Old 06-09-2013, 06:32 PM   #57
Basti
Basti's Avatar
Anyone got new insights on this matter already?
Also, what about the piston rods? What would be the problem if they were cockeyed? And are they, now?
Basti is offline   Reply With Quote
Old 07-26-2013, 05:01 AM   #58
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
Surprised there isn't any more input on this...
Kostamojen is offline   Reply With Quote
Old 07-26-2013, 05:31 AM   #59
zephyr69
Drives: TRD FT-86
i'll be trying to search through some japanese sites and see what they have to say. will post here if i find anything from any crazy japanese NA builds in development for the FA20
zephyr69 is offline   Reply With Quote
Old 07-26-2013, 05:51 AM   #60
zephyr69
Drives: TRD FT-86
Found this on one a blog of a individual Japanese tuner:
86のFA20エンジンというのはFB20エンジンのほぼフルチューン化(というよりはスポーツエンジン化 )されています。
Toyota 86's FA20 engine is essentially a FB20 engine that is fully tuned (essentially a sports engine version).
インプレッサやレガシィのエンジンEJの時よりも数段エンジンの組み付け精度をあげているのとすべての部品 において軽量化と低フリクション化されているので環境対策エンジンながらもリッター100馬力達成していま す。
In comparison to the Subaru Legacy's EJ engine, FA20 level of intricacy is much higher. Many parts of this engine are lightened and friction is reduced which is why they have been able achieve 100 horsepower per liter.
ただこのNAのままでは改造の余地があまりありません。
There isn't really much room to play with engine in terms of an NA build.
NAエンジンらしくもっと高回転まで突き抜けるようなエンジンがほしい!
I want a higher revving NA engine with more thrust and responsiveness!
となるとFA20では不可能だと思いました。
However, I don't think it is really possible with FA20.
Old 07-26-2013, 05:57 AM   #61
zephyr69
Drives: TRD FT-86
I wish they worked with yamaha to build 86 engine instead of subaru..zzzz
Old 07-26-2013, 07:52 AM   #62
regal
Best bet with this engine is to run the piss out of it and hopefully in a few years there will be a good solution. I remember not buying an MR-S because of the engine, only to wish I had when the 2z kits started to appear.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 08-21-2013, 08:00 PM   #63
Kostamojen
Surprised none of the tuners have tried this yet...
Old 08-22-2013, 01:28 AM   #64
DoctorNick
DoctorNick's Avatar
Drives: '13 BRZ
I guess too busy putting LS and 2jz motors in instead
DoctorNick is offline   Reply With Quote
Old 08-22-2013, 02:29 AM   #65
Kostamojen
LMAOOOOOOOO!!!
Old 08-22-2013, 02:56 AM   #66
Sonolin
This is a very interesting thread. I would be very interested in an N/A build if remotely affordable for a decent power increase. Unfortunately, I have little to no knowledge of engines other than mine has 4 cylinders, lays flat, and is 4 stroke lol.
Sonolin is offline   Reply With Quote
Old 08-31-2013, 12:50 PM   #67
fa5tco
fa5tco's Avatar
Drives: 2013 Firestorm FRS
I wonder if the E257 bottom end would mate tp the fa20 heads? minus the di of course. Could buy the ej257 bottom end for cheap and have the exhaust/turbo/ic piping all custom done for cheap too
fa5tco is offline   Reply With Quote
Old 08-31-2013, 02:26 PM   #68
Kostamojen
No not even close.
Old 08-31-2013, 05:24 PM   #69
s0sl0w
Proud of Boxer
Surpirsed this hasn't been determined but I'm 95% certain that the FA20 uses the same cocked bottom pistons as the fb20.
The biggest issue I could see standing in the way is the fact that the FB25 is made to bolt up to a subaru specced/sourced transmissions whereas the FA20 is bolting up to a toyota sourced transmission. I wouldn't be surprised if the bolt pattern is different between the two.
It shouldn't be too pricey to find a wrecked Forester FB25 and get to work honestly.
Some quick research indicates a FB25 can be had for around ~$3000, assuming you can afford to take your car off the road for a winter and do the work yourself, you could feasibly do this swap for about the same as some of the supercharger kits are going for.
s0sl0w is offline   Reply With Quote
Old 09-03-2013, 05:39 PM   #70
jet86
Mad Sciontist
jet86's Avatar
Drives: gt86
So guys I have acquired a fb25 short block and I've got numerous fa20 heads. I threw the heads on the fb25 block and well.. they fit quite well. Only issues I can see with this setup is the combustion chamber may need to be ported (probably cnc) a you have to take it out 8mm bigger. And the other thing is the starter motor location is missing off the fb25. Everything else is identical.
Sent from my GT-I9505 using Tapatalk 4
jet86 is offline   Reply With Quote
The Following 2 Users Say Thank You to jet86 For This Useful Post:
Calum (09-03-2013), neurokinetik (10-25-2013)
Would you guys prefer FB20 or FB25 for NA FT? tranzformer Engine, Exhaust, Transmission 89 07-20-2011 05:00 PM
FT-86 to be "introduced" for early 2012! Press conference clip from Geneva Motorshow ft86cbx Scion FR-S / Toyota 86 GT86 General Forum 32 03-05-2010 03:07 PM
Design Proposal for a New VW Corrado from the Imaginary World of "What If?" vh_supra26 Other Vehicles & General Automotive Discussions 2 02-13-2010 07:26 PM
