#57 |
Overall, on the FR-S/BRZ/GT86 my experience has shown the EL header making a bit more torque/power in the mid and upper RPM ranges over the UEL, with a little less torque in the lower RPM range (some EL header have not exhibited this in the lower RPM range). The amount of gain the EL provides is dependent on many factors -- it is not a tremendous amount, but in N/A form every little bit helps.
Stick to a high quality header, choose your sound preference and powerband, and you'll have a win, as any well designed EL and UEL header will net you decent gains and with a tune will eliminate the torque dip. I quickly grabbed a couple graphs from my laptop for comparison, not the best graphs, but I think they make the point. Different cars, different days, same dyno. For this comparison, don't compare the numbers, just the shape of the graphs. Both graphs are after tuning: EL header, with tune: ![]() UEL Header, with tune: ![]() As you can see, both have very linear power curves, and very flat torque curves, with no torque dip. Both performed very well. Look at the shape of the torque curves, and you will see the EL header producing a small increase in torque through the mid-upper range (slight up-hill, vs. the flatter UEL torque curve). - Bob Last edited by Circuit Motorsports; 07-16-2014 at 05:28 PM. |
| The Following User Says Thank You to Circuit Motorsports For This Useful Post: | Turdinator (07-16-2014) |
#58 | |
Honeydew old ID
Drives: GT86
Nice write up, can you get any data from a Tomei EL vs Tomei UEL header? debating which one should i order.
Used to owned M3 and Lotus, but love my GT86 the most.
| The Following 2 Users Say Thank You to skyloran For This Useful Post: | Circuit Motorsports (07-31-2014), Toyota GT 86 (09-01-2014) |
#59 |
Drives: '18 STi
#60 |
BOXER FR
Drives: WRB BRZ Limited
I had my bugeye with stock UEL header for 200k miles. zero problems.
Build Thread of the "STI theme BRZ"http://www.ft86club.com/forums/showthread.php?t=61522
#61 |
| The Following 4 Users Say Thank You to Circuit Motorsports For This Useful Post: |
#62 |
Drives: 2013 Scion FR-S 10 Series #2013
I'm glad this thread got revived I'm very curious about the sustainability of the engine with an EL or UEL header upgrade in the long run as I am in the market for a set right now. Thanks! Subbed for updates
#63 | |
Drives: BMW 120d
The manifold design will be down to the design parameters & engine bay constraints. Properly tuned equal length runners will produce very effective scavenging in tight rpm bands. However, EL manifolds while have bands of conflicting flow causing dips in the torque curve. Unequal length manifolds each runner fall in & out of harmonic sync with the other runners but not at the same time. When the length of each runner is tuned properly this will cause less efficient scavenging but over a much wider rpm band. A lot of supposed deficiencies of UEL manifolds are because they are harder to tune correctly as the length of one runner effects the optimal length of the other runners. Yes that's going to be generalised & wrong in certain respects as that's about 85 pages into 1 paragraph. |
| The Following 4 Users Say Thank You to stonenewt For This Useful Post: | diodelphi (01-15-2015), racecaresuaceb (05-30-2015), ThatAsianBradah (02-09-2018), Xero-Limit (09-30-2014) |
