#57 | |
SW5 Driver
Drives: Asphalt FRS
I dont see why everyone thinks this is going to hurt a car. The OE ECU still has the final say on limits so if anything it seems safer to me but maybe I dont understand the finer details... I mean shit im only a pilot and part time mechanic... I am by no means a professional. In fact next to you John Im extremely amateur but dont let that blind you to some one elses product. |
#58 |
SW5 Driver
Drives: Asphalt FRS
On a side note, talking about an ECU registering "disconnects". Would the ECU not assume a disconnect every time the battery died? Or you unplugged the battery to reset the ECU after a bolt-on upgrade as some suggest? Just curious.
#59 | ||
-John |
The Following User Says Thank You to Visconti For This Useful Post: | cruzinbill (03-12-2013) |
#60 |
Drives: '13 BRZ | '04 E55
The unichip from my understanding intercepts only a couple signals. You don't unplug the ECU. Rather you unplug the specific device you want to intercept, like throttle position for example, you plug the unichip harness between the throttle body and factory harness.
#61 | |
Drives: Argento 6spd FR-S
Dealers aren't gonna go digging for something unless things are fishy. So you blow an engine because of either ecutek or unichip tuned wrong and you want to cover it up... well you're a piece of shit and I hope you lose the ability to drive or walk after that. Guys have went in for the HPFP change with a ecutek tune on.... dealers never said shit. I think people are getting out of control with the whole "dealers gonna take my warranty" bs. These are the same clowns that try to scare people off from adding a sub or somthing because "dealer said my warranty is void now" |
The Following 3 Users Say Thank You to cruzinbill For This Useful Post: |
#62 |
Some versions used the ECU harness so everything is done there, this one uses plugs for the sensors it is changing the signal from/to in the engine bay. On this car they intercept the throttle body, the MAF, and the crank position sensor. That's it.
#63 | |
#64 |
Drives: ex500r
Could we all agree, that a tuning application is only as good as the tuner? If its either UniChip or ECUtek ultimately we have to rely on the person tuning it. ECUtek will come with a professional tuner, that SHOULD know all the ways to tune. For Unichip tuning you rely on yourself or someone else map. Im not saying that Amateur guys tuning cant beat Pros at tuning, but at least you have the peace of mind that you know who did your tune.
As You can tell i am little bias towards ECUtek, mostly because i am not a tuner/ or would put my 25k car in the hands on an unknown tuner. |
The Following User Says Thank You to Xdragonxb0i For This Useful Post: | JoeBoxer (03-13-2013) |
#65 | |
ScionFrsFan
#66 |
Drives: 13 WRB BRZ
So much bias in this thread.
![]() Sent from my GT-N7105 using Tapatalk 2 |
The Following User Says Thank You to VoiD For This Useful Post: | l0aded (03-13-2013) |
#67 | |
Drives: ex500r
Well Simply, it seems like most people who want to buy unichip is to tune their own cars. And since you don't tune for money/ For a living i would call you an amateur tuner. But let say Jack is a Professional Unichip tuner ( i dont really know, he might just be a supplier). I would see his tune as equivalent to let say John from visconti. I would use UniChip if i knew the tuner, or if the tuner was local and reputable. |
The Following User Says Thank You to Xdragonxb0i For This Useful Post: | Delacruzmd (03-13-2013) |
#68 |
Drives: DS FRS
#69 |
Drives: ex500r
Then i stand corrected, my perspective of unichip was a more hands on tuning application, where the user does have full control of tuning.
#70 |
Drives: DS FRS
It can be, if you buy the tuning module, but like Ecutek, most people use the off the shelf maps provided by the experts (Jack in this case). He has maps for different intakes, exhaust combos and octane levels.
Unichip MapsQ software | Unichip Jack | Software Tuning | 191 | 12-28-2015 07:28 PM |
Unichip EMS | Unichip Jack | Engine, Exhaust, Bolt-Ons | 300 | 11-22-2014 03:13 AM |
SAC Unichip Mod | Afzal | AFRICA | 35 | 02-14-2013 08:35 AM |
unichip | 13 FR-S Veteran | Engine, Exhaust, Transmission | 9 | 02-03-2013 11:05 PM |
unichip | 13 FR-S Veteran | CANADA | 0 | 12-03-2012 05:31 PM |
