the RHD pedal assy is in a tighter spot due to being closer to the driveshaft tunnel.
Old 05-21-2014, 05:02 PM   #66
codesplice
Elite Recognized Geek
codesplice's Avatar
Drives: 2014 DGM BRZ Limited
I'm gonna give this a go tonight. Wish me luck!
Success!
I don't know why I didn't do this sooner - I should have. Thanks guys!
This post is a work of fiction. Names, characters, places, and incidents either are the product of the poster's imagination or are used fictitiously, and any resemblance to actual persons, living or dead, business establishments, events, or locales is entirely coincidental.
G+
codesplice is offline   Reply With Quote
Old 05-22-2014, 07:14 PM   #67
Lord Peth
Drives: 2014 BRZ
Originally Posted by k.houan View Post
Hmm, I want to try this. But how hard would it be to reverse? In case I need to get back to stock or don't like the new clutch feel.
Sent from my LG-E980 using Tapatalk
This. Word from anyone that re-installed it?
Lord Peth is offline   Reply With Quote
Old 05-22-2014, 07:32 PM   #68
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
I've done the spring removal for a couple of friends. The only person I know that didn't like this change was the guy who learned how to drive stick on his FR-S (with the helper spring in)
I'm thinking with the pedal depressed, you could stick the spring in and force the top spring seat in. Not sure though.
Old 05-23-2014, 07:20 AM   #69
Lord Peth
Drives: 2014 BRZ
I've never had anything but manual my whole life, looks like the spring goes!
Old 05-23-2014, 07:24 AM   #70
Slysdexia
Slysdexia's Avatar
I'm reasonably sure that you could compress the spring with zip ties to get it all back together.
clutch helper spring, helper spring removal
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 12:11 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 10:01 AM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
